Welcome to the North American Subaru Impreza Owners Club Thursday October 19, 2017
Old 10-29-2000, 08:08 AM   #1
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Post Wide band O2 on stock ECU?
Would this be a possible swap? Would the stock ECU run better or just explode with a wide band 02 sensor?
Gary
HamFist is offline   Reply With Quote
Old 10-30-2000, 04:35 AM   #2
Nigel
Member#: 1919
1994 Legacy Turbo
Post
I believe the wide-band has a 0-5V output versus 0-1V for the narrow-band. That means that most of the output from the wide-band sensor is going to be out of range of what the ECU can interpret (a 0-1V range). But it's hard to say for sure how it would react without knowing the circuit design. I don't think it would react favourably though.
Nigel
Nigel is offline   Reply With Quote
Question on wide-band O2 placement fueledbymetal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 08-22-2002 01:47 PM
cheap wide-band O2 display ellisnc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-05-2002 08:31 AM
Factory Wide band o2. Need info. AZScoobie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 12-19-2001 10:55 PM
('93-'01) Wide band O2 sensor voltage range jeffg Impreza Forum 5 06-05-2001 02:26 PM
New Info about my00 wide band o2 sensor??? skidplatez Normally Aspirated Powertrain 3 11-03-2000 11:08 PM
