Welcome to the North American Subaru Impreza Owners Club Monday January 23, 2017
Old 07-17-2004, 02:39 AM   #1
motoracr22
Member#: 55022
1994 325is
Mauritus Blue
Default Tire Pressure on L
The doorjam says 29 Front / 32 Rear. There is visible bulging of the tire at this pressure on my Impreza. What is a reccomended pressure for 195/60/R15?
motoracr22 is offline   Reply With Quote
Old 07-17-2004, 09:19 AM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
29 front and 32 rear
Old 07-25-2004, 02:29 AM   #3
Back Road Runner
Member#: 60082
2004 Forester STI
I just go by tire, usually max. Different pressures as suggested on the car do affect handling and ride some. Lower pressure means more traction and a softer ride. However, rolling friction and tire wear will probably go up a little, more tire heat build up too. They'll feel less stiff and will diminish handling feel too. It's all trade-offs. Just choose the ones you want and don't go too extreme with the pressure either. All-in-all don't worry about that too much, 29psi and 32psi on a 35psi max tire will probably be completely unnoticable to the average driver in any way.
Each tire is different in look and behavior. Picking a good brand/model of tire in the first place will give you better characteristics than you could ever get playing with pressures.
I personally wouldn't dwell on the little things like a few psi on a tire. Anyways, you'll probably run your tires through a wide range of pressures anyways as they lose pressure over time and you periodically fill them back up.
Best tire pressure on stock tires HAL1 Tire & Wheel 21 12-30-2005 10:19 AM
hi, what is the standard tire pressure on the stock tires? chanyeehon Newbies & FAQs 23 08-10-2005 07:53 PM
tire pressure on stock tires for sti? for track event slowstangguy Motorsports 8 01-12-2005 07:24 PM
reccommended tire pressure on 215/45/17 for WRX GDA Brakes, Steering & Suspension 1 06-08-2001 07:49 AM
tire pressure on cars from sc subaru yuletak Bay Area Impreza Club Forum -- BAIC 3 03-24-2001 01:55 AM
