Welcome to the North American Subaru Impreza Owners Club Thursday April 19, 2018
Old 07-30-2004, 06:43 AM   #1
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Default compression test results
switched over to copper 1-step colder plugs yesterday (ngk bkr7e). took about an hour and a half, taking my time with three beers..
tested the compression while i was in there, and got 165 on each cylinder!
the motor is tight and strong and i am happy. at first i didn't believe the results, so i tested #2 and #4 a second time, and i got 165 again. motor was almost too warm to work on.
27k miles total, last 5k with utec st2, last 24k with mbc @ 16-17psi. i have never used under 93 octane gas. mobil 1 motor oil since 4k miles. i didn't have a jewler's loupe, but from what i could discern at first glance on the oem plugs they looked clean. i'll take a closer look today.
i didn't go easy on this motor when i broke it in. i didn't abuse it, but i was doing quick blasts up to 100mph while under 500 miles on the odo.
fwiw,
ken
Old 07-30-2004, 07:21 AM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Very good Ken, that shows that your tuning ability is sound!
cdvma is offline   Reply With Quote
Old 07-30-2004, 07:22 AM   #3
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Yeah, I hate how it needs to be warm to do a compression check; it's sooo much easier to pull the plugs when it's cold
Zackbo is offline   Reply With Quote
Old 10-10-2005, 04:15 PM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
did another test today. 39k miles, so 12k on the pulled coppers. engine not so warm as last time. car was stone cold so i idled it until the upper radiator hose was pressurized and a bit warm to the touch. probably ~120-130*F.
157, all four corners.
i've been running a vf23 @ 20psi @ 11.5:1 for ~6 months now. before that was the oem @ 20psi winter, 18psi summer.
old plugs didn't look too bad. ground strap was grey/white, electrodes a bit worn and rounded but not excessively so. gaps had widened from 0.032 to 0.037.
gapped the new ones to 0.035 (out of the box they were ~0.032) and slapped 'em in. took about an hour... no beers this time.
ken
Old 10-10-2005, 04:19 PM   #5
Freon
Member#: 88322
2009 BMW 135i
How are you testing compression? Sounds like you have some sort of DIY setup for this.
Freon is offline   Reply With Quote
Old 10-10-2005, 04:25 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
a compression tester! 25 bucks, actron brand, from sears.
take the old plugs out, stop the injectors from flowing (i use the utec security map), stick throttle wide open, put the tester in the plug hole, crank for 5-10 seconds, get out and read gauge, reset, move to another hole, repeat.
it takes a few more minutes but it's peace of mind, and it's only like another 10-15 minutes tops. highly suggested tool for the collection.
Old 10-10-2005, 08:01 PM   #7
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
I wasn't aware that there was another faster way to do it. In any case, nice numbers.
What made you decide to run a gap 0f 0.035 inches versus the as specified gap?
-Cheers
specialev is offline   Reply With Quote
Old 10-11-2005, 07:15 AM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Old 10-11-2005, 07:27 AM   #9
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
That, and I like his break-in method.
FWIW, Ken....I have sfw that computes dynamic compression in a given engine; you've gotta know the volume / camshaft specifics, but it's pretty neat.
S.
n2xlr8n is offline   Reply With Quote
Old 10-11-2005, 09:12 AM   #10
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i should point something out too...
it is better/safer to disconnect the coilpack entirely from the harness while you're cranking without load. that way you have no secondary coil system in place and therefore no high voltage that tries to find a path to ground. once an arc forms somewhere and leaves some carbon behind, it's going to do it again and again... at that point you'll probably end up getting a new coilpack.
when disconnecting the packs from the harness, be careful with the little clips that hold the terminals to the coilpack. they're fragile and i've heard of lots of folks breaking them off, which sucks.
Old 10-11-2005, 09:55 AM   #11
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
S.
Is the psi results of a compression always the same for a given comp ratio?
My reason for asking is because I recently comp tested mine and got an unusually low number on all 4 cylinders(126 psi), but exactly the same number on all 4. its an axis stg 1 block w/ wrx heads w/ cometic gaskets. I was told by Ron @ axis that its the ring gap he uses, so when the pistons expand, the ring gaps dont butt ends. He said anything above 120 is fine.
I figured maybe my comp ration isn't what I thought it was for the low comp test numbers.
I used same method as ride, hot motor when tested, throttle plate open, all plugs were out.
SBW is offline   Reply With Quote
Old 10-11-2005, 01:53 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...and pulling the 'IGN' fuse does exactly what that the above does not????
Old 10-11-2005, 02:14 PM   #13
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
keeps me from having to find the ign fuse.
seriously, where is it? i assume its in the underdash block...
that would of course work just as well.
Old 10-11-2005, 04:40 PM   #14
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I tested both of the WRXs about a month ago...160 on all 4 in the 48k car and 155 on mine at 57k
Lets hear it for EJ205s!
(psst I still run 0.028 )
Old 07-14-2006, 09:24 PM   #15
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
time for another update... 46k miles. been running a vf23 at 22psi and 11.5:1 afr for almost a year.
(in order of test)
#4 160psi
#2 160psi
#1 157psi
#3 155psi
#4 155psi
i can live with those numbers!
also made two changes to the ignition system, and one to the overall electrical system...
1) gapped plugs to 0.040
2) ran 4 individual 10awg ground wires from coil pack anchor bolts directly to battery -ve.
3) ran additional 10awg ground from existing ground point on #4 intake manifold runner directly to battery -ve.
no ecu reset. god damned car seems to idle smoother. we'll see how it holds up.
Old 07-14-2006, 09:58 PM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
didya ever find that fuse?
Old 11-06-2006, 09:21 AM   #17
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
(in order of test)
#4 160psi
#2 160psi
#1 157psi
#3 155psi
#4 155psi
periodic update: no issues yet with misfires at 0.040 gap.
Old 11-06-2006, 11:08 AM   #18
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
what misfires do you have? I sometimes rarely get those low load misfires. I havn't had one for weeks though. Heard they were because of my semi-lightweight flywheel and modded stock injectors.
akira02rex is offline   Reply With Quote
Old 11-06-2006, 11:52 AM   #19
pictureboy
Member#: 85132
2017 Bolt
I sometimes get the no/light load misfires on my 02 as well. My flywheel is stock but I do have modded stock injectors. My tuner suggested I try changing out the colder plugs for stock ones and see if it helps. I just changed them last friday so too soon to tel but so far no codes. He also mentioned the crank or was it cam) angle sensor can throw codes for no real good reason, expecially on the 02's.
pictureboy is offline   Reply With Quote
Old 03-23-2007, 08:32 PM   #20
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
165-170 in all 4 as tested today. Same as it was last time I did it
Old 03-25-2007, 12:46 PM   #21
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
I tried to do a comp. test on my car, but got too damn frustrated an gave up until I can regain composure!! It's so hard to tighten the air hose in the plug holes, there's just no room to work! Anyone one have any tips/pointers??
aps2fast4u is offline   Reply With Quote
Old 03-25-2007, 07:53 PM   #22
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I find that I have to "point" the hose a bit more vertical than I would expect it to be. Align it with one hand and twist with the other. Its hard but once you get the trick it becomes easy on the rest of them.
Old 03-26-2007, 09:33 AM   #23
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
Thanks, I'll give it another try this weekend.
Old 05-15-2007, 10:14 AM   #24
Nicklz
Member#: 94096
2003 WRX
OK instead of starting a new thread I'll revive this one.
03 wrx 130k miles (last 85k AP~stg2)
1: 150
2: 155
3: 145
4: 135
This was done on a cold engine.
I've been debating swapping on a 16g, but wanted tog et results from compression test first. Think it'd be safe at least for awhile??
Nicklz is offline   Reply With Quote
Old 05-15-2007, 10:29 AM   #25
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
sorry to tell you but 4 looks pretty low, i'm afraid.
that's a 20psi drop from its sister cylinder.
that said, i'll bet there are people driving around with cracked pistons who have no idea whatsoever. depending on the failure they can be remarkably subtle in their effect on power.
Compression Test Results subachad Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-29-2003 07:08 PM
Compression Test Results @ 55,650k PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-12-2003 02:59 PM
EJ25 Compression Test Results at 50,000 miles latinskllz Normally Aspirated Powertrain 4 11-11-2002 02:46 PM
Compression Test Results- 3 Motors dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-31-2002 11:32 PM
Compression test results numbers Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-12-2001 01:08 AM
