Welcome to the North American Subaru Impreza Owners Club Thursday April 27, 2017
Old 08-18-2004, 08:34 AM   #1
dr_wheel
has never eaten a strawberry
Member#: 60106
I eat pieces of
** like you for breakfast
Question STi Alignment Question - newbie
I am swapping out the factory BBS's for a set of new wheels this week and I am looking to get an alignment as well. It should be noted that I am looking for a strictly street setup here... maybe a little on the aggressive side. Problem is I have absolutely 0 knowledge when it comes to suspension settings. The specs:
-2005 STi
-18x8 wheels, +49mm offset
-235/40/18 tires
On with the questions:
1. Recommended tire pressures?
2. Recommended alignment settings?
Suspension is stock. Any advice would be greatly appreciated.
dr_wheel is online now   Reply With Quote
Old 08-18-2004, 12:20 PM   #2
dr_wheel
Member#: 60106
I eat pieces of
Default Is this thing on?
Anyone at all? The factory specs read as follows:
Toe
Front: 0 in (0mm)
Rear: 0 in (0mm)
Camber
Front: -0 30'
Rear: -1 40'
For all I know, these could be missile coordinates. Seriously though, could anyone recommend streetable settings that are slightly more aggressive than stock yet would not cause any problems with excessive or uneven treadwear?
Old 08-18-2004, 01:32 PM   #3
JIM THEO
Member#: 29715
2004 WRX
WR blue
First step increase front camber to at least -1 degree that is quite "safe" for your front tires.
Secondly if you want more oversteering behaviour give some toe out rear - about 1mm per wheel is enough - but if you want better steering response some toe out front.
Bear in mind Prodrive suggests -1,35 camber front and 1mm per wheel toe in rear for STI04 cars that have their springs.
JIM
JIM THEO is offline   Reply With Quote
Old 08-18-2004, 02:09 PM   #4
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
I wouldn't bother with rear toe. Keep it at 0 to minimize tire wear. Like Jim said, I would recommend -1 degree front camber with 0 toe everywhere. Rear camber is not adjustable.
-Tom
trhoppe is offline   Reply With Quote
Old 08-19-2004, 05:27 AM   #5
dr_wheel
Member#: 60106
I eat pieces of
Thanks for the feedback, guys. I appreciate it.
newbie alignment question?????? gregbenoit Newbies & FAQs 12 02-08-2008 12:23 PM
newbie alignment question x12oyx316x Newbies & FAQs 1 05-22-2004 06:00 PM
newbie alignment questions Chuck H Brakes, Steering & Suspension 1 01-16-2004 10:18 AM
Alignment question for STi RoyBoy016 Brakes, Steering & Suspension 10 12-13-2003 03:08 AM
More STI alignment questions ChrisW Brakes, Steering & Suspension 4 11-01-2003 05:10 AM
