Welcome to the North American Subaru Impreza Owners Club Sunday August 20, 2017
Old 08-21-2004, 04:38 PM   #1
blackie
Member#: 42979
03 wrx
blizzzack stage IV
Default can the stock knock sensor be used for knocklink?
I tried a search and found a few things about this subject but not a definant yes no answer. can you use the oem knock sensors signal to feed a knock link system? and also who has the best deal on knock link? thanks
blackie is offline   Reply With Quote
Old 08-21-2004, 06:15 PM   #2
blackie
Member#: 42979
03 wrx
blizzzack stage IV
does anyone know if the knock link puts a draw on the knock sensor wire. there website says that most newer vehichles have a knock sensor, buit if they dont they sell a separate one too. the way they worded that makes me think that its ok to tap into the oem knock sensor for the signal for the knock link. has anyone done this yet?
Old 08-22-2004, 04:11 AM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
u can use it but it draws too much power from the signl just get another one theyre cheap on ebay
im pretty sure any one wire knock sensor will work becauseu can tweak the sensitivity
i ordered some random volvo sensor
Old 08-24-2004, 02:22 PM   #4
coolcougar
Member#: 19674
2006 Baja Turbo 4EAT
Brilliant Silver Metallic
I've read that Sandstallion has some of the best prices on Knock Links plus IIRC they sell Bosch knock sensors.
coolcougar is offline   Reply With Quote
can stock exhaust gasket be used for 2.5in axleback Jungdragon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-15-2005 07:03 PM
Can a stock fuel pump be used for alc/water injection? LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-19-2003 08:35 PM
Can other Impreza MAF Sensors be used on 02' WRX? Hank3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-13-2002 02:53 PM
Can the wastegate on the Stock WRX turbo be adjusted for lower boost? BrysImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 8 09-08-2002 05:27 PM
Has anyone removed the stock Knock sensor?? TMR Impreza Technical Forum Archive 7 05-19-2000 06:52 PM
