![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 24234
VIC
Vehicle:2003 WRX Wagon 5sp WRB |
![]() I was doing some research on the subaru 4pot front brake upgrade and the "infamous" 2pot rear brake upgrade.
I found some really comprehensive japanese websites that were surprisingly detailed and thought it might help others contemplating the same. Here they are in no particular order -- I used the www.babelfish.altavista.com translation service to get "some semblance" of the English. Enjoy ![]() ================================================== ======== Straight from Subaru Sti: http://www.subaru-sti.co.jp/e/GRN/tec_info/1.html ================================================== ======== A comprehensive listing of parts -- including the 2pot/4pot upgrade, as well as part numbers for sway bars, fenders, etc. etc. Also includes japanese yen prices so you can compare how much it would be (approx.) to source directly from Japan: http://www5d.biglobe.ne.jp/~N-TEC/im...econtents.html direct babelfish link: http://www.babelfish.altavista.com/b....html&lp=ja_en ================================================== ======== 4 pot / 2 pot part number listings/prices w/pictures of each part: http://homepage2.nifty.com/~legacy/m...pot-parts.html http://homepage2.nifty.com/~legacy/m...pot-parts.html direct babelfish links: http://www.babelfish.altavista.com/b....html&lp=ja_en http://www.babelfish.altavista.com/b....html&lp=ja_en ================================================== ======== Detailed, step-by-step install of 4pot / 2pot w/pictures: http://homepage2.nifty.com/~legacy/m...ot-change.html http://homepage2.nifty.com/~legacy/m...ot-change.html direct babelfish links: http://www.babelfish.altavista.com/b...ot-change.html http://www.babelfish.altavista.com/b...ot-change.html ================================================== ======== The rest I was too lazy to create direct babelfish links to them..sorry! Looks like some adapters to fit 2pot rear calipers to existing 1pot backing plate: http://www.dspeed.co.jp/hard/ EDITED FEB-07-2005 added in-line pic ![]() A hodge-podge of other interesting links (including one on how to fit aluminum A-Arms to the WRX GGA wagon) http://tatsu-u.hp.infoseek.co.jp/leg.../4pot/4pot.htm http://b4.jk.to/salvage/b4.html http://www.os.rim.or.jp/~s14/data/BH.../4pot/4pot.htm http://dng.dip.jp/impreza/alumiarm/ http://www2s.biglobe.ne.jp/~masa-nak/imp2.htm http://www3.plala.or.jp/wrc/typeM/pat/2POT.htm Hope you enjoyed them. ![]()
#2 |
Member#: 21118
![]() first link is intersting, making the Brembos fit under 15" wheels!
#3 |
Member#: 1871
Vehicle:2000 Impreza 2.5RS Blue Ridge Pearl |
![]() looks like it's a different set of brembo's, altogether
"looks like it's a different set of brembo's", said all but they give you P/N's for new rotors, calipers, some washers, springs and bolts... but one thing that would be absolutely necessary is an adapter or braket of some kind... |
#4 |
Member#: 5583
BAIC
Vehicle:96' Ver.2 Wagon White |
![]() Its the wacky wording of the translation. It is the standard subaru 4-pot (non-brembo) they are talking about (what the part number lists).
#5 | |
Member#: 5039
South East
Vehicle:2007 Outback XT Grey 5-speed (sold) |
![]() Quote:
ss |
#6 |
Member#: 14893
Vehicle:2002 Impreza WRX Silver |
![]() If somebody would market a set of rear 2 pots in black with an adapter plate to use the existing WRX backing plate, I'd buy one tomorrow!!
#7 |
Member#: 24234
VIC
![]() I don't know how exact the prices are exactly -- I gathered them from the japanese websites I posted earlier in this thread, but likely without dealer/vendor markup I'm not sure if you could actually get these prices IRL.
They also don't include taxes/shipping etc. However, the part numbers and "relative" value of different pieces will give you an idea of what parts are expensive and what parts aren't. Also, please post to the thread if you see any errors in my spreadsheet. PS - my motivation for doing this? -- I'm currently trying to fit the 4pots/2pots to my GGA wagon, but am wanting to source some of the parts via part number directly from japan -- thought it might help to post how I'm organizing my information.. Hope you find it useful ![]() Here's the spreadsheet I devised for the 4pots, extracted from the websites I posted earlier in this thread: ![]() EDITED FEB-07-2005: EDIT: "4POT PAD KIT, 26296FA100" is indeed the correct part # See notes in this reply about contents. UPDATED: FEB-07-2005 -- CONFIRMED FRONT BRAKE PAD KIT IS PART # 26296FA100 and contains all the following bits: -- 26244FA000 4POT SPACER A x 2 -- 26244FA010 4POT SPACER B x 2 -- 26232FA010 4POT PIN CLIP x 2 -- 26233FA000 4POT BRAKE SHIM A x 4 -- 26233FA010 4POT BRAKE SHIM B x 4 -- ?? 4POT BRAKE PAD x 4 IT DID NOT INCLUDE: -- 26232FA020 4POT CROSS SPRING x 2 -- 26228FA000 4POT BRAKE RETAINING PIN x 4 (which you must order separately) Here's a pic of the 4POT bits: ![]() With the exception of a brake pad (it is stacked in the picture) this is exactly what you need to fully populate ONE 4POT caliper. So you will need everything in the picture X 2 for a pair of calipers (again, assume the brake pad shown in the pic is "stacked x 2") The rough "geographical map" of parts as shown in the pic is: .....................(SHIM_A x 2)..........(SHIM_B x 2) ....(CROSS SPRING)..(PIN_CLIP)............(RETAINING_PIN X 2) ................................................(B RAKE_PAD X 2 STACKED ON EACH OTHER) .............................................(SPAC ER_B)...........................................(S PACER_A) .....................(ANTI_SQUEAL_GREASE) IMPORTANT: Note that the 4POT brake shims are indeed DIRECTIONAL as per the official JDM 4POT instructions I received from SOJ: ![]() I found installing this way -- I get silent, dependable, smooth, non-squeak/squeal operation whilst braking to a stop in the forward direction, and only a "slight squeak/squeal" going backwards. (It's not often that you brake that hard going backwards anyways). I figure if you got it the other way around -- the frontwards braking direction could be quite squeaky/squealy and could become VERY ANNOYING over time ![]() -- ONE LAST THING ![]() Make sure the 4POT calipers are installed with bleeder screws oriented towards the TOP of each caliper or else the system will be VERY DIFFICULT TO BLEED PROPERLY. Last edited by Dendrobium; 02-07-2005 at 12:54 PM. |
#8 |
Member#: 24234
VIC
![]() And here's the same done for the 2pots (which admittedly are much more involved -- the key as people have found out is the backing plates of the IMPREZA NB-R)
![]() EDITED FEB-07-2005: EDIT: "2POT PAD KIT, 26696FA000" is indeed the correct part # See notes in this reply about contents. EDIT: "SHIM A, #26635FA010" was slightly incorrect, correct part # is: "SHIM A, #26633FA000" EDIT: "SHIM B, #26633FA000" was slightly incorrect, correct part # is: "SHIM B, #26633FA010" EDIT: "OPTIONAL REAR 4POT BRAKE PARTS" should read "OPTIONAL REAR 2POT BRAKE PARTS" EDIT: "OIL SEAL, REAR AXLE, 28015AA090" is indeed the correct part #. EDIT: "REAR AXLE NUT, 2804AA000" is indeed the correct part # for WRX IMPREZA's. "REAR AXLE NUT, 902170044" seems to be more for LEGACY's. See notes in this reply for details. EDIT: "HUB NUT, 90100074" is for LEGACY's BACKING_PLATE-to-HUB attachment. "HUB NUT, 901120036" is for R160 WRX's BACKING_PLATE-to-HUB attachement. See notes in this reply for details. UPDATED: FEB-07-2005 1. CONFIRMED REAR BRAKE ROTOR DISC for R160-equipped WRX's is: PART # 26700AE030 2. Here's a pic of ALL the bits that I used for my 2POT REAR SWAP: ![]() Here's a close-up detail of all the OIL SEALS/etc. that you will need to swap the rear bearings (ie. it is not recommended to re-use the oil seals) Note the correct oil seal for IMPREZA R160 WRX's is PART #28015AA050 as I found out not PART #28015AA090) Also, note that you will need everything in the below picture PER REAR BEARING SWAPPED (so multiply everything x 2 for a pair of REAR BEARINGS) ![]() 3. CONFIRMED REAR AXLE NUT for IMPREZA WRX's is: 28044AA000 REAR AXLE NUT is for IMPREZA WRX's 902170044 REAR AXLE NUT looks like it is for LEGACY's 28044AA000 REAR AXLE NUT (PIC) If you look closely at how the hub nut is "crimped" you'll understand why you shouldn't re-use it: ![]() 4. 2POT REAR PIN-CLIP Installation -- Here's how I put the 2POT pin-clips go on -- took awhile to figure out -- but this seemed right -- (please let me know if it is wrong! ![]() ![]() 5. 2POT REAR CALIPER Bolts and BACKING PLATE bolts -- I recommend picking up a total of 12 of: 901120036 BOLT ASSY (bolt + spring lock washer) PIC Here's why: 2 for LH rear 2POT caliper (as per STi GrpN recommendation*) 2 for RH rear 2POT caliper (as per STi GrpN recommendation*) * on website: http://www.subaru-sti.co.jp/e/GRN/tec_info/1.html ...AND (I found this out while I did the install) 4 for LH backing plate-to-hub attachment (better to use new bolts here) 4 for LH backing plate-to-hub attachment (better to use new bolts here) ================================================== ==== for a total of 12. (you may want to pick up a few extra as well since this seems a common bolt) 6. CONFIRMED 2POT REAR PAD KIT PART # is: 26696FA000 2POT REAR PAD KIT ![]() AFAIK, it should contain all of the following: -- 26632FA000 2POT PIN CLIP x 2 -- 26633FA000 SHIM A x 4 (note prev #26635FA010 was slightly incorrect) -- 26633FA010 SHIM B x 4 (note prev #26633FA000 was slightly incorrect) -- 26632FA020 2POT GUIDE PLATE x 4 -- ?? 2POT REAR PAD x 4 I'm pretty sure that -- 26628FA000 2POT BRAKE RETAINING PINS x 4 -- 26632FA010 2POT CROSS SPRING x 2 need to be ordered separately from the 2POT rear brake pad kit. 7. MISCELLANEOUS NOTES -- Rear "hub carrier" was completely removed to hydraulically press out the old bearings, and put in the new ones: REAR HUB CARRIER REMOVED (pic) -- Make sure to re-use the "grommet" that covers the "parking brake adjustment port" from your original backing plates. ![]() -- Note the difference between the original backing plate (LEFT) and the new 2POT backing plate (RIGHT), both diameter-wise, and caliper mounting holes-wise (if you look closely, you'll notice that I technically didn't do a correct LHS-WITH-LHS or RHS-WITH-RHS comparison though -- sorry!) ![]() -- ONE LAST THING ![]() Make sure the 2POT calipers are installed with the bleeder screws oriented towards the TOP of each caliper or else the system will be VERY DIFFICULT TO BLEED PROPERLY. Last edited by Dendrobium; 02-07-2005 at 02:09 PM. |
#9 | |||||
Member#: 24234
VIC
![]() Here's a pic of the 4pot / 2pot calipers IRL:
![]() And finally, to dispel the mystery behind it, here's an abbreviated pictorial sequence of exactly what is meant by "pressing out the hubs" to "facilitate changing of the backing plates". I hope to do this soon -- but credit for the pics goes to the japanese websites I posted earlier ![]() ![]() cheers! UPDATED: FEB-07-2005 (some helpful hints from this thread: http://forums.nasioc.com/forums/showthread.php?t=707023 for full details) Quote:
#10 |
Member#: 7747
NESIC
Vehicle:2004 WRX 5door 5spd 08 E90 M3 |
![]() I like the idea of going with factory equipment,would a bbk from wilwood or stoptech be more cost effective and have more stopping power?
Thanks for all the helpful info and research though! Last edited by socrates42; 09-07-2004 at 06:41 AM. |
#11 | |
Member#: 29556
Vehicle:2003 WRX Wagon Midnight Black Pearl |
![]() Quote:
#12 |
Member#: 60972
BAIC
![]() This post is almost 2 months old with out an update!
Dendrobium...what's the scoop? |
#13 |
Member#: 3
South East
Vehicle:2012 Geeteeeye and 71' VW Gulf Beetle |
![]() Had to bump this for more info... what type of puller is shown in that 4th pic of them removing the hub?
I didn't think it was an option to use any hand tools to remove those. ![]() -Mike. |
#14 |
Member#: 4800
TXIC
Vehicle:1990 Legacy & OB XT AWD 6MT EJ22T AWIC Swap |
![]() It's a two jaw puller
here's a better pic http://www.surrealmirage.com/subaru/...6/DCP_3163.JPG You should be able to find them at your local parts store. I'm impressed the guy pressed out the hubs with just that little puller thing. |
#15 | |
Member#: 3
South East
![]() Quote:
-Mike. |
#16 |
Member#: 4800
TXIC
![]() He had to have used some sort of press. I suppose a bench vice might work, but you'd be better off using a press of some sorts.
#17 |
Member#: 7958
Vehicle:09 GH B+ |
![]() Gary S said he used a pretty cheap press from harbor freight to do all of his wheel bearing swaps- I don't know how cheap is cheap to Gary?
Big Sky<----------- has two pots to put on, doesn't want to pay for labor (because he's cheap ![]() |
#18 |
Member#: 10276
Vehicle:2001 Impreza RS 2002 WRX, 2012 535i |
![]() a friend of mine had a press from harbour freight. it was the $100 one. fairly easy to swap out the plates.
#19 | |
Member#: 21811
International
![]() Quote:
#20 | |
Member#: 7958
Vehicle:09 GH B+ |
![]() Quote:
I looked through their pics and they showed doing it w/ the knuckle still on- it appears they had something that fit just right and hammered the hub back on. This saves disconnecting the trailing and lateral lniks, but wondering how effective it is (ie not damaging anything)? Big Sky |
#21 |
Member#: 10276
![]() yes i pulled the hub off. to press the hub in i just used a impact socket between the press and the hub to press it in.. worked fine..
#22 | |
Member#: 7958
Vehicle:09 GH B+ |
![]() Quote:
#23 | |
Member#: 14970
BAIC
Vehicle:1997 GF8 multi |
![]() Quote:
Did I make a wrong turn somewhere? Rich |
#24 |
Member#: 78334
Vehicle:00 Impreza Turbo Silver |
![]() I want those 2pot brakes (and all auxiliaries) for my MY00 Impreza Turbo wich has now the sliding 1pot calipers at the rear.
Where can I order a set (for Belgium...) Greets Creepy |
#25 | |
Member#: 4800
TXIC
![]() Quote:
Subaru 4 pot/2 pot brakes. >800 miles. WRX/2.5rs upgade | Redneck Ricer | NESIC Private Classifieds | 23 | 11-27-2006 09:44 PM |
STI brembos VS Subaru 4 pots/2 pots | Sypher | Brakes, Steering & Suspension | 6 | 05-17-2006 06:22 PM |
Subaru 4 pot/2 pot brakes | AHadjiminas | Private 'For Sale' Classifieds | 14 | 01-07-2006 02:59 PM |
Wanted: Subaru non-brembo 4-pot/2-pot calipers | projectrally | Private 'Wanted' Classifieds | 4 | 04-28-2005 11:59 PM |
subaru 4-pot/2-pot | StarDogChampion | Brakes, Steering & Suspension | 68 | 08-30-2004 01:53 AM |
