Welcome to the North American Subaru Impreza Owners Club Sunday February 18, 2018
Old 09-11-2004, 09:02 PM   #1
stil2stock
Member#: 51870
06 STI
Default STI to WRX brake swap
Maybe a dumb question, but... is it possible to swap the STi brakes onto my 02 WRX, if, say, i found a wrecked STi in a junk yard? How involved would that be?
stil2stock is offline   Reply With Quote
Old 09-11-2004, 11:21 PM   #2
Phil Jr.
Member#: 62221
I am pretty sure the front is bolt on to the WRX as long as the rotors are from a 2004 STi. Also you will need proper 17" wheels to fit the larger brembo caliper. As for the rears there are some issues with the parking brake I believe. That being said I would'nt go ahead and just slap on STi braking gear up front an leave your rear stock. That will REALLY mess up the braking bias of the car and most likely lower your performance over stock.
Maybe someone could comment on what must be done to make the rear STi brakes fit a WRX properly. IIRC someone was making a kit so it would be possible with no fabrication on your part.
Hope that helped!
Phil Jr. is offline   Reply With Quote
Old 09-11-2004, 11:24 PM   #3
stil2stock
Member#: 51870
06 STI
Looks like i've got a bit of research to do before i attempt that ish.
Old 09-11-2004, 11:59 PM   #4
Phil Jr.
Member#: 62221
You sure do.
Keep in mind that pretty much any regular 1pot caliper can lock up a rotor....the reason people get BBKs are:
1) looks
2) endurance for fade-free performance at the track
3) better feel
BUT, if you can find a set of front/rear STI brembo/rotors for little or no $$$ then it is an awsome upgrade. Spending $1500-$2000 on the other hand for a brand new BBK seems a little silly to me.
Old 09-12-2004, 12:06 AM   #5
thesmokingman
Member#: 17751
You can do the front Brembos and match'em with a H6 rear setup to regain your brake balance. Or you can get fancy and use the rear Brembo's. spiralsmurf, though he's a lil behind, should be finishing up a kit for the rear brembos to r160 hubs soon.
Finding Brembos "for little or no $$$" is like a treasure hunt. $2000 is nothing for a good BBK. I wouldn't leave home without a good set of brakes.
thesmokingman is offline   Reply With Quote
Old 09-12-2004, 12:12 AM   #6
StevieD
Member#: 14029
You're gonna spend some $ to get this done. Considering the amount of braking actually done up rear it's not worth doing the brembo rear conversion in my opinion.
The setup should look mighty nice up front with some 17' STI rims
StevieD is offline   Reply With Quote
Old 09-12-2004, 12:19 AM   #7
thesmokingman
Member#: 17751
I've got a set with your name on 'em...
Hey Stevie, how's it man? It's been a longtime. Oh, btw I sourced a JDM Hid harness from Tokyo Subaru for 15 bucks! Turns out I have a sister-in-law out there.
Old 05-29-2005, 04:12 PM   #8
remingtonlw
Member#: 44764
2003 WRX
Default This seems too simple but...
I am a little new to the import world, but very a seasoned street-rod guy. When i have done drum to disk conversions in the past i always (mostly) used an adjustable proportioning valve. Why wont that work for the sti conversion?
LR
remingtonlw is offline   Reply With Quote
Old 05-29-2005, 08:03 PM   #9
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
you can't go wrong with taking the STi 4-pot fronts and putting them on the WRX. unless they're Brembos, i heard with Brembos you have to replace a LOT of parts in order to get them to work...
STi 4-pot in front. H-6 Legacy/Outback in the rears.
eltrouble is offline   Reply With Quote
Old 05-29-2005, 08:39 PM   #10
thesmokingman
Member#: 17751
LR
Modern ABS systems prevent simple installations of brake bias valves, especially considering these systems already have a valve in there. And since the ABS system controls the portportion of brake torque per its sensors and computer, that includes side-to-side and front-to-rear...
There's also quite a few threads. You should do a search.
Dude, you need to stop guesstimating. Brembo's are straight bolt-on for the front applications. The rears are a different thing altogether.
Old 05-29-2005, 08:44 PM   #11
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
i just heard that the Brembos require you to get a new hub, new axle, all that stuff. I'm not saying it's absolute truth, just what i heard.
or is this only true for the rears or something?
Old 05-29-2005, 09:23 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....now THIS is a great idea
Old 05-29-2005, 10:51 PM   #13
Chigliakus
Member#: 77525
'02 GDA, '09 GR
'93 FD
Anyone doing a front sti brembo swap on a wrx needs to know that the wrx bracket bolts do NOT thread into the brembo calipers (their bracket is integrated into the caliper). I had to put my wrx rotor and caliper back on until I can obtain some brembo bolts. In my research I didn't come across the fact that the brembos use different bolts, and I did read the '04 sti manual and a bunch of threads here on nabisco before starting this project. Annoying...
Chigliakus is offline   Reply With Quote
Old 07-19-2005, 12:20 AM   #14
willfong
Member#: 62031
02 S2000 for sale
Showroom condition!
Chigliakus...
Could you explain more in detail or post some pics? That would be great!
Thx.
willfong is offline   Reply With Quote
Old 09-29-2005, 02:15 AM   #15
ronf
Member#: 51034
03 WRX, 02Forester
Where to get these bolts ?
Do you need to get sti mounting brackets also ?
Planed to swap my front with Sti Brembo, but some private sellers sell only calipers and rotors only. what else are needed for swap ? Thanx
ronf is offline   Reply With Quote
Old 09-29-2005, 01:41 PM   #16
edmundu
Member#: 54672
Just order them at the dealer. They are about 2.25-3.25 ea, and you need 4. No brackets, calipers have the ears cast in. You might want to use the larger STI dustshield, it also has better airflow.
edmundu is offline   Reply With Quote
Old 10-05-2005, 01:30 PM   #17
Chigliakus
Member#: 77525
'02 GDA, '09 GR
'93 FD
I just ditched the dustshields alltogether, both front and rear. I never go off-road and I suspect I get better cooling as well. No problems with brake fade on the road course at least. YMMV
Old 10-05-2005, 07:41 PM   #18
eric94501
Member#: 61686
2004 WRX
FYI: Only get the caliper bolts from the dealer cuz the bembo torque for the STi is 100-120 lb if I remember right.
eric94501 is offline   Reply With Quote
Old 10-05-2005, 07:51 PM   #19
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
Or just buy the Brembo kit complete - $1200 for new everything pads/slotted rotors/calipers/SS lines doesn't sounf too bad compared to takeoffs of questionable condition. There's a thread in the vendor section
infantsam is offline   Reply With Quote
Old 10-05-2005, 08:16 PM   #20
Butt Dyno
Street's closed, pizza boy
Member#: 17301
17' would make the Brembos look tiny
Old 04-06-2006, 02:31 PM   #21
flwrx
Member#: 35944
'03 EJ207/30R/G4+
MBP
can anyone confirm this? in all my research, i havent heard this mentioned before. I have 04 sti calipers going on 03 wrx..didnt come with bracket bolts
flwrx is offline   Reply With Quote
Old 04-07-2006, 06:16 AM   #22
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
FWIW, and at the risk of being flamed (again) I changed out my stock 4 spotters on the front of my Aussie 02 WRX for Brembos and I did have to use the bolts that came with the Brembos. Bolt head size is larger also.
I left the rears stock and I really don't know what all the fuss is about leaving them stock. Geez, it's not like we're doing F1 or WRC you know I get no fade on the track anymore and the rear under heavy braking is so light anyway that an upgrade is not necessary IMO.
renhoek is offline   Reply With Quote
Old 04-07-2006, 12:37 PM   #23
digitalboy40
Member#: 63328
02 WRX
Blaze Yellow
I've thought about the front brembo conversion for my wrx and i've come up with 3 choices for the rear: H6 upgrade, LGT vented rear upgrade, or the rear 2-pot conversion. Oh ya, and there is a vendor on the boards selling a whole front brake setup (calipers, rotors, lines) for fairly cheap for what it is.
digitalboy40 is offline   Reply With Quote
'06 RS to WRX brake swap problem nees Brakes, Steering & Suspension 1 08-28-2007 10:10 PM
STI to WRX spoiler swap brassgurus Interior & Exterior Modification 18 07-16-2005 06:45 PM
RS to WRX brake swap piker28 Brakes, Steering & Suspension 2 06-26-2005 04:35 PM
'98 L to WRX brake swap TractionLimit Brakes, Steering & Suspension 2 01-06-2004 09:58 AM
RS to WRX brake swap "meet" Bob O Mid Atlantic Impreza Club -- MAIC 9 05-09-2003 10:08 AM
