09-25-2004, 08:41 PM | #1 |
Member#: 40200
Vehicle:2002 WRX Cobb Stage 2.5 |
Cobb Stage 2.5 VF34 Won't Hold Boost
So I was driving on the highway going to the track today and when I went to pass people and dropped it into 4th gear and gaver', my boost would go low, high, low, high, it just won't hold as it should. I think this may be related to the problem of why I can't get into the 12s as well. Any ideas?
Mods: Complete Cobb Stage 2.5 with PWR TMIC and Walbro fuel pump
09-26-2004, 09:13 AM | #2 |
Member#: 10292
Vehicle:2002 WRX Sedan Silver |
How long have you had the reflash? My 2.5 took a few weeks to learn my mods. Also, the TMIC might be the cause. The reflash doesn't call for one and usually a TMIC isn't within the "learning" ability of any reflash. All TMICs are differant as well, so no map could be universal.
09-26-2004, 12:52 PM | #3 |
Member#: 40200
had it for about 3 months now but i never really go out on the highway so i didn't really notice it till now. i've never had anything like this happen to me within the city
09-27-2004, 10:27 AM | #4 |
Member#: 24621
Vehicle:2006 Legacy GT 2015 WRX STi |
When I installed the Cobb VF34 setup I started hearing a hissing noise from the bpv area at full boost (hitting around 16.5-17psi). I tried replacing the bpv gasket but still heard the same noise. So I gave up and bought a forge bov, before the installation I went for a drive to see how much psi I was hitting that day (16.5psi). Then I installed the new bov and started hitting 18-18.5psi. So maybe you have the same problem.
09-27-2004, 04:48 PM | #5 |
Member#: 40200
just an fyi- it was the boost hose, put the cobb hose back in and everything is okay, max boost is 18.3
09-27-2004, 09:24 PM | #6 |
Member#: 10292
Cobb hose? Do you mean factory hose?
09-28-2004, 04:04 PM | #7 |
Member#: 40200
no, the cobb hose that you have to ask them for to get
How will my cobb stage 2.5 vf34 wrx run against other stuff? | brandon230573 | Proven Power Bragging | 54 | 03-31-2005 11:02 PM |
anyone have timing maps for cobbs stage 2.5 vf34 map? | blackie | Engine Management & Tuning | 0 | 03-31-2005 01:26 PM |
cobb stage 2.5 vf34 question. | blackie | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 01-20-2005 04:53 PM |
cobb stage 2.5 vf34 and port work | wrxracer55 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 10-06-2004 06:03 PM |
Clutch Slippage-cobb stage 2.5 vf34 | kedrin | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 09-22-2004 10:30 AM |
