Welcome to the North American Subaru Impreza Owners Club Thursday January 19, 2017
Old 10-02-2004, 05:44 PM   #1
airengineer
Member#: 69321
2001 Forester L
Default OK, Can I remove my PS pump? (Was "What's a good basic UDP?")
Originally Posted by Handsdown
why not just take the belts off then?
So, I thought "Why Not". Well, not take the belts off but I did try removing the alternator/PS belt to see how the car would drive. Took a quick drive around the block and backed into my driveway and garage. Takes quite a bit of effort when the car is sitting still, but is easy enough when moving even a little.
Has anyone removed their PS pump or at least re-belted so it's not in use?
If so, any downsides to handling other than forearm muscle development?
If the lines are removed and the fluid drained, does that improve the handling?
Finally, how much horsepower does the PS pump consume?
Thanks in advance,
Air
airengineer is offline   Reply With Quote
Old 10-03-2004, 12:14 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
about 2 hp at idle, at speed, absolutely nothing
Old 10-03-2004, 07:28 PM   #3
ruskiyab
Member#: 55128
2007 Impreza WRX
if you are trying to save some hp, take off the PS and the A/C compressor and all associated hardware. It wont give u much hp but it will sure as hell take off some weight
ruskiyab is offline   Reply With Quote
Old 10-03-2004, 07:37 PM   #4
nySulli
Member#: 32617
2008 STi
taking off powersteering probably won't make a huge difference, at least not enough to warrent its removal and the resulting pita you'll have to deal with all the time (trust me, had ps go out for 2 weeks in my supra, its ok the first few days, then it just pisses you off)
as for taking off the ac, yeah, someone took it off here and said it was ~22lb, without the refrigerent, which is probably a few more lb's
nySulli is offline   Reply With Quote
Old 10-03-2004, 10:36 PM   #5
airengineer
Member#: 69321
2001 Forester L
Thanks for the replies. I'll keep the PS for now. Sounds like minimal Hp gains, and I'm not looking at removing weight at this point. Just starting out and looking for things that work.
In another thread, I found a post that mentioned that the steering equipment wasn't really designed for full-manual steering so it was best to leave it on.
Thanks for your replies,
Air
Old 10-04-2004, 02:31 PM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
refridgerant is 1.43lbs so make that an even 24 for the a/c system which IMHO is NOT worth removing, buy a Alumnium hood or CF hood and alumnium or c/f trunk lid and you'd spent your money MUCH more wisely
Old 10-04-2004, 05:07 PM   #7
jeffg
Member#: 2958
2001 6.0?RS
removing the PS can make the steering feel better at speed. You wont get a real gain in HP, but handling may be improved at speed.
SCC felt a beneft with a few of their project cars after romoving the PS belt and draining the steering rack of fluid. Obviously you will lose the benefit of PS at low speed.
jeffg is offline   Reply With Quote
did my dealer damage my PS pump? culturedetox Texas Impreza Club Forum -- TXIC 123 11-05-2008 07:50 PM
did my dealer damage my PS pump? culturedetox Service & Maintenance 7 11-04-2008 10:17 AM
Can I remove the fuel pump controller??? HELP james_95 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-31-2006 12:34 PM
What's a good basic UDP? airengineer Normally Aspirated Powertrain 8 10-01-2004 07:36 PM
if i run a link ecu can i remove my tvg's STEALTH-WRX Engine Management & Tuning 3 09-07-2002 12:53 PM
