Welcome to the North American Subaru Impreza Owners Club Friday December 15, 2017
Old 10-07-2004, 03:35 PM   #1
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Default Strut failure and Proof the STi rear lsd doesnt do anything
So this weekend one of my jic coilovers snapped in two during an autox(thank God I had a double driver) and I just happened to have a cone cam mounted right behind the offending strut.
http://tyrannoracing.com/Vid/glilly.mpeg
From inside the car it just felt like a snap spin so my codriver put in in 1st and gave it some gas which resulted in absolutly nothing.
afpdl is offline   Reply With Quote
Old 10-07-2004, 03:47 PM   #2
PaulC
Member#: 12283
Still downloading the video.. but if you lost a wheel completely the LSD won't do anything. Since it's a gear-type differential it operates as a torque-multiplier, if there's no torque on one wheel you get nothing.
Edit: Just watched the video. That must make you sick watching the wheel fly out like that.
PaulC is offline   Reply With Quote
Old 10-07-2004, 03:51 PM   #3
Butt Dyno
Street's closed, pizza boy
Member#: 17301
How long had you had the coilovers? That's crazy..
john
Old 10-07-2004, 04:00 PM   #4
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
PaulC doesn't grasp the sarcasm methinks.
TyrannoSullyRex is offline   Reply With Quote
Old 10-07-2004, 04:11 PM   #5
04RedWRX
Member#: 59224
2004 Red WRX
STX Dead Money
john
Makes you kinda wonder doesn't it John?
Bruce
04RedWRX is offline   Reply With Quote
Old 10-07-2004, 04:13 PM   #6
KC
Member#: 442
17 OK Sport
00 S2000
Current discussion in Suspension Forum: http://forums.nasioc.com/forums/showthread.php?t=642564
KC is offline   Reply With Quote
Old 10-07-2004, 04:14 PM   #7
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
Oh Snap! It was a nice spin to see in person for sure
forced4 is offline   Reply With Quote
Old 10-07-2004, 04:17 PM   #8
PaulC
Member#: 12283
That is correct! Totally missed any sarcasm there.
Old 10-07-2004, 04:23 PM   #9
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Between 8-12,000 miles. Less then a year.
And yes sarcasm.
Old 10-07-2004, 04:25 PM   #10
Butt Dyno
Member#: 17301
Not really, someone broke a set of Zero2R's at nationals too, and there are tons of people autocrossing on these things. Anything is possible, but some things are unlikely enough that you can't worry about em.
john
Old 10-07-2004, 04:40 PM   #11
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
[quote=ButtDyno]Not really, someone broke a set of Zero2R's at nationals too, and there are tons of people autocrossing on these things. Anything is possible, but some things are unlikely enough that you can't worry about em.
john[quote]
Old 10-07-2004, 09:59 PM   #12
AlpineFD
Member#: 42573
2004 WRX
I've seen another STi JIC coilver fail, it was at streets of willow race way, the owner went off track, and the coilover snapped at the strut bolt mounting point.
AlpineFD is offline   Reply With Quote
Old 10-07-2004, 10:29 PM   #13
rautox
Member#: 68573
98 Italkart F125
I'm gonna go hug my teins. Yikes.
rautox is offline   Reply With Quote
Old 10-07-2004, 11:28 PM   #14
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The rear diff on the STi is a plate type, not a gear type.
If the CV joint and axle was still stuck to the bent over wheel, it could have prevented forward motion from the other side due to the LSD (revving due to clutch slip...?)
And unless the DCCD had gone into failure mode (due to loss of ABS sensor wire) then there should have been some drive from the front.
Glenn
PS any damage to the diff housing (from the axle trauma?)
ANZAC_1915 is offline   Reply With Quote
Old 10-08-2004, 02:36 AM   #15
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
I guess you guys havent seen the pics yet
http://tyrannoracing.com/images/afpdl/ they are the ones titled img_ Pay no attention to the other pics in that file.
The axel pulled completely free. Putting it in first and letting the clutch out slowly just spins the free axel, I didnt want to screw with locking the center diff or anything while the car only had 3 wheels. In the vid we only went to low revs in first, since we didnt feel any forward motion we stopped trying to get the car to move. There is no visible damage to the axel to diff area just axel to wheel.
This weekend ill get up in the air, taken apart, and see if the front is still getting power if not then Ill call it a rwd mod <<Thats sarcasm again
Old 10-08-2004, 02:40 AM   #16
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Lemme guess, rear strut?
Old 10-08-2004, 03:40 AM   #17
patr
Member#: 97
just FYI the only **possible** way to drive the car with an axle out and any amount of torque is actually to LOCK the EMCD. think about it. It heats it up, but its doing its job. Obvisouly if you keep driving the crap out of it before long, then it overheats, but you can limp pretty far like that taking care not to overheat it.
you can do it without locking it, but have to be very very gentle with the application of torque, and you have to have more lock, the more torque you apply
a generally loose auto-x setup (which most people seem to run), i.e. towards open or on auto, will almost never work with a shaft off
I'm not talking from armchair experience here.
patr is offline   Reply With Quote
Old 10-08-2004, 03:42 AM   #18
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
I would tend to agree with you, also not armchair experiance.
Old 10-08-2004, 04:55 AM   #19
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Wow, you seem really calm about this. I would have been supper pissed. Good luck.
subiekid is offline   Reply With Quote
Old 10-08-2004, 05:01 AM   #20
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
And it happened on my 21st bday too. Life goes on, no one got hurt there are worst things that could have happened. Im not happy about it but you got to make the best of what you get, and I cant stop laughing at the video. The car is getting like 6 degrees of positive camber on that run.
Old 10-08-2004, 05:41 AM   #21
MRF582
Member#: 48219
. Always drive
the race line .
wow, i know a couple people running JIC coilovers. i guess i better tell them to switch them out immediately.
haha, j/k.
MRF582 is offline   Reply With Quote
Old 10-08-2004, 10:34 AM   #22
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Duh, now I realize why auto mode wouldn't have worked.... no wheels rotating means no ABS signals means no detection of slippage.
Glenn
Old 10-08-2004, 11:59 AM   #23
Fred
Member#: 3560
00 2.5RS, 06STi
06FXT, 95rallyimpreza
You need to tell your co-driver to stop being so afraid of the cones.
Cool video, sucks about the strut failure. Amazing how you just happened to have a video camera right there when it happened.
Fred is offline   Reply With Quote
Old 10-08-2004, 12:19 PM   #24
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
That was that guy's first time ever to autocross, he's normally a show car guy and we convinced him to come out and co-drive with the owner of the (now) brokeded STI. Hell of a first time.
Old 10-08-2004, 01:20 PM   #25
Fred
Member#: 3560
00 2.5RS, 06STi
I wonder if he'll do it again?
WTB 05 STi front struts low milage and FS 05 STi rear strut 20k miles EtoS Tri-State Area Private Classifieds 0 03-05-2010 04:36 PM
Helical Front LSD, STI Rear LSD? Go or No Uber-Charged Transmission (AT/MT) & Driveline 9 03-14-2008 04:09 AM
Do you think that Jet Hot Coating the stock turbo heatshield would do anything? Schleppy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-10-2003 03:03 AM
Where can I buy the Impreza rear LSD? edkwon Transmission (AT/MT) & Driveline 8 03-04-2002 04:59 PM
All that stuff on the car that doesn't really do anything 8Complex Technical Forum Archive 19 07-11-2000 01:17 AM
