Welcome to the North American Subaru Impreza Owners Club Wednesday June 28, 2017
Old 10-10-2004, 11:34 AM   #1
GC8drifter86
Member#: 57896
Default weird sounds from motor
Ok i am getting a really strange sound from my motor when i first turn it on and when i will rev it to about 1,500rpm and drive slowly. It sounds like water being "sloshed" around. I dont no what it is. I thought it might be gasoline in the motor that wasnt burned. but i have no idea.
Also my clutch is basically gone would this have anything to do with it? and my only engine mod is exhaust
GC8drifter86 is offline   Reply With Quote
Old 10-10-2004, 01:33 PM   #2
chip4761
Member#: 55867
2005 Saabaru
AS
DON'T DRIVE YOUR CAR IT'S GOING TO EXPLODE!!
Just kidding!!
I noticed that on my car after I did some work on it with the engine out. I think it turned out to be the shroud on the the exhaust manifold making a wierd noise. From the cabin, it sounded like water going over a prop on a boat. The other thing it could be is coolant. Maybe going through the heater core?
chip4761 is offline   Reply With Quote
Old 10-10-2004, 02:37 PM   #3
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Yes it should be the coolant and heater core. I have the same thing starting my car.
If gasoline was sloshing around in the engine, you wouldn't hear the slosh. Either that or boom
-paK +2
Pakin is offline   Reply With Quote
Old 10-10-2004, 09:14 PM   #4
GC8drifter86
Member#: 57896
lol so its not gonna hurt my car? how much would it be to be fixed? could i do it myself?
Old 10-11-2004, 04:37 AM   #5
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
Mine does the same thing. I just ignore it. Man I bet you are happy. You probably thought your car was all jacked up!
RyansJDMgc8 is offline   Reply With Quote
Old 10-11-2004, 12:35 PM   #6
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
No it won't hurt your car, and since it's normal you really can't repair it unless you want to stuff some more sound deadening in between to not hear it
-paK +4
Old 10-11-2004, 01:59 PM   #7
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
ah yes. that noise. i had it on my car too. it was the ac compressor. a mechanic said it was probaboly the bearings going so i cut the belt to it and the noise went away. now i have to drive with the windows open when its hot but owell...
the noise started after one hard days use of the ac. i never used it b4 that day, but when i disabled the compressor it went away
-shaun
t3hWIT is offline   Reply With Quote
Old 10-11-2004, 04:46 PM   #8
SubyGC8
Member#: 70069
2005 Legacy GT
Satin Pearl White
Pakin is right.. Its just water in the heater core.. After the car sits and cools off the water in the heatercore drains out.. When you start the car up and the water pump moves the coolant around, the heatercore fills back up.. Thats all your hearing.. Its all natural..
SubyGC8 is offline   Reply With Quote
Old 10-11-2004, 05:27 PM   #9
GC8drifter86
Member#: 57896
ok good. now all i need is a clutch and flyhweel............ ACT or Exedy
Old 10-11-2004, 06:04 PM   #10
SubyGC8
Member#: 70069
2005 Legacy GT
Satin Pearl White
Exedy
Old 10-11-2004, 06:10 PM   #11
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Werd on Exedy, they also manufacture Subaru's OEM clutches/flywheels.
-paK +1
Old 10-11-2004, 06:47 PM   #12
Seeinstars
Member#: 31226
2000 2.5RS coupe
2004 jbp forester xt
To fix this make sure your radiator is completly toped off. The heater core gets air in it and swishes around. If you top off your radiator then it will usually fill the heater core back up.
Seeinstars is offline   Reply With Quote
Old 10-11-2004, 07:26 PM   #13
GC8drifter86
Member#: 57896
ok yea thanks seeinstars ill do that tomorrow or wednesday.
how come everyone likes exedy? I know they make Japanese OEM clutches and such but everyone ive talked to said that they shudder pretty badly even in warm conditions and it takes a lil bit to get used to
Old 10-12-2004, 09:13 AM   #14
Seeinstars
Member#: 31226
2000 2.5RS coupe
Exedy's shutter because of a defect in the pressure plate and the dealerships can replace them under warrentee if it only shutters when cold. when they shutter all the time it means the clutch has been abused and has some hot spots on it.
weird sound from turbo area under boost OneArmedScissor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-02-2003 03:29 AM
Weird Sound From Front End flent Normally Aspirated Powertrain 5 04-20-2003 10:59 PM
help: weird sound from boost gauge mrmcderm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-03-2002 12:54 PM
Weird Sound From CD Player? TinyIvan Car Audio, Video & Security 4 03-18-2002 11:45 AM
Help, more weird sounds from my baby. nightshade000 Technical Forum Archive 4 06-28-2000 12:23 AM
