Welcome to the North American Subaru Impreza Owners Club Thursday May 25, 2017
Old 06-22-2001, 11:10 AM   #1
mikemo
Member#: 7627
93 L Wagon
Blue (ish)
Question cam belt change, miles or months
Hello. I just bought a MY93 wagon (11k miles, verified). Aside from 4 oil changes and a new battery, the car has had no other maintenance. The owners manual has change intervals for all the maintenance items listed as miles OR months. It is saying that at 60k miles OR 60 months I should change the cam belt. I can see changing the fluids when they are old, but a belt?
Should I stick with the time recomendations or not worry about it for now. If I go by mileage I've got alomst 50k left before a cam belt change.
BTW, is the cam belt a difficult job?
Regards
MikeMo
mikemo is offline   Reply With Quote
Old 06-22-2001, 02:52 PM   #2
RallyKid
Member#: 2215
Change it!, Its a 93, and with 11k miles on it, I assume its been standing still ALOT, which is not good for the belt also.
The belt costs about $100, or somewhere around there ( at least for the MY99 RS it does, and its a SOHC too). But 16 valves + work time cost alot more.
The job is fairly easy, as long as your mechanically inclined.
RallyKid is offline   Reply With Quote
Old 06-22-2001, 06:45 PM   #3
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
It's no more difficult than changing the timing belt on any other vehicle. Standing isn't really that good for belts, either, so I would definitely change it.
I believe that the later 2.5 engines are interference engines, so if the belt snaps, at minimum, your valves are toast.
gavin is offline   Reply With Quote
changing the timing belt, change bearings or whole idler wheels/pulleys? NicEJ25 Service & Maintenance 15 12-28-2010 06:46 PM
Timing belt change along with cam seal and WP Vincentmoy Alaskan Impreza Club Forum -- AKIC 9 01-31-2009 03:29 PM
Cam locking tools for timing belt changes... where to rent/borrow? Buttsy Service & Maintenance 2 02-10-2008 08:56 PM
timing belt change - worried about left side cams Wagon Joe Service & Maintenance 11 10-01-2007 10:56 AM
So who changes their oil every 7500 miles or 7.5 months? bomber991 Service & Maintenance 23 10-02-2006 08:09 PM
