Welcome to the North American Subaru Impreza Owners Club Wednesday April 26, 2017
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 10-24-2004, 10:48 AM   #1
stu
Member#: 25768
35RR OFCDV3 Bugeye
Slowbaru
Default Element Hydra ??
Hey I just installed the hydra and had a few questions that I hope you guys can help me out with. First off I got the unit pretty late on friday and hooked up the map sensor and called it a night then I had to work all day on saturday so now I am going to attempt to finnish it off.
1 what is the best way to route the wide band ? through the fire wall or through the vehicle itself.
2 did you guys have to disconnnect the front 02 sensor or can I leave it in for wright now and disconect it later?
Thanks before hand for all your help, And I cant wait to get this thing up and running.
Thanks Jeff
stu is offline   Reply With Quote
Old 10-24-2004, 10:56 AM   #2
Veck
Member#: 15661
I ran my o2 cable through the firewall, I used the opening thats behind the intercooler.
I pulled the front 02 sensor and replaced it with a dead one so I would not ruin a perfectly good sensor.
Veck is offline   Reply With Quote
Old 10-24-2004, 10:58 AM   #3
stu
Member#: 25768
35RR OFCDV3 Bugeye
Slowbaru
coo thanks
Old 10-24-2004, 03:45 PM   #4
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
8cmFP Red, RA 5spd, Hydra
1) I took the easiest route and went through the shifter boot. I had a TXS Tuna and routed the wires the same way.
2) If you leave the front o2 sensor connected or disconnect it, it should not matter since its not used with the Hydra.
CK02WRX is offline   Reply With Quote
Old 10-25-2004, 03:14 PM   #5
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
I also just went through the shifter boot and used the factory rear 02 sensor bung. You may want to uninstall the front 02 as it will not be powered by the Element Hydra.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 10-25-2004, 03:41 PM   #6
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
I forgot to mention that I put the WBo2 in the stock rear location. I removed the front o2 sensor and put the rear sensor in the front bung to plug the hole.
Element Hydra + Element GT65 (coming soon)+Hydramist(even sooner)=good Numbers THE-95-STi Other Engine Management 10 10-08-2006 03:11 AM
Element Hydra + Element GT65 Turbo + Time Attack WRX = 534 HP 478 TQ! Element Tuning Proven Power Bragging 56 01-31-2006 08:28 PM
World One Track Spec STI + Element GT65 + Element Hydra = Holy *****!!! WorldOne Member's Car Gallery 122 11-11-2005 04:03 PM
Gauging interest.Element Hydra for 99RS jetfan8178 Private 'For Sale' Classifieds 0 09-16-2004 06:20 PM
Happy Day!! Element Hydra is in the car. NinosAutoAccesories Other Engine Management 11 08-26-2004 11:28 AM
