Welcome to the North American Subaru Impreza Owners Club Wednesday March 22, 2023
Old 10-29-2004, 05:04 PM   #1
blackie
Member#: 42979
03 wrx
blizzzack stage IV
Default Best spark plug gap for stage IV?
This might be a silly question but is there a recommended gap for a stage 4 wrx, or should i just set the plugs to factory specs?? also what is the factory recommended spark plus gap?? thanks, BTW im using the BKR7E's if that makes a difference.
blackie is offline   Reply With Quote
Old 10-29-2004, 05:25 PM   #2
moremaga
Member#: 12179
2002 WRX RA gears
Blk
Smile Gapping
I have a stage 4 setup and use the BKR7EIX-11 NGK Iridium plugs. I gap mine at .026. That set-up has worked well for me so far.
moremaga is offline   Reply With Quote
Old 10-30-2004, 02:12 PM   #3
fatray
Member#: 18150
2002 WRX Wagon EJ207
Velocity Red, Liberal kit
NKG Iridium BKR7EIX Stock# 2667. Good to go no gapping required.
fatray is offline   Reply With Quote
Old 10-30-2004, 02:17 PM   #4
moremaga
Member#: 12179
2002 WRX RA gears
Blk
Question Gapping
What is the stock gap on those plugs?
Old 10-30-2004, 02:42 PM   #5
fatray
Member#: 18150
I have no idea I didn't check. From what I have read (do a search) on these fourms the BKR7EIX-11 are the same as the BKR7EIX except the plug gap. The -11 are for non turbo cars, NA.
Old 10-30-2004, 03:03 PM   #6
blackie
Member#: 42979
03 wrx
blizzzack stage IV
ok well i just bought some bkr7e's should i just gap them to .026?
Old 10-30-2004, 03:20 PM   #7
Unabomber
Big Ron
Super Moderator
Member#: 18062
on car parts so PM
me b4 j00 buy
"Any larger gap suggested is wrong for a turbo app. A slightly smaller gap(.026" - .028" ) is commonly used in 'colder' plugs because of increased boost and the slightly smaller gap helps reduce spark blow-out."
-Uncle Scotty
Old 10-30-2004, 04:01 PM   #8
blackie
Member#: 42979
03 wrx
blizzzack stage IV
-Uncle Scotty
thats the answer i was waiting for
Old 10-30-2004, 04:40 PM   #9
Sports Wagon
Member#: 43081
Teh spark plug FAQ http://forums.nasioc.com/forums/show...ht=spark+plugs
I have bkr7e's gaped to .032
Sports Wagon is offline   Reply With Quote
Old 10-31-2004, 01:33 AM   #10
hotrod
Member#: 14141
2002 Impreza WRX
Default plug gap
Although I generally agree with Uncle Scotty, on these sort of things, I have to make a qualified correction to that statement.
IF your ignition system is running at its limits, and having spark blow out problems, that is a correct statement. But you can actually increase the chance of detonation by running too small of a spark gap.
The small flame kernal created by a small spark gap, increases the length of time the combustion spends in the "slow burn" phase. When a spark plug fires it creates a small spherical kernel of flame about the diameter of the spark gap. This small flame grows relatively slowly until it gets to about .100 inches in dia, (2.5 mm) Then combustion accelerates rapidly. If the spark gap is smaller than necessary to give reliable ignition at high cylinder pressures, you cause two effects. First the spark jumps before the ignition coil reaches peak voltage ( this causes a relatively weak spark) and the slow burn increases the chances of detonation.
If you run a wider gap, you get better ignition due to higher spark energies required to jump the gap, and the hotter spark does a better job or lighting off hard to ignite mixtures. There is a trade off here, as the longer spark is also prone to being blown out at high rpm when mixture turbulence is very high. The higher spark energies also stress the ignition system more so you reduce the life time of things like ignition coils and spark plug wires (on cars that use them).
In my oppinion you should run the widest spark gap that does not cause breakdown and failure of the ignition coils over time, and does not cause high speed miss at high rpm and boost. Closing down the spark gap is a low tech cure for an inadequate ignition system. The older turbocharged NA subaru's often had to close down the gap to around .029 inches or so to avoid problems.
FYI I am running more than .030 gaps on my plugs. The factory recommended turbo engine spark gap is .028 - .031 inches. The maximum gap recommended from the factory assumes the spark plug will be left in place for the recommended service interval of 30,000 miles, over which time the spark gap will grow due to spark errosion and STILL meet emissions standards.
I am running more spark gap than the factory max with no problems, but I will change the plugs every 15,000 miles or so. This is with both pump 91 premium, 100+ octane race gas, and E-85 fuel ( 85% alcohol ) and even in cold weather I have seen no starting problems.
The rule of thumb I've heard is keep opening up the gap about .002 at a time until you get a high speed miss, or see indications of spark blow out (ie the engine falls on its face at high load and loses power under high boost high load conditions)
Then back off to the previous gap.
Larry
hotrod is offline   Reply With Quote
Old 10-31-2004, 09:55 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Thanks for your input, Larry. I always like to read what you post.
I had problems at .030" and 22psi...and .028" cured it....so...all else considered the largest gap that dosen't cause issues, as you said, is better.
Old 10-31-2004, 05:51 PM   #12
blackie
Member#: 42979
03 wrx
blizzzack stage IV
uhhh..... i gapped mine to .026 is that ok or what? will it cause a problem?
Old 10-31-2004, 07:45 PM   #13
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Wow, informative post, Larry.
Blackie, go read it again, your answer is in there.
drees is offline   Reply With Quote
Old 06-10-2007, 09:18 PM   #14
slprsube04
Member#: 147486
2004 WRX
very informative. thanks. altough i dont think i have enough patience to keep pullin the plugs out and regapping. not that fun especially when you have fat hands.
slprsube04 is offline   Reply With Quote
Old 06-10-2007, 09:36 PM   #15
Sharky NRK
Member#: 29549
2003 WRX
copper bkr7e
Sharky NRK is offline   Reply With Quote
Old 06-10-2007, 09:38 PM   #16
Sharky NRK
Member#: 29549
2003 WRX
gapped at .28 they have NEVER given me issues, but I try and make sure I swap them at 10-15K intervals, its cheap insurance
Old 11-28-2007, 02:30 PM   #17
Carnage02
Member#: 123060
02 WRX and GC
gravel
I just changed mine from the stock plugs (NGK platnum) to the NGK copper. I wasn't having any problems with the stock plugs and they were gapped to .035. I put the new ones in at .030 and I THINK they are causing issues... I had a hard time starting (just once) and I got misfires on 1 and 3, and I have been smelling a little fuel... any ideas?
Carnage02 is offline   Reply With Quote
Old 11-28-2007, 04:00 PM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
...didn't put it back together right
Old 07-07-2009, 11:29 PM   #19
DrumNWReX
Member#: 99119
2006 WRX Cobb Stg. 2
OBP Clark Turner tuned!
Just curious, I changed my plugs today as is consistent with the 60k mile service. Used OEM NGK plugs, did not gap them. From what I understand, I think I did the right thing. Am I incorrect? Should I have tried to gap them? My car is completely stock. Please pm with responses, thanks
DrumNWReX is offline   Reply With Quote
Old 07-08-2009, 12:10 AM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
you did
Old 07-08-2009, 12:39 AM   #21
XanRules
Member#: 157348
I Thlammed My
Penith in the Car Door
I don't think that you'd have to gap them yourself unless you're running a pretty insane motor setup.
Pre-gapped ones are working just fine for me.
XanRules is offline   Reply With Quote
Old 07-08-2009, 08:26 AM   #22
kaisersouse
Member#: 85900
2001 Forester S
XanRules: It still doesn't hurt to check the gap IMHO. The tool is 99 cents at the automotive counter and it takes 2 seconds per plug.
kaisersouse is offline   Reply With Quote
Old 07-08-2009, 10:29 AM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
....until you destroy your iridium plugs by doing it
some plugs are VERY fragile and it is a virtual CERTANTY that you WILL destroy them if you put ANYTHING between the electrodes
been there
done that
and even knowing EXACTLY what you are doing and being careful WILL yeild destroyed plugs once in a while
BEWARE EVEN 'CHECKING' the gap on ANY iridium(or 'fine wire'type) plugs!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Old 07-08-2009, 11:30 AM   #24
kaisersouse
Member#: 85900
2001 Forester S
been there
done that
Ahh I didn't realize this. My car is to slow for fancy plugs haha.
Sorry about that folks.
Spark plug gap for hybrid motor mrchris1979 Newbies & FAQs 2 04-28-2010 05:42 PM
best spark plug gap ? IllNastyImpreza Normally Aspirated Powertrain 28 09-19-2007 06:10 PM
spark plug gap for ecutek, 20 thousand? .5mm? Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-03-2003 06:39 PM
NGK Iridium spark plug gap for WRX? Ken Levin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-27-2002 07:48 PM
spark plug gap for 98' RS SubeDonC Technical Forum Archive 1 08-08-2000 07:16 AM
