Welcome to the North American Subaru Impreza Owners Club Wednesday June 20, 2018
Old 11-26-2004, 09:02 PM   #1
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Talking happy day... 4.4 mafv, stock turbo
just one, but you've got to start somewhere! second gear, uphill highway entrance ramp.
Code:
1939	-8.3	2.3	13	0	0	  W/B 	33.6	8.6	ECU. 	0	ECU.  	2.2	 >25:1
2027	-5.9	2.4	18	0	0	  W/B 	33.6	10	ECU. 	0	ECU.  	2.3	14.87
2123	-3.2	2.5	36	0	0	  W/B 	29.6	11.4	ECU. 	0	ECU.  	2.4	14.49
2198	-1	2.6	39	0	0	  W/B 	28.5	14.3	ECU. 	0	ECU.  	2.5	14.78
2297	0.4	2.7	39	0	0	  W/B 	28.5	14.3	ECU. 	0	ECU.  	2.6	14.58
2398	1.7	2.8	54	0	0	  W/B 	25	14	ECU. 	0	1	2.6	14.58
2527	2.9	2.9	92	20	0	  W/B 	21.2	19.8	28.9	0	75	2.8	14.11
2658	4.1	3	101	30	0	  W/B 	22.1	23.9	24.2	0.5	100	2.9	13.68
2766	5.7	3.1	100	40	0	  W/B 	17.7	28.4	22	1.1	100	3.1	13.59
2957	7.8	3.4	100	50	0	  W/B 	15	37.6	18.3	2.2	100	3.3	13.42
3129	10.4	3.6	100	70	0	  W/B 	11.8	50.2	17	3.9	100	3.6	12.89
3297	13.5	3.7	100	90	0	  W/B 	11.4	59.1	16	5.1	100	3.6	12.18
3588	16.1	3.7	100	100	0	  W/B 	10.4	64	15	4.3	100	3.7	11.56
3766	18.4	3.8	100	100	0	  W/B 	12.2	69.8	15.3	3.5	100	3.8	11.23
3992	19.2	3.9	100	100	0	  W/B 	13.8	71.5	16.1	2.9	100	3.9	11.06
4278	19.2	4	101	100	0	  W/B 	13.8	75.7	16.9	2.9	100	3.9	10.96
4498	19.2	4.1	100	100	0	  W/B 	13.5	82.9	17.7	2.6	100	4	11.11
4701	19.6	4.1	100	100	0	  W/B 	14.5	83.6	18	1.7	100	4	11.02
4859	19	4.2	100	100	0	  W/B 	15.6	91.1	18	1	100	4	10.89
4945	19	4.2	101	90	0	  W/B 	12.7	92.2	18.9	0.7	100	4	10.89
5359	18	4.3	100	90	0	  W/B 	14.2	95.7	19.8	0.2	100	4	10.96
5611	17	4.3	100	90	0	  W/B 	16	93.4	20.4	0.3	100	4.1	11.02
5698	17.2	4.3	100	90	0	  W/B 	17.1	95.1	20.8	0.2	100	4.1	11.05
5963	17	4.3	100	90	0	  W/B 	17.6	93.9	22	0	100	4.1	11.05
6049	16.7	4.3	101	80	0	  W/B 	18.6	95.4	24	-0.3	100	4	10.96
6277	15.9	4.3	100	80	0	  W/B 	21.8	99.2	25.8	-0.8	100	4.1	10.86
6349	14.9	4.3	101	70	0	  W/B 	22.9	96.1	28.5	-0.7	100	4.1	10.81
6523	14.1	4.3	100	70	0	  W/B 	23.4	95.4	28.8	-0.9	100	4.1	10.76
6788	14.3	4.3	100	80	0	  W/B 	23.3	96	29.5	-0.8	100	4	10.73
6613	14.9	4.4	101	80	0	  W/B 	24	92.8	28.6	-0.9	LCM.  	4	11.24
5963	14.7	4.1	101	80	0	  W/B 	20.7	82.9	22.2	-0.8	LCM.  	3.9	19.49
5333	14.5	4.1	101	70	0	  W/B 	19.3	79.7	18	0.3	LCM.  	3.9	 >25:1
my die grinder and carbide bits will be here soon! 4.4s here i come...
ken
Old 11-26-2004, 09:19 PM   #2
crazymikie
Member#: 56321
2006 Honda El Camino
Green
You going to have your way with the exhaust manifolds?
Grinding is so relaxing....until you put a hole in your manifold. Especially when it's the last port you need to do too.
crazymikie is offline   Reply With Quote
Old 11-26-2004, 09:41 PM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
ouch! do you speak from experience, mike?
i'm going to have my way with everything i can get my tool into... ream it out nice and good.
seriously, tgvs are on borrowed time, and certainly the exhaust manifolds. depending on how the intake mani looks it may be just a gasket/port match, or something more invasive. i know there's a good solid tenth of a volt in these mods...
Old 11-27-2004, 05:01 PM   #4
quazimoto
Member#: 70395
What exactly happens when you gain a higher MAF volt value?Does this mean your turbo is flowing more CFM?I'm asuming the highest value is 5 volts?
quazimoto is offline   Reply With Quote
Old 12-16-2004, 01:09 PM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Default woohoo!!!
i like cold air...
Code:
4492	8.8	3.7	27			20.7	49.1	ECU. 	-1.5	ECU.  	3.4	12.7
4578	9.2	3.7	26			21.7	48.8	ECU. 	-1.5	ECU.  	3.4	12.5
4681	8.8	3.7	26			22.0	48.9	ECU. 	-1.5	ECU.  	3.4	12.3
4741	8.2	3.8	26			22.2	51.3	ECU. 	-1.5	ECU.  	3.5	12.2
4768	7.8	3.8	26			22.3	52.3	ECU. 	-1.5	ECU.  	3.5	12.2
4823	7.0	3.8	26			22.9	53.0	ECU. 	-1.5	ECU.  	3.5	12.1
4880	7.4	3.8	29			23.8	53.7	ECU. 	-1.5	ECU.  	3.5	12.0
5058	7.8	4.1	78	40		22.2	78.3	22.8	-0.5	27	3.8	12.2
5073	9.4	4.2	100	60		16.4	88.3	19.0	-1.0	100	4.0	11.7
5224	12.5	4.3	100	90		15.1	92.6	18.9	-1.0	100	4.0	10.9
5120	15.3	4.3	101	100		15.6	93.9	19.4	-1.2	100	4.0	10.8
5437	17.4	4.3	101	90		16.4	93.1	19.7	-1.3	100	4.0	11.0
5482	18.8	4.4	100	90		17.0	93.5	19.9	-0.9	100	4.0	11.0
5555	17.6	4.3	100	90		17.8	96.2	20.7	-0.9	100	4.0	10.9
5640	17.2	4.4	100	90		18.4	93.9	20.8	-1.0	100	4.0	10.9
5747	17.2	4.4	100	90		18.8	95.8	21.2	-1.2	100	4.0	10.9
5827	16.8	4.4	100	90		19.1	95.4	22.4	-1.7	100	4.0	10.8
6006	16.8	4.4	100	90		20.1	95.5	22.2	-2.0	100	4.0	10.7
6105	16.8	4.4	100	90		20.1	97.3	23.9	-1.8	100	4.0	10.7
6116	16.3	4.4	100	80		21.0	95.9	25.2	-1.9	100	4.0	10.8
6150	15.9	4.4	100	80		21.9	97.2	26.4	-2.2	100	4.0	10.7
6265	15.5	4.4	34			24.2	70.5	ECU. 	-1.5	LCM.  	2.9	10.7
5847	9.8	2.0	0			11.1	10.6	ECU. 	-1.5	LCM.  	2.0	12.3
5420	3.5	2.2	0			11.0	11.2	ECU. 	-1.5	LCM.  	2.1	22.5
5027	-2.8	2.5	8			20.9	23.1	ECU. 	-1.5	ECU.  	2.9	 >25:1
4357	-6.7	3.4	24			31.5	29.3	ECU. 	-1.5	ECU.  	3.2	 >25:1
4474	-3.6	3.8	25			21.0	45.5	ECU. 	-1.2	ECU.  	3.5	14.1
and another pull:
Code:
4930	0.8	4.1	49			22.3	69.2	ECU. 	-1.5	1	3.2	13.0
4975	1.2	2.3	2			42.2	10.7	ECU. 	-1.5	ECU.  	2.0	11.5
5073	-0.2	2.3	0			11.2	11.6	ECU. 	-1.5	ECU.  	2.0	11.9
4887	-2.6	2.2	0			15.0	 ---.-	ECU. 	-1.5	ECU.  	2.3	13.7
4916	-6.7	3.1	19			29.5	34.2	ECU. 	-1.5	ECU.  	3.0	14.0
4990	-6.7	3.5	19			29.5	40.5	ECU. 	-1.5	ECU.  	3.3	13.1
4916	-4.1	3.6	19			27.4	47.6	ECU. 	-1.5	ECU.  	3.4	11.6
5012	1.0	4.0	70	30		17.4	80.2	24.2	-0.9	15	3.8	11.4
5265	5.9	4.2	100	70		16.7	90.0	18.0	-1.3	100	4.0	11.3
5402	10.8	4.3	100	80		15.5	95.5	19.6	-1.3	100	4.0	10.9
5307	15.3	4.3	100	100		16.4	94.7	19.9	-1.2	100	4.0	11.1
5564	17.6	4.3	100	100		17.5	96.6	20.5	-1.1	100	4.0	11.1
5574	17.8	4.4	100	90		17.9	95.7	20.4	-1.2	100	4.0	11.1
5767	17.6	4.4	100	80		18.9	96.2	20.7	-1.2	100	4.0	11.1
5899	17.2	4.4	100	90		19.1	96.6	26.3	-1.6	100	4.0	11.0
5931	16.1	4.4	100	90		19.5	97.2	18.6	-1.5	100	4.0	10.9
5931	16.3	4.4	100	80		19.5	93.0	19.7	-1.8	100	4.0	10.8
6093	17.2	4.4	100	90		20.5	94.8	20.2	-2.0	100	4.0	10.9
6138	17.2	4.4	100	100		20.4	95.6	20.1	-1.7	100	4.0	10.9
6207	16.8	4.4	100	80		22.0	94.2	23.0	-2.5	100	4.0	10.9
6373	16.8	4.4	100	80		24.1	95.9	27.0	-2.5	100	4.0	11.0
6277	15.1	4.4	100	80		24.3	96.0	27.0	-2.7	100	4.0	11.0
6459	15.3	4.4	100	80		24.2	93.7	27.0	-2.7	100	4.0	11.1
6706	15.5	4.4	100	90		24.5	95.7	27.1	-2.3	100	4.0	11.0
6523	15.5	4.4	100	80		24.6	92.0	27.6	-2.8	100	4.0	11.0
6435	15.5	4.4	101	80		25.1	96.8	27.0	-2.6	LCM.  	4.0	11.1
5941	13.9	4.2	101	70		21.7	83.0	21.8	-1.2	LCM.  	3.9	17.2
5241	13.3	4.2	101	60		19.6	85.0	19.0	-1.1	LCM.  	3.9	 >25:1
4694	13.7	4.3	101	80		12.7	91.0	17.6	0.6	100	4.0	 >25:1
4761	15.9	4.2	100	100		14.0	84.6	18.0	-0.7	100	3.9	12.8
4775	17.4	4.2	100	100		15.4	87.1	18.0	-0.1	100	3.9	10.9
4844	18.8	4.2	100	90		13.4	89.7	18.0	-0.5	100	3.9	10.8
5035	19.6	4.2	100	100		15.1	89.7	18.0	-0.7	100	3.9	10.7
4916	18.6	4.3	100	100		15.1	91.2	18.0	-0.5	100	4.0	10.8
4975	18.8	4.2	100	100		15.7	89.8	18.0	-0.8	100	3.9	10.8
5058	19.0	4.3	99	100		11.6	93.3	18.3	-0.4	70	4.0	10.8
5020	18.8	4.2	100	100		12.3	91.3	18.1	-0.9	100	4.0	10.8
5096	18.6	4.3	100	100		13.0	92.1	18.3	-1.0	100	4.0	10.8
5128	18.6	4.3	100	90		12.6	93.9	18.6	-0.9	100	4.0	10.9
5159	18.4	4.3	100	100		14.0	89.1	14.8	-1.2	100	4.0	10.9
5249	18.4	4.3	100	100		13.9	89.0	14.9	-1.2	100	4.0	11.0
5291	19.0	4.3	100	100		14.4	91.5	14.8	-1.2	100	4.0	11.1
5350	18.6	4.3	94	100		14.9	94.1	15.5	-1.2	70	4.0	11.1
Old 12-16-2004, 06:19 PM   #6
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
lol, is that the max. the MAF reads?
PaulRex is offline   Reply With Quote
Old 12-17-2004, 09:49 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
no--iirc, it should be good up to a little over 4.8, at least as long as the utec is calculating fuel delivery. the oem ecu has a limit as to how far it's internal maps extend, at least in stock form (they can be extended with a reflash up to the theoretical max, 5v, but the other issue is that up in those ranges a tenth or even hundreth of a volt change makes a HUGE difference in indicated air mass. in other words, the resolution becomes ever more crappy.
see also: http://forums.nasioc.com/forums/showthread.php?t=423273
ken
Old 12-17-2004, 10:52 AM   #8
omahasubaru
Member#: 1594
1999 2.5 RS
2002 Legacy
Might as well take your bits to your turbo too, there is a lot to be gained by reworking it.
omahasubaru is offline   Reply With Quote
Stock turbo boost issues: few questions... dman918 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 07-08-2010 11:50 AM
04 STI Stock turbo back exhaust onesicsti Engine/Power/Exhaust 0 06-02-2010 03:12 PM
FS- 4 Stock 03 WRX rims, stock turbo Lightndattic TXIC Private Classifieds 0 04-09-2007 11:19 AM
Anyone got a stock turbo i could borrow/buy for 1 day? jefersun Texas Impreza Club Forum -- TXIC 4 01-07-2006 01:11 PM
