Tire & Wheel Forum sponsored by The Tire Rack |
12-14-2004, 09:19 PM | #1 |
Member#: 42544
Vehicle:2004 Impreza STi Blue |
steel wheels for the winter
Does anyone know where I can get a set of steel wheels for my 04' STi, say around $50 a wheel?
I' just purchased a set of Blizzaks from tire rack.. and I would like to save the $$ on a new set of rims... they are just for winter after all. I'm hoping I wont have to swap them on my stock rims... and then back again in the spring. - Ari
12-15-2004, 09:42 AM | #2 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
there are no steel wheels that will work on your STi
12-16-2004, 08:23 AM | #3 | |
Member#: 77579
Vehicle:1999 STI V. Type R 792 |
@AriAllen As for the Brembo calipers STI. If you cannot find steel rims, you might consider Brake swap as well for the winter (you can treat all the set -brakes, wheels, tires- as winter set). Then, you can use the WRX brakes and steel wheels. Try to source one from some "Subaru breakage" stock, then it would not cost much and you can have it for like 2-3 winters depends on usage, however, your summer set will have a longer life consequently. Ronin |
12-16-2004, 08:07 PM | #4 |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
doesn't really make sense to spend a few hundred dollars on new brakes to save the $70/wheel it costs to go with some Rota's or ASA's instead of 16" steelies.
Tire rack out of Steel wheels for the Season? | Soulofdarkness | Tire & Wheel | 6 | 11-01-2005 04:09 PM |
new wheels... for the winter.. | CBRDSpeedfactory | Member's Car Gallery | 43 | 02-26-2005 04:59 PM |
Good place to buy steel wheels for my Mazda for the winter? | 03WRXMA | Off-Topic | 7 | 10-07-2004 06:07 PM |
Steel Wheels for Winter | vt00rs | Brakes, Steering & Suspension | 17 | 11-01-2000 05:08 PM |
Cheap steel wheels for winter tires? | DoctorMoo | Technical Forum Archive | 6 | 07-27-2000 12:06 AM |
