Tire & Wheel Forum sponsored by The Tire Rack |
12-16-2004, 04:24 PM | #1 |
Member#: 36135
Vehicle:2005 WRX Aspen White |
Alignment Question: please help!
I just made an appointment with Sears to do an alignment and they told me that they dont have the specs for my 05 WRX yet. Shouldn't it be the same as an 04 WRX? Also, I'm lowered on Eibach Prokit springs. Is there anything I should tell them before they do it?
THANKS!
12-16-2004, 06:13 PM | #2 |
Member#: 44945
SCIC
Vehicle:06 LGT wag silver |
i have prodrives and told sears that its lowered about an inch. just tell them that. if its lowered too much they wont do it. so an inch is about as much you should say.
12-16-2004, 09:44 PM | #3 |
Member#: 15289
South East
Vehicle:02 wrx pollen silv & 07 Hyundai misfire'R'us |
you don't even need to tell them it's lowered, it shouldn't matter. The stock specs and adjustments should be the same from 04-05.
Don't let them give you the stock alignment specs, please. Just go in prepared with your own... |
12-17-2004, 12:14 AM | #4 |
Member#: 44945
SCIC
i would call sears to make sure they are willing to do the alignment to your specs. the sears by my place wouldnt even listen to me when i asked for specific camber and toe settings. liability i guess. and, hell, its sears, the alignment guy doesnt know what different settings does. he just works the machine. trust me, they suck.
12-17-2004, 05:23 PM | #5 | |
Member#: 30440
South East
Vehicle:03 WRX WR Blue |
With the springs, did you put camber bolts in the rear? Otherwise you're limited in camber adjustment in the rear. Mild street alignment might be around -1.5 front camber, -1.0 rear camber. Zero toe all around. I'm presently running a very agressive set-up with relatively stiff coilovers -- but my commute to work is about 12 miles I've got -2.25 front 1.9 rear with 1/8 toe out in the front. Razor sharp turn-in. |
12-17-2004, 11:01 PM | #6 | |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
....you should try '0' toe in front and a little toe OUT in the rear I did it like you have it for a while and I like a bit of toe out in back better |
12-18-2004, 12:06 AM | #7 | |
Member#: 44945
SCIC
12-18-2004, 01:52 AM | #8 |
Member#: 36135
crap i dont know what you guys are all talking about. I didnt even know I needed anyting else after the eibach drop.
12-18-2004, 08:35 PM | #9 | |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
Toe out in front makes the car difficult to drive on the highway - as wind gusts push the car, it is putting more weight on the leeward side of the car, causing the front leeward tire to have more pull than the front windward tire and thus it will follow wind gusts (even small ones) a lot. Also, imperfections in the flatness of the road will cause lots of difficult tracking Toe out in the rear does not have the same highway issues because as wind gusts push your car to the side, the rear tires will move the car in a direction which tends to combat the wind. Also, toe-out in the front adds some turn-in crispness but it doesn't really do anything beyond that. Toe-out in the rear will give the car more oversteering effect on turning because as you turn, the outside rear wheel will tend to track more towards the outside of the turn thus bringing the tail out a hair. You do not need to put camber bolts in the rear when you put springs in! This is a silly myth that stems from the fact that putting sedan struts on a wagon results in severe negative camber and vice versa. If anything, you would want to put the camber bolts in the front to give yourself more front camber. |
12-21-2004, 12:22 PM | #10 |
Member#: 15766
TXIC
Vehicle:torq steer=something cattlemen do after work. |
So what settings would you guys recommend with the rear toe for street use?
12-21-2004, 01:38 PM | #11 | |
Member#: 15289
South East
nick- i used camber bolts in the rear to get less negative camber because the insides of my tires were wearing faster back there. I went from -1.7 to -1.0. |
12-21-2004, 10:04 PM | #12 |
Member#: 16200
I run toe out in back...and lots of camber....and no real wear issues...but I drive a bit......mmmmm.....well...... let's say....in a spriited manner Keeps the wear a bit more even....yeah...that's it...
12-22-2004, 09:01 PM | #13 | |
Member#: 25859
South East
Vehicle:1965 MGB yellow 2008 Black Miata |
12-22-2004, 11:32 PM | #14 |
Member#: 74588
NESIC
Vehicle:07 Camry XLE /08 Honda Pilot |
Why sears for the Alignment??? Go to Mallory Kotzen or Mavis Tire. They are more reputable in my book. I've bought three sets or more tires from them an d aligned my old 97 OS when I had that. They were great.
My .02 Matt |
Another Boost Question: Please Help | klie5111 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 02-16-2005 12:41 AM |
Auto Insurance Question: Please help. | DieselClown | Off-Topic | 2 | 02-11-2004 01:50 PM |
Factory Alignment Specs, Please Help! | malaki | Brakes, Steering & Suspension | 4 | 08-20-2001 05:39 PM |
Lighting question: Please help | NJ WRX | Interior & Exterior Modification | 10 | 08-14-2001 10:41 AM |
Alignment questions, please help!! | Ben | Brakes, Steering & Suspension | 1 | 04-18-2001 09:44 AM |
