Tire & Wheel Forum sponsored by The Tire Rack |
12-17-2004, 07:20 PM | #1 |
Member#: 59563
Vehicle:2004 white WRX confused |
Auto-x alignment specs
Well im auto-x-ing on sunday and i need an alignment. I was thinking about finally messing around with the specs, I know nothing about this subject so..... id like your guys advice.....I want a more agressive alignment that will help me in the auto-x but wont unevenly ware my tires too quikly on the street, so???????
In case it matters i have 17x8 torques wraped with 225/45 azenis, Thanks, Matt
12-18-2004, 11:54 AM | #2 |
Member#: 58031
TXIC
this depends on what you have to adjust camber. If you have factory parts.. then you have to run as much camber as possible in the front.
The biggest thing is to MAKE SURE THAY YOU RUN 0 TOE ALL AROUND. This is going to dictate your tire wear. I plan on starting with -2.5F/-1.5R no toe all around. In case you are wondering, I am running TEIN Flex with pillowballs and will be putting 18x8s with at least 255s on very soon. |
Whats your alignment specs.AUTO X | Mitsu | Brakes, Steering & Suspension | 4 | 02-22-2006 03:45 PM |
Alignment specs and corner weight specs | hokiewrx | Brakes, Steering & Suspension | 8 | 03-14-2003 07:29 AM |
Auto-x alignment specs | Division By Zero | Motorsports | 17 | 11-30-2001 06:20 PM |
('93-'01) Alignment spec with 17" rims? | kkeetha | Impreza Forum | 0 | 04-15-2001 01:31 PM |
Alignment specs-for those who asked | Revision | Mid West Subaru Owners Club Forum -- MWSOC | 2 | 06-16-2000 11:52 PM |
