Tire & Wheel Forum sponsored by The Tire Rack |
12-18-2004, 05:26 PM | #1 |
Member#: 76754
Broke a lug nut stud...question for you all
So I broke one of my lug nut studs on my STi....how easy is it to replace one? Do I need any special tools that the average person might not have?
Thanks guys!!
12-18-2004, 06:40 PM | #2 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
Front or rear?
Jay |
12-18-2004, 08:07 PM | #3 |
Member#: 76754
front....driver side
12-18-2004, 08:45 PM | #4 |
Member#: 67004
SCIC
Vehicle:02 vf30 pnp wagon silver and cf |
should be a press in part like a honda hub idea from what I know.
12-18-2004, 09:08 PM | #5 |
Member#: 6178
Vehicle:98 GM67 2 whls > 4 whls |
Fix it and invest in a torque wrench to prevent this from happening again.
12-18-2004, 11:25 PM | #6 |
Member#: 61558
Vehicle:04 wrx wgn silver |
How did you do this, sorry to hear it.
12-19-2004, 01:19 PM | #7 |
Member#: 76754
I would imagine I broke it from over torquing it to begin with. I do have a torque wrench and I'm not the kind of person to tighten it til my arms hurt. Maybe I just got unlucky...who knows.
I was taking the wheel off and SNAP! |
12-20-2004, 12:37 AM | #8 |
Member#: 36495
Vehicle:2004 WRX Black Pearl |
Replace all of them w ARP studs. My buddy owns the Modified Mag STi and he had it happen to at least one stud on each wheel. He thinks it's from either aggressive driving or a shop using an airgun to put his wheels on.
12-20-2004, 11:41 PM | #9 |
Member#: 22462
SWIC
Vehicle:2001 AutoFozzyFTW SilvernBlack |
2 bolts for the calliper and its off . pull off the rotor . You will then need to line up the offending stud with a cut out in the hub (easy to see with the wheel off) I usa a 3 pound mini sledge to whack it out . Get a couple of thick washers and some anti seize . Put the new stud in coat the threads in anti seize . Put the rotor back on , then the washers , use a lugnut and some patience to pull the new stud in , should take less than an hour .
12-21-2004, 04:10 AM | #10 |
Member#: 17684
Vehicle:1989 pathfinder rusted red |
anyone have a link to the ARP studs?
12-22-2004, 02:06 PM | #11 | |
Member#: 6034
BAIC
Vehicle:2002 WRX It's Soo-BAH-roo |
Believe him when he said to use a 3 pound mini sledge. Regular hammer won't cut it. One whack with the sledge and it comes right off.
12-22-2004, 10:35 PM | #12 |
Member#: 44351
Vehicle:2004 Mitsubishi Evo 701whp 9.91@146 |
Pull the caliper and rotor off - two bolts to undo caliper from caliper bracket. Then the rotor slides right off.
I used a regular hammer, gave it a couple wacks and it came right off. Slide the new stud in, put a bunch of washers on, then put the lug nut on and start tightening. The lug nut will press against the washers and pull the stud in. Then you're done. Simple to do - took me about 1/2 hour to do all five on my front passenger side. |
12-23-2004, 10:12 AM | #13 |
Member#: 38983
SCIC
Vehicle:2004 WRX Platinum Silver |
Try this link... (at least I *think* that's what you're talking about)
http://www.scoobymods.com/forums/showthread.php?t=2591 |
OK, heres a question for you all you tuning techo's | bugeyes | Engine Management & Tuning | 8 | 03-20-2005 10:10 AM |
good question for you all, regarding moded injectors | wrx&998rduck | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 36 | 02-11-2005 10:12 PM |
Question for you all out there ? | TheNookie | Off-Topic | 3 | 01-12-2004 12:53 PM |
Questions for you all, help if possible, advice | 1stgearsyncro | New England Impreza Club Forum -- NESIC | 8 | 07-14-2003 09:45 AM |
An RS Question for you all | wrx182 | Normally Aspirated Powertrain | 2 | 02-15-2002 07:10 PM |
