Welcome to the North American Subaru Impreza Owners Club Wednesday November 22, 2017
Old 01-17-2005, 04:47 PM   #1
eric94501
Member#: 61686
2004 WRX
Default WRX stock ecu upgrade
Does anyone know if the stock WRX ecu can be upgraded and still pass smoge?
eric94501 is offline   Reply With Quote
Old 01-17-2005, 05:40 PM   #2
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Yes, Prodrive makes kits that work with the factory cats or Stage 3 provides a single, high flow cat that should pass emissions testing. I'm sure there are others out there as well. Check around. Cobb, Prodrive, Vishnu maybe, Ecutek would be good places to start.
Acostafan is offline   Reply With Quote
Old 01-17-2005, 08:54 PM   #3
eric94501
Member#: 61686
2004 WRX
Is there a way to mod my OEM ECU and still use it and still pass smog? I heard theres a way and it will increase 20hp and still pass smog.
Old 01-17-2005, 08:59 PM   #4
WRXdriver04
Member#: 72560
04 WRX (stg. II)
java black prl
as long as there are catalytic converters in the exhaust system ull pass smog... unless im mistaken.
WRXdriver04 is offline   Reply With Quote
Old 01-17-2005, 09:33 PM   #5
Acostafan
Member#: 67398
2002 Now with 100%
The key is getting a reflash that has quality engine management. Run too rich, you send your cats to an early death, run too lean, you kill cats and scorch pistons and detonate. I've talked to Prodrive and their reflash kits work with factory equipment. I'm sure Cobb has maps for their Accessports that won't kill your emissions equipment. Ecutek may have them too. Do your homework. THERE IS NO MAGIC BULLET! Good luck!
WTT: Ecu-Tek ECU For 04 WRX Stock ECU nightcrawler60 SCIC Private Classifieds 16 03-10-2010 03:45 PM
WRX stock brake upgrade? Mr. Sadface Brakes, Steering & Suspension 3 12-14-2005 04:44 AM
FS: '02 WRX Stock ECU and TXS UTEC Eraz3r Private 'For Sale' Classifieds 13 05-02-2004 02:57 PM
WRX stock ECU blkbdrx Private 'For Sale' Classifieds 9 03-02-2004 01:54 AM
WTB: 2002 WRX Stock ECU - can trade for 2003 ECU also mweinst Private 'Wanted' Classifieds 0 10-30-2003 03:20 PM
