Welcome to the North American Subaru Impreza Owners Club Tuesday October 24, 2017
Old 01-18-2005, 07:00 PM   #1
BLACKUTECSTI04
Member#: 74702
Question Need help w/ JDM Cluster on STI
I just got a JDM Cluster for an STI, i have a 2004 STI and when i installed the JDM, the lights on it dont work... the backlighting... on my stock one it was red, and this one should be green... all the gauge arrows work, the diff too. just when its night time i cant see anything... also the boost gauge, temp. heat. stuff doesn't light up either... can someone help?
BLACKUTECSTI04 is offline   Reply With Quote
Old 01-18-2005, 07:46 PM   #2
BLACKUTECSTI04
Member#: 74702
Bump!
Old 01-18-2005, 08:26 PM   #3
BLACKUTECSTI04
Member#: 74702
Bump! Help plz
Old 01-19-2005, 10:30 AM   #4
smdandb2
Member#: 70656
Old Mazda3 Hatch
Shelby Lancer #623
It sounds like you popped the illumination fuse. I would check that first.
You want to sell your stock cluster?
smdandb2 is offline   Reply With Quote
Old 01-19-2005, 03:23 PM   #5
Subahaulic
Member#: 51163
02-5 02WRXwgn &05FXT
sedona & cayenne red
Maybe it's set on dim--have you adjusted the brightness control?
Subahaulic is offline   Reply With Quote
Old 01-19-2005, 06:27 PM   #6
BLACKUTECSTI04
Member#: 74702
Default cluster
i will sel the stock sti cluster if i can fix my jdm one to work... its the wiring setup..
Old 01-19-2005, 08:27 PM   #7
smdandb2
Member#: 70656
Old Mazda3 Hatch
Shelby Lancer #623
If I had a wiring diagram, I could tell you exactly what is wrong. I am the cluster master. I've had 4 different clusters in my Ranger, including a Civic Si cluster, lol.
I am going to assume the lighting circuit is different, but what doesnt make sense is if the STi cluster is plug in play on the 02s, it should go both ways. Did you check the fuse? What happens if you hook the stock STi cluster back up?
Old 01-19-2005, 11:28 PM   #8
StevieD
Member#: 14029
I've tried a couple of the JDM ones on WRX's and they are very dim.. I have no idea why. You could check all of your fuses very quickly as a sanity check.
StevieD is offline   Reply With Quote
Old 01-19-2005, 11:59 PM   #9
smdandb2
Member#: 70656
Old Mazda3 Hatch
Shelby Lancer #623
Like I said, it should be working. If I can plug an STi cluster into my bugeye and have illumination, it should work the same on plugging a bugeye cluster into an STi.
Maybe your cluster is toast.
Old 01-20-2005, 12:41 AM   #10
smdandb2
Member#: 70656
Old Mazda3 Hatch
Shelby Lancer #623
I guess on installing a STi cluster in a bugeye, you have to whack one wire on the harness... b28. Damnit I wish I had a wiring diagram, this would be easy to figure out.
Old 01-30-2005, 11:53 PM   #11
BLACKUTECSTI04
Member#: 74702
Default Wiring Diagram
I have found the wiring diagram, and the cluster works in a 2004 wrx, but if u check this diagram out the wrx doesnt need 4 extra illumination pinouts... the only thing i dont understand is what wires i need to run to the 2 + and the 2 -.
http://www.ds1motorsports.com/cluster.html
JDM experts, need help for JDM STI V8 (EJ207) urgently! curiousgeorge2k5 Subaru Conversions 25 01-20-2016 04:05 AM
Need help w/ JDM V8 Cluster on 04 STI Rustyr6 Electrical & Lighting 4 10-03-2005 01:54 PM
Need help with AVCR install on STi ninjaboy76 Electrical & Lighting 2 09-09-2005 01:07 PM
need help -real invioce price on sti ps99115 General Community 95 07-08-2005 08:54 AM
Need help fast, what power on a JDM STI block? Roffa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 09-04-2004 06:28 PM
