Welcome to the North American Subaru Impreza Owners Club Wednesday June 28, 2017
Old 03-29-2005, 11:17 PM   #1
dropmech
Member#: 41477
2006 Tahoe that
will pull your bumper off
Default Strange CEL stuff with UTEC
I've had my UTEC in for about 6 months now. I'm running the stock map for my 02 WRX because I haven't had time to get it properly tuned. I've been noticing, for the past month or so, that the CEL will stay on longer when I start the engine now. Before, it would come on and go off normal just like the rest of the start up lights. Now it stays on for around 10 seconds or so. Does this mean that I am knocking right away on start up? Should I remove the UTEC to check for other CEL's?
Mods: turbo back, MBC, UTEC.
dropmech is offline   Reply With Quote
Old 03-30-2005, 03:07 PM   #2
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
Have you tried the stage 2 turboxs map to see if it still happens?
Neek is offline   Reply With Quote
Old 03-30-2005, 03:45 PM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
do you have it set to disable the oem cel light?
Old 03-30-2005, 06:54 PM   #4
sloppy_seconds
Member#: 79435
good point here...mine's set to disable the OEM CEL light, and now i noticed it stays on a few seconds longer when i start the car now.
--Justin
sloppy_seconds is offline   Reply With Quote
Old 03-30-2005, 06:55 PM   #5
dropmech
Member#: 41477
2006 Tahoe that
That's what it is. Thanks guys!
Old 03-30-2005, 09:47 PM   #6
2phless
Member#: 69343
1998 TransAm cnvrtbl
Doesn't that mean you have thrown codes that it is hiding, but storing so you can still check them?
2phless is offline   Reply With Quote
Old 03-30-2005, 09:53 PM   #7
dropmech
Member#: 41477
2006 Tahoe that
^^^I think i'm gonna go ahead and take it out for a week to make sure i'm not throwing any other codes. I'll just scan it with my OBDII scanner.
Old 03-30-2005, 10:08 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The above makes NO sense whatsoever.....
Old 03-30-2005, 11:46 PM   #9
2phless
Member#: 69343
Just go into user parameters and set the code CEL light function back to stock... where the CEL flashes when there is an issue. That or just scan it with the OBDII reader. The UTEC doesn't block the OBDII port. You can read through it. Heck you can reflash a COBB AP through the UTEC. I reset my codes while running down the highway. Engine on, UTEC on, AP flashed... There isn't any probelm with the electronics in your car. You probably just have an O2 code or a misfire code, and 1 UTEC setting is blocking it.
Old 03-30-2005, 11:57 PM   #10
dropmech
Member#: 41477
2006 Tahoe that
Your post makes NO sense to me. Try giving some useful input like the others, or don't even bother. Try telling me why it makes no sense.
Strange knock with UTEC stg2 cluck Engine Management & Tuning 12 08-05-2005 10:01 PM
CEL flash with utec? Knock? WRX-ERROR Engine Management & Tuning 2 07-29-2005 02:26 PM
CEL Issue with UTEC Inprogress Engine Management & Tuning 7 05-27-2005 05:49 PM
strange knock logging with UTEC.. ? samh22a Engine Management & Tuning 12 02-02-2004 07:54 PM
Strange Idle with UTEC SupaSizeFries Engine Management & Tuning 13 12-03-2003 11:34 AM
