Welcome to the North American Subaru Impreza Owners Club Monday December 11, 2017
Old 04-01-2005, 01:37 AM   #1
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
Default 2.5 swap or RA gears?
Basically, if you had a WRX w/basic bolt ons, etc & $2500, would you do a 2.5 STI shortblock swap, or install STI RA gears? This is my dilema in the near future. I will probably do one or the other............or just go with a "stage 4" setup instead,........????
Thoughts, opinion, comments?
Drews_WRX is offline   Reply With Quote
Old 04-01-2005, 01:43 AM   #2
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Stage 4 with RA gear set is big fun. The 2.5 is cool but the gears still suck. That is what makles a car fun. Gearing not power per say. 2.5 is very torquey though. Americans love their torque.
Be prepared for all kinds of opinions on this one.
ebeck is offline   Reply With Quote
Old 04-01-2005, 01:54 AM   #3
mantra1
Member#: 23568
'08 Forester STi
Shaggin' Wagon Thrice
Gears. I wish I did this mod sooner.
mantra1 is offline   Reply With Quote
Old 04-01-2005, 01:54 AM   #4
Diode663
Member#: 70325
03 Wrx Sedan
WTB Rear Lateral Links
Doesnt everyone love torque?
Diode663 is offline   Reply With Quote
Old 04-01-2005, 02:16 AM   #5
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
That's the rub, do the 2.5 and a good sized turbo and BAM! your tranny is fearing for it's life on every on ramp!
fogdor is offline   Reply With Quote
Old 04-01-2005, 02:27 AM   #6
Fusionpnoy
Member#: 43752
get the gears first, then 2.5 later if u can
Fusionpnoy is offline   Reply With Quote
Old 04-01-2005, 02:30 AM   #7
soundwave
Member#: 30370
2011 STi
White & Hyperblue
6 spd !
soundwave is offline   Reply With Quote
Old 04-01-2005, 04:27 AM   #8
garie
Member#: 26607
2002 wrx wagon
gears. I am sort of in your position or will be soon. I think gears you will get the most out of it because the difference in gearing should make for some fun driving.....do the 4.44 fd while your at it.
garie is offline   Reply With Quote
Old 04-01-2005, 04:46 AM   #9
moremaga
Member#: 12179
2002 WRX RA gears
Blk
Smile
Anyone have both?
I have RA gears and was thinking about getting a 2.5L block too. Man, how would the acceleration feel with both!
moremaga is offline   Reply With Quote
Old 04-01-2005, 04:52 AM   #10
Gundoo
Member#: 34112
i only like ot
as a friend
i'd go for the gears, i cant stand the standard ratios sometimes
Gundoo is offline   Reply With Quote
Old 04-01-2005, 06:20 AM   #11
pux888
Member#: 8356
02 STi swap
12 WRX limited
2.5 makes the ratios of the wrx very nice compared to the 2.0. plus you have a stronger block to work w/. then after the shred the gears w/ the extra 80 ft lbs or so you can worry about gears.
pux888 is offline   Reply With Quote
Old 04-01-2005, 06:21 AM   #12
kettsupp
Member#: 68891
gears... IMO your gears will go out before your motor and if the 2.0 is breaking the stock tranny imagine what a 2.5 would do.
of course it all depends on how you drive.
kettsupp is offline   Reply With Quote
Old 04-01-2005, 08:41 AM   #13
rhd
Member#: 81820
2003 WRX sedan
Sedona
how strong IS the RA gearset? i'm going to be doing some stuff to my car soon....and both of these issues have arisen to me, as well. i can't decide on 6 speed or RA....and i can't decide between 2.2, 2.34, 2.5, or bigger
rhd is offline   Reply With Quote
Old 04-01-2005, 01:26 PM   #14
samowrx
Member#: 8403
how do the gear ratios of the 5spd RA match up with the 2.5L block?
samowrx is offline   Reply With Quote
Old 04-01-2005, 01:35 PM   #15
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Everybody loves torque yes. Things to consider though.
A. Gears multiply torque. That is thier function.
B. Torque falls off after 5252 rpm. That is where smooth motors with 8K on tap pay dividends. I hit fuel cut before I hit peak power. With pump fuel.
C. I like to spin motors. I drive around at 3500rpm. I am an eye blink from 20# boost. My style is better served with 2.0. Some prefer to lug the car at 2000 rpm. The 2.5 is better in that case.
D. Gearing with less power is more fun to drive as opposed to lots of power and poor gearing. Fun to drive and excelleration are not the same btw.
A balanced 2.2 or 2.35 with a 6 speed is magic.
Old 04-01-2005, 01:36 PM   #16
Division By Zero
Member#: 7555
This is such an easy question. The 2.5L without a doubt. The gears will make it fun but the extra displacement is what will transform it. I personally like 1st, 2nd, 3rd gears in the WRX. When you've got power on tap (especially torque) it'll pull nicely. Now 4th and 5th gear, I don't want to go there
Division By Zero is offline   Reply With Quote
Old 04-01-2005, 01:43 PM   #17
Division By Zero
Member#: 7555
By the way, did I mention "no replacement for displacement" And nope, the rpm arguement won't do
Old 04-01-2005, 02:10 PM   #18
JCampbell
Member#: 25159
2015 BrAkes stop you
BrEAks make you broken
This is easy:
-2.5, built to the hilt
-enjoy at will
-'polish' the tranny gears
-'repair' with RA gearset (because you had to
-enjoy at will.
JCampbell is offline   Reply With Quote
Old 04-01-2005, 02:23 PM   #19
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
thanks so far. Basically, my budget is ~$2500 and there are really 3 options. Right now I am up,tbe,em.
If you were in my situation with that much money, would you 2.5 it, RA it, or turbo it??
thanks
Old 04-01-2005, 02:30 PM   #20
pux888
Member#: 8356
02 STi swap
12 WRX limited
id save a bit more bc you always run into unexpected costs. if you do 2.5 your barely gonna make on the block and install. then you gotta pay to tune. that will also just barely cover the gears w/ install, and if you go gears your should go ahead and upgrade the clutch. id set back and wait a while personally.
Old 04-01-2005, 02:41 PM   #21
faylix
Member#: 70184
2012 WRX STI
Definatly gears. I bet your tranny lasts a whole month with your 2.5 block and after you grenade the tranny you'll be out of money. If you do the gears your car will feel compleatly different and you'll be set to save again for a swap.
-J
faylix is offline   Reply With Quote
Old 04-01-2005, 02:45 PM   #22
clamdip
Member#: 18709
the power potential is actually pretty good on the 2.0L engine. i'd say get the RA gearset.
clamdip is offline   Reply With Quote
Old 04-01-2005, 03:29 PM   #23
perkowskiforpope
Member#: 50618
2004 Crawford S2
FPgreen PSM Wagon
2500 get a built 2.5 from crawford, than you have all sorts of good options.
perkowskiforpope is offline   Reply With Quote
Old 04-01-2005, 04:07 PM   #24
Division By Zero
Member#: 7555
I'll try again then, $1500 for the 2.5L + $300 EJ257 gasket kit/head studs etc + $500 used UTEC + $free modded stock injectors + $250 left over for something else.
Don't launch it and the tranny stays together
Old 04-01-2005, 05:07 PM   #25
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
On pump gas it matters little. High reving 2.0 or STI 2.5. Heads and valve train are the issue. Get the RA gears. You can do engine later. For the record I would like a balanced 2.35 or 2.5 even if it were balanced. In stock form is is clanky and unrefined. But you shift at 5K so who cares. It is like a pushrod motor. My style prefers 8.5-9K rpm. Stock STi block won't even get close with out shaking apart or throwing a rod. Nasty motor man. Makes tons of power though!
To each his own.
Ga 2006 wrx 2.5 engine/5sp ra gear set BARTS Engine/Power/Exhaust 17 06-14-2010 06:05 AM
Ga 2006 wrx 2.5 engine/5sp ra gear set BARTS Complete Car Part-Out 49 04-26-2010 04:06 AM
WTT 86 RX-7 For 95-01 Impreza 2.2 or 2.5 Swap and Install Karas Tri-State Area Private Classifieds 5 12-21-2009 09:00 PM
Ga 2005 sti 2.5 engine/5sp ra gear set BARTS Engine/Power/Exhaust 3 11-06-2009 07:38 PM
2.2 or 2.5 swap cindergarden Normally Aspirated Powertrain 3 09-25-2002 05:12 PM
