Welcome to the North American Subaru Impreza Owners Club Sunday May 28, 2017
Old 04-02-2005, 01:24 PM   #1
silvscorp
Member#: 28480
Default cobb tuning vs gearbox?
i guess this is some what related to the engine tuning section?
Just wondering if the cobb tuning or along with others, do those maps actually depend on what type of gears you have? Most cars I guess it was tuned with stock tranny. What if you upgrade to 6mt or RA gears? Due to closer ratio, the load on the engine will be decreased so you won't see a high psi as on stock tranny, so how would the maps (cobb 2.5 for example) effect the setup or does it even matter?
silvscorp is offline   Reply With Quote
Old 04-02-2005, 01:35 PM   #2
hyp36rmax
Member#: 24537
2006 LanEVO9 RS
SFVoltron White
wow, i thought about this as well at one point in time....
hyp36rmax is offline   Reply With Quote
Old 04-02-2005, 05:16 PM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Good question. Hopefully Clark or some other smart guy can chime in with some info. I know that Clark has tuned at least one 6MT conversion, so I would assume there are differences. As to wether this is a smart idea or not with a Cobb Stage, I'm not sure and that would probably require a call to Cobb.
Old 04-02-2005, 06:37 PM   #4
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
neanderthal blackout
try searching cobbs forum
MeetMrGlock is offline   Reply With Quote
Old 04-02-2005, 11:50 PM   #5
silvscorp
Member#: 28480
wow now here is a q that FAQ master can't answer for us!
Old 04-03-2005, 05:43 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if what you fear would happen were true, then all the cobb users would see huge boost when carrying 3 passengers up hill w/the ac on, and too little boost when say flooring the gas while going downhill.
they do not. the boost control system will adapt to the varying load.
Old 04-03-2005, 06:24 PM   #7
silvscorp
Member#: 28480
thanks for the reply. Well cobb is just one example and it uses factory boost controller. Infact I'll try contact cobb regard this issue and see what's their answer to this.
Old 04-04-2005, 01:31 AM   #8
Max Umbarger
Member#: 1112
2006 FXT
RBP
yeah, then post with a reply. good info!!!
...max
Max Umbarger is offline   Reply With Quote
Old 04-04-2005, 02:37 PM   #9
hyp36rmax
Member#: 24537
2006 LanEVO9 RS
SFVoltron White
assuming you want the power advatage in each gear im sure you would tune to maximize as per gear right?
Old 04-04-2005, 05:48 PM   #10
silvscorp
Member#: 28480
The main selling point for cobb is to get a good management for some some what safe all around setup. You can't really get the max potential out of a cobb per say. Anyways, I've called cobb and according to what they have experienced overall nothing will be changed except the faster response from closer ratio setup. The boost on 1st and 2nd might be lower due to the closer ratio (less load) but from 3-5 should be in the same range, if not differ by 3-400 rpms. Of course the power curve will shift a little to the left side.
so I guess don't have to worry about anything.
COBB Tuning Motorsports Dominates Redline Time Attack Round 4 at Auto Club Speedway! Cobb Tuning Press Releases 0 06-02-2010 01:57 PM
COBB Tuning Surgeline Weekly Tunes! STis VS Evos! 1555WHP! Cobb Tuning Proven Power Bragging 8 02-28-2010 09:06 AM
Cobb Tuning vs. Greddy wrxwagonSB Newbies & FAQs 4 09-24-2005 10:02 PM
Cobb Tuning Vs Vishnu ECU reflash BiggyTim Newbies & FAQs 15 01-21-2004 09:02 PM
Cobb Tuning VS Turbo XS Ex Con Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-13-2002 10:23 AM
