Welcome to the North American Subaru Impreza Owners Club Thursday February 20, 2020
Old 04-15-2005, 07:07 PM   #1
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Default Element Hydra + Element GT65 Turbo + Time Attack WRX = 534 HP 478 TQ!
Well what can I say it was a good day and all went smoothly on the Dynajet. I tuned the Element Time Attack WRX on VP race fuel around 30 psi and then some My egts were relatively low considering the power output so I was able to run 12.5 to 13.0:1 AFRs with egts peaking at 880C. Actually I was forced to run AFRs in the 13s as my Perrin 816cc injectors were running 100% but I’m sure the Walboro pump was also at its limit. I didn’t think I was going to max out those injectors as they are obviously very large but I think its time for some 1000cc low impedance injectors.
The car felt really good after we tested new modifications to airflow in and out of the engine so I knew it was time to hit the dyno on race fuel. It only took an hour to tweak out the race map with the new 2.14V7 Hydra software since I was able to block out large portions of the map to remove fuel and add timing.
It was a perfect day so I’ll show you the uncorrected numbers also:
Power slides at 120 mph…….Just another day in the office
You can find out more about the setup here: http://www.elementtuning.com/elementtimeattack.htm
Thanks,
Phil
Element Tuning is offline   Reply With Quote
Old 04-15-2005, 07:12 PM   #2
STi_Man
Member#: 79096
2004 Impreza WRX STi
Nice numbers Phil, looking forward to see the numbers of my Car, see you in Puerto Rico
Att Aldo
STi_Man is offline   Reply With Quote
Old 04-15-2005, 07:12 PM   #3
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
12.8 @ 112, '09 spec.B
nice power... take her to the track!
def
dug-e-fresh is offline   Reply With Quote
Old 04-15-2005, 07:14 PM   #4
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
Nice numbers! I noticed you have a fogger system. Were you spraying on this pull? Also, Are you able to fit a front strut tower bar with that turbo kit?
mrubino83 is offline   Reply With Quote
Old 04-15-2005, 07:24 PM   #5
Element Tuning
Member#: 54918
673 WHP Element
def
Thanks and I was planning to go to 7580 but it's not even open yet. LOL! I'l take it when I get back from another dyno day tomorrow.
Phil
Old 04-15-2005, 07:28 PM   #6
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Awesome #s Phil. Congrats.
SilverSurfer04STi is offline   Reply With Quote
Old 04-15-2005, 07:29 PM   #7
Element Tuning
Member#: 54918
673 WHP Element
Thanks and yes I have an NX system but it's not even hooked up. I would love to use it but I'm a little timid without knowing the rod strength. I'm waiting for someone else to try it on the stock rods first
It may just have to wait until we finish the race engine. I have it “pilled” for a 75 shot which has netted over 100 whp in the past so no doubt if the rods will hold it should make 630 whp if we have enough exhaust flow.
Phil
Old 04-15-2005, 09:14 PM   #8
Gadiel
UTEC Guru
Member#: 19290
2004 White STI
AEM Factory Trained Tuner
Congratulation
Good job
Gadiel
Gadiel is offline   Reply With Quote
Old 04-16-2005, 12:02 AM   #9
InfamousDX
Member#: 25413
Uhmm wow... can I buy trhe turbo kit already?
Old 04-16-2005, 12:36 AM   #10
WHAT
Member#: 19399
2013 LRPE M3/Touareg
Orange/Black
Damn Phil... that looks sweet!!!!
Nice job. I think you should fly out here to Hawaii and hook all those parts on my car.
WHAT is offline   Reply With Quote
Old 04-16-2005, 12:37 AM   #11
STi_Guy04
Member#: 69461
2004 WRB/Sti
11.41 @ 123mph
WoW.. So is this turbo like an in the middle of a Gt35R and a Td04R?? I would imagine that the Gt65R would be a bit bigger than a 35R.. Phil how would you compare both those turbos to the Gt65R, How`s the spool and what types of numbers would we all be lookin at if you where to do a pump gas map?
STi_Guy04 is offline   Reply With Quote
Old 04-16-2005, 12:55 AM   #12
mrubino83
Member#: 22987
Phil
AWSOME! Nice numbers, and great work with the Hydra. Hopefully we can see some 600+whp dyno graphs from you guys in the near future. Keep up the great work.
Old 04-16-2005, 03:19 AM   #13
short_travel_wrx
Member#: 84218
wow good job great nuimbers
short_travel_wrx is offline   Reply With Quote
Old 04-16-2005, 08:30 AM   #14
Element Tuning
Member#: 54918
673 WHP Element
Thanks for all the compliments. Just so you know GT65 stands for Garrret turbocharger 65 lbs. It the name of the kit and not the turbocharger itself.
Phil
Old 04-16-2005, 10:48 AM   #15
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Nice numbers Phil! Now track her again!
I guess we shall see how the same turbo reacts on a 2.0L when im ready for the tune.
-Sinclair
Need4Boost is offline   Reply With Quote
Old 04-16-2005, 01:47 PM   #16
bboy
Member#: 56468
04 Improved STI
Dirty White
Vroooom!!! I like the 300 ft-lbs of torque at 4000 RPM. It must feel like a jet.
Old 04-16-2005, 02:28 PM   #17
chibby goku
Member#: 32121
Wow! Great job!
I don't see a maf sensor. Is this something new with your hydra?
chibby goku is offline   Reply With Quote
Old 04-16-2005, 07:12 PM   #18
StealthWRX
Member#: 50175
3 Bugeyes
'11LGT '16FXT '18STi RA
WOW!!!! 534whp....*drool*
StealthWRX is offline   Reply With Quote
Old 04-16-2005, 07:35 PM   #19
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
the Hydra never demanded the use of a maf, or even supported it for that matter.
great numbers phil, can you tell us if there is anything different with this turbo and the GT35R? what a/r exhaust housing did you use, what diameter uppipe, what headers?
jared nelson is offline   Reply With Quote
Old 04-16-2005, 07:45 PM   #20
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Custom fuel rails in that thing? Hard to see from the pics.
wcbjr is offline   Reply With Quote
Old 04-16-2005, 09:42 PM   #21
rallysport02
Member#: 68978
Phil
gt35r has a 65lb compressor is that what your talking about.
rallysport02 is offline   Reply With Quote
Old 04-16-2005, 10:57 PM   #22
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
yes it is
ImprezaRSfan! is offline   Reply With Quote
Old 04-16-2005, 10:57 PM   #23
WorldOne
Member#: 22731
2002 WRB Do-Luck GDA
worldoneperformance.com
Although the GT35R may have a 65lb compressor, The turbo in his kit is not a "GT series."
WorldOne is offline   Reply With Quote
Old 04-17-2005, 01:15 AM   #24
pdare
Member#: 72225
Thats what I tried to tell Glock in the "engine build up" thread, but I guess he knows more than you and I combined.
pdare is offline   Reply With Quote
Old 04-17-2005, 01:30 AM   #25
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
Great numbers - almost 480 ft-lbs of torque.
Any idea what it would do on 91?
AntiochCali is offline   Reply With Quote
2009 wrx 298 hp 355 tq The Crowd Proven Power Bragging 72 08-03-2009 03:01 PM
05 WRX 291 hp / 316 tq snwman Proven Power Bragging 4 03-22-2008 06:47 PM
2007 WRX?!! Less HP and TQ?!?! gedlee Newbies & FAQs 2 10-18-2006 05:29 PM
Element Hydra + Element GT65 (coming soon)+Hydramist(even sooner)=good Numbers THE-95-STi Other Engine Management 10 10-08-2006 04:11 AM
What bumper on the CP Time Attack WRX? o2sys Interior & Exterior Modification 6 04-20-2006 09:53 PM
