06-11-2005, 09:53 AM | #1 |
Member#: 89011
A/C fan problem
I just got a 96 Impreza 2.2L. The air conditioning has been working fine until last night. The fan just stopped working. When I have the selector on air conditioner and turn the fan to 'on', I can hear the compressor turning on and a click from the fuse box, but nothing blowing out. I checked all the fuses...is there a relay or something I am missing? The fan doesn't work on any setting (vent/bilevel/defrost) either.
Thanks
06-11-2005, 11:53 AM | #2 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
there's a motor which runs those fans.
my guess? switch, relay or the motor just went bad. Jamie www.subiegal.com |
06-11-2005, 03:43 PM | #3 |
Member#: 89011
I dont think the motor died...every other time it happened in other cars, the fan would make noise or blow some smoke. Where are the relays located? I pulled the ones right above the fuse block under the dash, but they looked fine (dont know how to tell if one is blown). There was a red one that I couldnt get my hand in to reach...could that be it?
06-11-2005, 09:22 PM | #4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Have you tried all the fan speeds? If the fan only works on the highest speed but not on any of the lower ones it indicates a bad blower motor resistor. This should not be an expensive part and is easily replaced.
If the fan doesn't work on any speed, and the fuses are ok (check with a meter, not just visually), check for power at the motor terminals and work back from there. |
06-11-2005, 09:25 PM | #5 |
Member#: 28897
Vehicle:2004 STOLEN WRX STI Blue/Gold |
There should be a fan relay to the left of the fusebox,aluminum housing
06-12-2005, 07:38 AM | #6 |
Member#: 89011
Where is the fan motor located? I want to see if power is getting to it and work my way back. Sorry for all the questions...this is my first Subaru (I drive Jeeps usually and just use this for commuting 150 miles a day, so it gets kinda hot with no ac)
06-12-2005, 04:14 PM | #7 |
Member#: 23784
Vehicle:2005 M3 Tiag |
well not exactly sure on the wrx, but all the other cars I've ever changed a fan motor in it was under the dash right at the passenger foot well.
06-15-2005, 09:31 AM | #8 |
Member#: 89011
ok...i pulled the fan and was able to get it to work while it was out of the housing. It kept slowing and stopping, then restarting...so it looks like its shot. anyone know where to get a replacement? I looked online and saw them for about $120, but would like to see if there is a cheaper place. I'm not gonna even bother calling the stealership.
thanks |
06-16-2005, 09:04 AM | #9 |
Member#: 3148
TXIC
Vehicle:12 Ford F150 EB 00 BRP 2.5RS (again) |
1stsubaruparts.com is going to be a good bet... or you could always check you local parts stores...
I stumbled into this thread because my car did the EXACT same thing.... sucks... looks like I will be pulling the motor in the 97 degree heat today.... :grumble: !!!! |
HID harness problem or Fan problem? | Striker13 | Electrical & Lighting | 8 | 12-07-2006 01:43 PM |
AC Fan Problem | Texas Red Rex | Service & Maintenance | 1 | 06-07-2005 11:10 AM |
Weird fan problem... | loreley | General Community | 7 | 11-15-2004 04:32 PM |
main fan problems | scoobydorift | Subaru Conversions | 0 | 05-29-2004 11:55 PM |
Radiator fan problem | wrxpeed | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 03-21-2004 11:34 PM |
