06-11-2005, 10:46 PM | #1 |
Member#: 86420
Vehicle:2004 STi Silver |
CEL Misfire Codes
All of the sudden today when I started my car I had a flashing "cruise" light, and a solid CEL. The codes are 300 and 302, both referring to cylinder misfire. I don't know as much as I should about my car ... do I need to worry about these immediately? What could have caused it?
06-11-2005, 10:53 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
A solid CEL with stored misfire codes is not as critical as a flashing CEL which would indicate a real-time misfire. Still, this does mean that a problem has been detected. Your 04 is presumably still under warranty, take it in and have the dealer check it, unless you have cleared the codes in which case you should wait for them to come back and then take it in.
06-11-2005, 10:57 PM | #3 |
Member#: 86420
Cel
The light is solid, and it came on from out of nowhere, no noticeable changes in performance. I'm scared to death, because I'm sure our warranty is void at this point, and I'm scared to even drive it to a shop. What is a cylinder misfire? Is there any way to tell if this has really happened?
06-11-2005, 11:09 PM | #4 |
Trust no one
Why do you think your warranty is "void"? Presumably you have some mods? It can't be totally "voided", but individual claims may be denied if the dealer feels your mods were a cause or contributing factor to the problem.
You don't have to be scared to drive the car as long as the CEL isn't flashing. When it's solid it means the ECU has detected a misfire event at some point for the cylinder(s) indicated. This can happen randomly sometimes and may not be anything serious as long as it does not recur once cleared. Now, should the light begin flashing, this means that a misfire is happening RIGHT NOW, and you should not drive the car any further than is necessary because damage to the catalytic converters can result from unburned fuel. Possible causes of misfires- plugs, bad coil pack (usually this will cause codes to be set for only the one cylinder affected), bad gas, cylinder problems (bad rings/valves, low compression). |
06-11-2005, 11:11 PM | #5 |
Member#: 86420
OK thanks, maybe I'll take it to the dealer on monday. I'll have my husband check the plugs, I'm assuming he'd be able to tell if they're bad. I appreciate your help. I'm just scared because I can't afford a serious problem right now.
06-11-2005, 11:22 PM | #6 |
Trust no one
The plugs are not that easy to get to, if you're going to be taking it in anyway don't bother. As long as the dealer is willing to address this under warranty they'll probably take the plugs out among other things.
CEL and rough at startup: Misfire Code P0301 | bjteel | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 09-24-2009 05:19 PM |
TGV codes and misfire code upon start up | eliezerrosario | Service & Maintenance | 3 | 07-03-2009 05:27 PM |
CEL Misfire code D 03 | surith | Service & Maintenance | 2 | 10-18-2006 06:49 PM |
awesome! my CEL was a misfire code!!!! | Handsdown | Off-Topic | 21 | 10-10-2004 09:32 PM |
random misfire code #4/cel 0304 | harvey oh | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 05-29-2004 07:23 PM |
