Welcome to the North American Subaru Impreza Owners Club Thursday July 27, 2017
Closed Thread
Old 06-12-2005, 03:29 PM   #1
EdsWRX
Member#: 13881
08 spec b
07 335xi
Default Help with my window
I took apart my doors again today to finish adding dynamat and ensulite to the outer skins, when I went to put everything back jsut now, I noticed my passenger window was not working, from either switch, driver ans passenger switch. The power locks on both sides work, as well as the passenger rear view mirror. How can I troubleshoot this, I didn't do any wiring or anything so I don't think I shorted anything out, is there anyway I can test it out myself to find where the problem is?
Thanks
EdsWRX is offline
Old 06-12-2005, 03:53 PM   #2
EdsWRX
Member#: 13881
08 spec b
07 335xi
never mind, fixed it, accidently cut the ground for the motor
EdsWRX is offline
Old 06-12-2005, 03:53 PM   #3
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Wirelessly posted (Treo 600: Mozilla/4.0 (compatible; MSIE 6.0; Windows 95; PalmSource; Blazer 3.0) 16;160x160)
Did you check the fuses? I do know that Subaru recomends that you disconnect the battery before you disconnect the harnesses on the door switches. I believe the driver-side switches are the master control for all of the doors. If the fuse is intact, try checking the that the harnesses on the driver side door switches haven't comee loose. if everything checks out, you may also want to use a multimeter to test the powerblock and the current going into the driver side harness.
chrisarella is offline
Closed Thread
help me with my window? BbugWag Service & Maintenance 13 04-24-2010 10:42 PM
need help with power window part iluvdrt Interior & Exterior Modification 0 09-24-2009 05:13 PM
Need help with some windows "issues". jacobsen1 Off-Topic 11 11-08-2007 09:01 PM
Help With My Windows JohnyS Vancouver Impreza Club Forum -- VIC 6 09-27-2003 06:35 PM
Problems with my window Jonn Interior & Exterior Modification 4 11-10-2002 09:50 PM
