06-13-2005, 03:41 PM | #1 |
Member#: 73542
Vehicle:2005 WRX Wagon Crystal Gray Metallic |
What does the 10,000 mile maintenance include?
My dealer is calling me about getting the 10k mile mainenance done, so i am curious what about what is included, and do you think that it is worth whatever they are charging?
Thanks
06-13-2005, 04:20 PM | #2 |
Member#: 67398
South East
Vehicle:2002 Now with 100% RDA of 2.5l Goodness!!! |
Why don't you ask him? Or check your owner's manual?
06-13-2005, 04:33 PM | #3 |
Member#: 33410
Vehicle:08 wrx dgm |
according to my 03 manual the 12k mile service (no 10k for my car) involved tire rotation and oil/filter change.
what is the dealer telling you is neccesary and how much are they trying to charge? |
06-13-2005, 04:56 PM | #4 |
Member#: 73542
I looked at the manual and only saw a 12k as well, that is my reason for questioning... Just seeing if anyone else got a call.
Thanks |
06-13-2005, 04:57 PM | #5 |
Member#: 74215
SCIC
Vehicle:2007 987 Silver-ish |
I just went in for the 15K maintanence and be careful about what the dealer tells you. On the list they gave me it was a bunch of check this and check that (most of which had nothing about replacing parts in it) then all the way at the end they had another item that said check and inspect car.... at this point I turned to the dealer and said "isnt this what the previouse points are for anyway?" .... 190 bux down the drain because I want some BS dealer papers that said I maintained the vehicle through the dealer (mostly for resale value). But I am really debating if it is worth taking a hit on the car at resale or speding more money for dealer papers.
06-13-2005, 05:55 PM | #6 |
Member#: 73542
Yeah, that's what I figured, some BS way for them to make an extra buck. And I am not totally confident in the dealerships garadge. I have yet for them to fix an issue the first time I have taken the car in...
06-13-2005, 07:05 PM | #7 |
Member#: 79493
SCIC
Vehicle:2003 WRB WRX Wagon 5 doors > 4 doors |
don't ever take your car to the dealerships for basic maintenance work. you save yourself a WHOLE lot of money just by doing it yourself (plus it's fun).
If you take your car in, they'll most likely throw it to the 18 year old kid working the lube rack, and I do not trust guys fresh out of high school with my car. |
06-13-2005, 07:46 PM | #8 | |
Member#: 21392
Vehicle:2018 E63S AMG MB Black/MB |
06-13-2005, 08:07 PM | #9 |
Member#: 56297
Vehicle:2013 Focus ST 2004 STi MSPT Tuned |
my dealer doesnt have a 10,000 mile service but they do have 7,500 and 15,000 service....
3,000 Miles or 3 Months Change Oil & Oil Filter Check & Adjust Belts Check & Tighten Hoses Check & Adjust All Fluid Levels Check & Adjust Tire PressureOperation Test A/C Operation Check Operation of Power Windows Door Locks & Mirrors Check Operation of Interior & Exterior Lights Check Windshield Washer Operation Road Test 7,500 Miles or 7 1/2 Months, Repeated at 22,500 - 37,500 - 52,500 - 67,500 - 82,500 - 97,500 Change Oil & Oil Filter Inspect & Adjust Belts Inspect & Tighten Hoses Check & Adjust All Fluid Levels Service Battery & Check Charging System Inspect Axels & Axle Boots Check Windshield Washer Operation Check Tire Condition Check Tire Pressure & Adjust as Needed Check ABS Operation Inspect Front & Rear Brakes Adjust Cluth Freeplay as Needed Adjust Hillholder as Needed Inspect Exhaust System Balance 2 Front Wheels Check Sunroof Operation Road Test 15,000 Miles or 15 Months, Repeated at 45,000 - 75,000 Change Oil & Oil Filter Inspect & Adjust Belts Inspect & Tighten Hoses Check & Adjust All Fluid Levels Service Battery & Check Charging System Test Windshield Washer Operation Inspect Parking Brake Operation Replace Spark Plugs Replace Air Filter Inspect Axels & Axle Boots Test A/C Operation & Temperature 4 Wheel Tire Rotation Balance All 4 Wheels Check Tire Condition Check Sunroof Operation Inspect Steering & Suspension Check & Adjust Tire Pressure Check & Adjust Rear Brakes as Needed Inspect Front & Rear Brakes Visual Check Wheel Alignment Inspect Exhaust System Replace PCV Replace Fuel Filter Inspect Cooling System Test All Exterior Lights Check ABS Operation Road Test Check Wiper Blades 30,000 Miles or 30 Months, Repeated at 60,000 - 90,000 Change Oil & Oil Filter Inspect & Adjust Belts Inspect & Tighten Hoses Check & Adjust All Fluid Levels Inspect Front & Rear Brakes Service Battery & Check Charging System Check Windshield Washer Operation Visual Check Wheel Alignment Replace Spark Plugs Replace Air Filter Replace Ingnition Wires Replace Coolant Inspect Axels & Axle Boots Test A/C Operation & Temperature Check Sunroof Operation Check Tire Condition 4 Wheel Tire Rotation Balance All 4 Wheels Check & Adjust Tire Pressure Inspect Steering & Suspension Check & Adjust Rear Brakes as Needed Inspect Parking Brake Operation Replace PCV Replace Fuel Filter Replace Transmission Fluid Replace Gear Oil & Filter Test Heater Operation Check Cooling System Check All Exterior Lights Road Test Check Wiper Blades |
06-13-2005, 09:07 PM | #10 |
Member#: 78539
Vehicle:2005 Subaru STi K&N Typhoon HKS CarbonTi |
you dont need nething cept oil and filters till 30 it says in manual i think.
all they care about is the road test. |
06-14-2005, 03:29 PM | #11 | |
RIP 1/19/64 - 7/23/11
Scooby Guru Member#: 24654
NESIC
Vehicle:1957 Taggart Comet atlasshruggedpart1.com |
06-14-2005, 03:31 PM | #12 | |
Member#: 79493
SCIC
06-14-2005, 03:46 PM | #13 | |
Member#: 80670
06-15-2005, 04:07 PM | #14 |
Member#: 49238
Vehicle:2004 WRX WR Blue |
dunno the guys at Subaru dealers work on WRX's all the time, you'd think tearing it up during the road test portion would get a little old after awhile, now the dumbass at jiffylube or walmart definately.
06-15-2005, 04:47 PM | #15 | |
Member#: 79493
SCIC
Trip to the Top. My Bugeyes 10,000 mile Birthday | trex616 | Member's Car Gallery | 50 | 06-21-2009 10:56 PM |
The 10,000 Mile Mark. | iRace559 | Member's Car Gallery | 26 | 08-11-2008 07:21 PM |
The "Can I do the 45,000 mile maintenance myself?" thread | bomber991 | Service & Maintenance | 6 | 02-18-2007 11:11 PM |
The Ultimate WRX Break-In: 10,000 miles, 33 days, 27 states | CasWRX | General Community | 38 | 01-11-2004 01:22 PM |
Question about different types of oil and the 10,000 mile checkup | bambams247 | Service & Maintenance | 0 | 08-29-2003 03:07 AM |
