06-13-2005, 08:50 PM | #1 |
Member#: 28747
VIC
Vehicle:06 WRX |
How much oil do YOU put in?
I have a 2003 impreza TS (2.5L non-turbo engine).
According to the manual the engine calls for 4L of engine oil per change...... What I am currious is if this value includes a oil filter change also? (as my toyota quotes 2 different oil capacities, one with the oil filter and one without). Anyhow, for the longest time i've just been changing the oil and dumping "blindly" 4L of oil into the engine. I change it every 5000km and when I come time to drain it I get very close to 4L of oil back out (prob loose 1/8 - 1/4 of a liter). Well, today I decided to run the car for few mins (2-3 mins) and check the oil after the oil change and noticed something... the oil level is right in the middle of the full and empty line. I just want check if this is normal and if I shoudl add a "tad" more oil into the engine to bring it up to full...... Most of my other vehicals (a ford and toyota) will bring the oil level up to the full mark when you add the "specified" amount of oil in.
06-13-2005, 09:29 PM | #2 |
Member#: 17315
International
Vehicle:MY95 Impreza 207C MY05 Forester 257X |
With an oil filter change, it's more like 4.2 to 4.5 depending on how long you let it drain. Should get you faily in between the marks.
-paK +4 |
06-13-2005, 09:34 PM | #3 |
Member#: 35490
Vehicle:97 Impreza 2.2l slow. |
my97 ej22
i put 4.25 qts. |
06-13-2005, 09:44 PM | #4 | |
Member#: 34670
South East
Vehicle:2016 slowmobile |
How much nuts should you put in your mouth each day? | Sephro | Off-Topic | 17 | 02-13-2007 02:35 PM |
How much oil do i put in?? | SickAW02 | Service & Maintenance | 17 | 01-03-2006 09:11 PM |
How much change do you have in that bottle? | PoopRSkupe | Off-Topic | 17 | 01-10-2005 03:50 PM |
How much thought do you put into gifts? | Brady | Off-Topic | 9 | 03-19-2004 01:16 PM |
what kind of oil do you put in your wrx? | scoobypuff | Southern California Impreza Club Forum -- SCIC | 10 | 04-27-2002 12:59 PM |
