06-14-2005, 03:12 PM | #1 |
Member#: 53975
South East
Vehicle:2004 Forester XT Java Black Pearl |
Coolant Changing Drain Valve
Please help me out here. I have been trying to get the darn drain valve open for over an hour. It is really frustrating me. The thing just won't budge no matter what I try! Thank you!!!
06-14-2005, 04:07 PM | #2 |
Member#: 34436
SWIC
Vehicle:2018 Jeep Wrangler |
I used a pair of pliers and got it open without too much difficulty.
06-14-2005, 04:40 PM | #3 |
Member#: 53975
South East
thanks but mine is at such an angle i cant use pliars on them?
06-14-2005, 04:42 PM | #4 |
Member#: 79493
SCIC
Vehicle:2003 WRB WRX Wagon 5 doors > 4 doors |
you can't get pliers on them?! it shouldn't be that difficult at all....
wait...you did remove the splash shield right? |
06-14-2005, 04:44 PM | #5 |
Member#: 53975
South East
lol yeah its all off, i have the intercooler off, the spark plugs out, the gbods off and cant get this darn thing turned so i can replace my hoses and turbo w/o a mess. The angle is such that if i got pliars on them i could only turn it to tighten it there would be no room to turn it to loosen it. in order to get pliars on it so i could turn it the right way id have the come from behind and i cant do that. this really stinks, the little things always get me, argh. Thanks for the help.
06-14-2005, 04:46 PM | #6 |
Member#: 79493
SCIC
whoah you got a lot of stuff off...well anyways. try to wiggle the plier back and forth when it's on the drain valve, that might break it loose.
06-14-2005, 04:48 PM | #7 |
Member#: 53975
South East
good idea, its worth a shot... i mean it seems like i must be messing with the wrong part, but what i am looking at looks like all pics/diagrams/descriptions ive seen
06-14-2005, 04:49 PM | #8 |
Member#: 79493
SCIC
go ahead and give it a shot, oh and place a plastic hose or something to guide the coolant into the drain pain, that stuff splashes all over the place.
06-14-2005, 04:56 PM | #9 |
Member#: 53975
South East
Well i can move it clockwise, but not get it lose enough to be able to move it counter-clockwise once i cant use the pliers anymore. Also, i place a hose on the little opening or the big one or both? I got all that stuff off but now its been a good 3 hours of trying to loosen this darn thing, man what a day.
06-14-2005, 06:35 PM | #10 |
Member#: 53975
South East
it does go counter-clockwise right? lol
06-14-2005, 06:51 PM | #11 |
Member#: 53975
South East
if i never get this to work, what lese can I do? If I take off only the upper hose and the turbo, will it be a disaster? I really don't need to flush/drain the entire system just to change the hoses and the turbo. I had a friend help me in the last hour and we still couldn't get the valve to turn.
06-14-2005, 07:49 PM | #12 |
Big Ron
Super Moderator Member#: 18062
Remove the lower radiator hose where it meets the thermostat housing. That's a real pain to do as well and I have a permanent lower radiator hose removal scar on my right wrist as a battle scar.
06-14-2005, 07:59 PM | #13 | |
Member#: 79493
SCIC
06-14-2005, 11:01 PM | #14 |
Member#: 53975
South East
Yeah how are you supposed to remove the lower hose when the head of the clamp screw is facing up and is blocked from the top? Should I destroy the hose before it destroys me?
06-14-2005, 11:36 PM | #15 |
Member#: 34436
SWIC
or just put everything back together and get it done at the dealer for $30, less if you supply your own coolant and conditioner.
06-14-2005, 11:49 PM | #16 | |
Member#: 17315
International
Vehicle:MY95 Impreza 207C MY05 Forester 257X |
After you loosen the clamp, twist the hose around the T-stat housing to free it loose, and pull off in the same motion firmly, but steadily. I've had my fair share of scars, but it's quite miniscule compared to others. By now, it's almost as easy as filling the washer fluid reservoir, other than a little bit of contortionist moves -paK +4 |
06-15-2005, 01:58 AM | #17 |
Member#: 53975
South East
Man I can't believe how ridiculous this is, I am definitely not going to put it all back together lol. I think I will just do the upper hose and turbo and then top off the fluid. Then after its all said and done take it to a shop to get the bottom one loosened and the coolant done. I just can't believe that something so stupid is such a problem, man its crazy. BTW the bottom hoses clamp is definitely facing up, idk why/how it got that way cause i have never touched it, but it is definitely inaccessible. Thanks for the help, more advice is still appreciated.
06-15-2005, 08:52 AM | #18 |
Member#: 11808
I used a very small crescent wrench and open the jaws to straddle the valve ears. took acouple of 10 degree moves but worked great. Ed
06-15-2005, 04:45 PM | #19 |
Member#: 53975
South East
I'll have to try that, I just bought a small crescent wrench for this purpose anyway lol. I heard from a guy at the store though that there are sockets made for wingbuts which may be what I need. Thanks and keep it coming :-)
06-17-2005, 07:55 AM | #20 |
Member#: 26607
Vehicle:2002 wrx wagon |
yup...this took me forever and killed my hands. There is even less room to work with, with my borla headers too....i think.
06-17-2005, 10:19 PM | #21 |
Member#: 52569
Vehicle:2004 STi |
when i changed mine i used an 11/16 in. socket and it fit right over the plug, then i just ratcheted it off.
'04 coolant drain valve? | geoffpac | Service & Maintenance | 8 | 04-10-2010 01:57 PM |
quick coolant change question after reading coolant faq | roccer | Service & Maintenance | 7 | 10-20-2009 07:27 PM |
Fujimoto oil drain valve and oil change questions | ps99115 | Newbies & FAQs | 38 | 10-14-2005 08:14 AM |
3 day sale: JDM Fumoto Engine Oil Drain Valves for QUICK oil changes | King Of Imports | Engine/Power/Exhaust | 15 | 05-31-2005 10:43 AM |
Coolant Drain Valve Leaking... | mikebike357 | Forester Forum | 3 | 03-07-2005 09:43 AM |
