06-15-2005, 02:11 PM | #1 |
Member#: 89289
Vehicle:1994 sentra se-r(egg sapphire blue |
uninstalling and installing spark plugs for the first time
I need some help....this is my friends first subie and he has a 02 wrx, he has modded it, but he needs to chnge his plugs as for they're time is up...and neither of us are familiar with the individual coil packs and plugs setup.....can someone give me instructions so we can get through this install....and also which plug is recomended for the wrx....he's running 2or 3 psi over factory and has a full exhaust boost controller and the upgrade ecu....thanx.
06-15-2005, 02:16 PM | #2 |
Member#: 61845
RMIC
Vehicle:MY06 Legacy GT 5MT Regal Blue Pearl |
Get some NGK's I like them in my RS. Make sure you gap them first, and don't put them in backwards (in reference to title).
David |
06-15-2005, 02:30 PM | #3 |
Member#: 50082
Vehicle:02 wrx cobbstage 2 mbp |
its pretty easy... scoobymods has a good write up i believe
06-15-2005, 02:33 PM | #4 |
Member#: 50082
http://www.scoobymods.com/forums/showthread.php?t=3017
the swivel head socket works wonders and youll need some extensions.. |
06-15-2005, 02:39 PM | #5 |
Member#: 61845
RMIC
Deebo's right. Check out the thread he posted. I believe there's a list of tools you'll need for the replacement too. Deifinitely get an extension, too. I think the one I used was 6".
David |
06-15-2005, 02:44 PM | #6 | |
Member#: 53856
NESIC
Vehicle:2012 Speed3 Red Mica |
06-15-2005, 02:55 PM | #7 | |
Member#: 68516
NWIC
Vehicle:2019 YOTA TRD BLK R.I.P. MasterTuned© |
ALWAYS CHECK!! |
06-15-2005, 04:09 PM | #8 | |
Member#: 82197
Vehicle:03 WRX Aspen White |
06-15-2005, 04:27 PM | #9 |
Member#: 79621
Vehicle:Bug Waggy 3.0 PNP |
Check unabombers manifesto >>> Spark plug FAQs. It discusses in detail the types of plugs and their application. 1 step colder iridium might be a good why to fly based on his mods.
07-01-2005, 12:34 PM | #10 |
Member#: 90156
NWIC
Vehicle:1986 Syncro Vanaru 07 SV650 |
I had to remove the air cleaner box and the windshield wiper liquid tank to get at the cylinders. After that it was pretty easy, it would have been a lot easier if the car was cold as it is kind of a squeeze for your hands. Just take your time and use anti seize on the threads and dielectric on the wiring connections.
Installing clutch and tranny for the first time.... | JeffrWRX | Transmission (AT/MT) & Driveline | 0 | 07-16-2008 05:22 PM |
Spark plugs at the same time as injectors? | WRXislander | Newbies & FAQs | 4 | 05-18-2008 08:45 PM |
Which Engine Oil and Spark Plugs for the TRACK ??? | george3 | Motorsports | 25 | 01-10-2008 08:59 AM |
Good god! What did you guys do to get the oil drain plug off the first time? | DVN428 | Newbies & FAQs | 27 | 05-02-2003 03:24 PM |
Turbo'd scoobies: problems you came when installing for the first time | DoctorNick | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 02-14-2002 09:19 PM |
