06-15-2005, 03:06 PM | #1 |
Member#: 67355
NESIC
Vehicle:2005 Audi S4 2004 GSXR600 |
screwed up oil change
Brought my car to a garage I always go to for an oil change today. I run synthetic and told them but the mechanic didnt read the slip right so they filled it with regular oil and then realozed the mistake after driving the car out of the garage. They then brought it back in, drained it and put the synthetic oil in. Can this cause any problems or is it no big deal?
06-15-2005, 03:26 PM | #2 |
Member#: 37644
Vehicle:2009 Legacy 2.5i Blue |
No big deal.
06-15-2005, 03:37 PM | #3 | |
Member#: 16388
You got PWN3D!!!! j/k your fine. |
06-15-2005, 04:33 PM | #4 |
Member#: 58142
Vehicle:2002 WRX/forester WRB/Silver |
well one time i changed my oil and i put on the new filter and didnt realize that the rubber ring from the old filter stuck to the motor. i started the car and and got out to check if there was any leaks like i always do and all 5 quarts were on the ground in like 5 seconds. i turned the car off quick like and then had a mess to clean up. 5 quarts is Alot to clean off a driveway.
06-16-2005, 06:49 AM | #5 |
Member#: 30277
Vehicle:2002 WRX Japan Specs Platinum Silver Sedan |
Speaking of OIL Change!
Since I went with a not Cat Turbo Back Exhaust and Uppipe, IC/Hose, Intake. I've noticed that the OIL Comsumption is much Greater? Anyone, have noticed the same eventhouht I am running Mobil 1 full Syn. Note: I do push the car a lot and notice a lite white smoke at Idle. |
06-16-2005, 05:06 PM | #6 |
Member#: 79493
SCIC
Vehicle:2003 WRB WRX Wagon 5 doors > 4 doors |
check for leaks in the uppipe, that's where a lot of leaks occur.
06-16-2005, 05:40 PM | #7 |
Member#: 23510
South East
Vehicle:2020 Tacoma |
Dude, try changing your own oil next time. I'm a complete noob when it comes to my car (I'm learning), and I just changed it myself for the first time. Check out the write-up I did here and give it a shot yourself: http://forums.nasioc.com/forums/showthread.php?t=786772
Good luck! |
06-17-2005, 12:49 PM | #8 | |
RIP 1/19/64 - 7/23/11
Scooby Guru Member#: 24654
NESIC
Vehicle:1957 Taggart Comet atlasshruggedpart1.com |
Here's a hint: many people run dino all the time. |
06-19-2005, 09:15 AM | #9 | |
Member#: 30800
E. Canada
Vehicle:2000 .7 RS |
ahaha your oil consumption is probably greater because now with all those goodies installed I bet you push your car ALOT more FWIW I switched to castrol syntec and my car eats pretty much no oil anymore, with 140,000km and always driven >3000rpm... |
1st oil change -> skid plate removale -> broken screws | zmoney | Newbies & FAQs | 2 | 01-04-2010 03:13 PM |
HELP: The dealership screws up an oil change... | SubieWReX | Service & Maintenance | 2 | 08-02-2009 08:27 PM |
Did my dealer screw up my oil change?!? | stevessti | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 9 | 12-30-2004 10:48 PM |
Dealership screwed up oil change? | XBD | Warranty Issues & SOA Problems | 13 | 11-28-2001 04:54 PM |
