06-17-2005, 11:47 PM | #1 |
Member#: 71558
Vehicle:2002 TS Wagon Black |
Please Help! Oil pump removal?
Hey guys, I've stff and can not find any info on how exactly to remove the oil pump. I was hoping to have the timing belt/water pump job done tonight. But this oil pump has just brought me to a stand still. What's the trick? I removed 5 bolts from the front side of the pump. I don't see any more holding it in. I do see some type of gasket there, so do I just have to pry it off? I really don't want to damage anything since things are actually going pretty well. Any help would really be appreciated.
Oh, and does anyone know the procedure for the cam seal replacements? Do you just pry those seals out once the pulleys are off?
06-18-2005, 08:06 AM | #2 |
Member#: 71558
Anyone know how to remove this? Anyone at all?
06-18-2005, 10:40 AM | #3 |
Member#: 7555
South East
Why are you replacing the cams seals? Are they leaking? They should be fine if not. As for the oil pump, you will need to pry it out. Careful not to mar up the mating surface on the block but that is how it's done. Remember, the crank shaft is also holding it in place so just work it off slowly. A tip on the crank seal install is to lubricate the inner part of the seal where it slides over the shaft. Have you R+R'd the timing belt before. If not and you've got DOHC engine, it can be tricky so if you need any advice let me know.
06-18-2005, 11:47 AM | #4 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
there are 7 bolts. Look closer. After that you should be able to tap it off from the bottom.
06-18-2005, 02:46 PM | #5 |
Member#: 71558
Thanks a ton man. All done with that.
ANy idea's on how to tighten the crank pulley on an auto? |
06-23-2005, 10:06 PM | #6 |
Member#: 12535
NWIC
Vehicle:Low 06 5MT OBXT 92 EG33 Legacy Rally Car |
theres a hole near the bellhousing that you can put a large screwdriver into, and down there is the torque converter cover or whatever, anysways theres little holes in that so you can make the engine not spin when you have the screwdriver stuck in there.
Oil Pump Removal? | Captain Art | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 01-05-2009 05:44 PM |
ea81 oil pump removal | Subarufene | 'Old School' Subaru Forum | 8 | 10-30-2008 01:39 AM |
oil pump removal = air filter? | sepharad | 'Old School' Subaru Forum | 12 | 09-18-2007 08:57 AM |
Help oil pump seal | DelawareLGT | 'Old School' Subaru Forum | 13 | 12-17-2006 01:09 AM |
2.2L timing oil pump removal question | emyselfandi | Normally Aspirated Powertrain | 8 | 12-22-2005 02:25 PM |
