06-19-2005, 09:45 PM | #1 |
Member#: 88382
BAIC
Vehicle:04 WRX Blue |
Best transmission oil for WRX gearboxes
Has anyone tried the Motul Gear 300 for your WRX gearbox?
Redlines and other manufacturers have cool synthetic oil for the transmission, but some of them are only for hypoid axle without LSD. Mine is 04 WRX, so does anyone know if it has the hypoid axle? I believe the WRX comes with LSD...right? I'm just not so sure, so if advice would be appreciated. I'm in search for a great Transmission oil (something that will help the trannie last longer and shifting easier). Thanks.
06-19-2005, 10:16 PM | #2 |
Member#: 55011
Vehicle:1999 Legacy Outback |
Take a look at the "gear oil" sticky at the start of the transmission forum for starters.
06-22-2005, 07:57 AM | #3 |
Member#: 28062
SCIC
Vehicle:2018 WRX WRB |
I just recently replaced my clutch and switched to Motul 300. Definitely a plus. Car shifts smoothly. I have been running i for only a week but definitely recommended.
06-22-2005, 11:44 AM | #4 |
Member#: 88382
BAIC
thank you Wzcb08. I hope it will be smooth for you for many miles to come.
06-22-2005, 07:01 PM | #5 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
Been running Motul gear 300 for two years - no problems at all. (actually, probably about time to change - debating whether or not I should stick with Motul, or try the Silkolene Silktran Syn 5 stuff...)
06-22-2005, 07:20 PM | #6 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Hey! Alright!
Another thread about tranny fluid. It's about time! For a minute there I thought people were reading the stickies or doing searches. You know why people don't read the search threads about oil and gear lube? It's because there are so damn many of them. Because people keep starting new ones! Hey, go figure! Everybody pretty much swears by what they are using. I think the best thing you can do is try different things for yourself and see how they work for you. I use Amsoil 20w50 motor oil in my tranny. No problems. I like it. Last edited by Tim Sanderson; 06-22-2005 at 07:30 PM. |
06-22-2005, 07:30 PM | #7 |
Member#: 72630
Non-synthetic GL5 75w90
06-22-2005, 07:31 PM | #8 | |
Member#: 72630
06-22-2005, 08:03 PM | #9 |
Member#: 38890
NWIC
Vehicle:2002 WRX |
I saw on the motorsports forum that a concotion of 3 qt of redline mt-90 and 1 qt of redline shockproof will work wonders.
I'm using MT-90 right now... 1st gear is virtually impossible to get into but the shifts are smooth. |
06-22-2005, 09:21 PM | #10 | |
Member#: 6486
Check it out.http://www.amsoil.com/testimonials/8pt2_morempg.aspx tested in a deisel trucks transmission. I've had zero issues for 60,000 miles. |
06-23-2005, 12:35 PM | #11 |
Member#: 72630
never heard of motor oil being used for transmissions...hmmm
your post seemed sarcastic and I thought you were trying to sabatoge us noobs by telling us to put wacky stuff in there, didnt know people did that. hehe ya learn something new everyday <-------n00b for life |
06-23-2005, 12:52 PM | #12 | |
Member#: 6486
Anyhow, good times. |
best transmission oil for STi ???? | imprezivSTi04 | Service & Maintenance | 11 | 05-14-2006 05:18 PM |
Is Redline 75w90NS and regular 75w90 (rear diff) the best gear oil for WRX? | scoobbee | Transmission (AT/MT) & Driveline | 6 | 04-09-2006 02:21 PM |
whats the best "dino" oil for a wrx? | blackie | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 51 | 12-31-2004 03:17 AM |
Best Sythetic Oil for 02 WRX? | sherifx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 19 | 11-08-2001 03:55 PM |
('93-'01) Whats the best oils for diffs,gearbox & engine? | dvs81n | Impreza Forum | 1 | 05-27-2001 04:09 PM |
