06-21-2005, 09:14 AM | #1 |
Member#: 55011
Vehicle:1999 Legacy Outback |
PCV valve torque spec -- 2002 WRX?
06-21-2005, 06:24 PM | #2 |
Member#: 55011
late afternoon bump
06-21-2005, 08:50 PM | #3 |
Member#: 79493
SCIC
Vehicle:2003 WRB WRX Wagon 5 doors > 4 doors |
13 ft-lbs. Hand-tightening it should just about get you between 13-15 ft-lbs.
06-21-2005, 09:20 PM | #4 |
Member#: 55011
Thanks, Eltrouble!
06-21-2005, 10:28 PM | #5 |
Member#: 38890
NWIC
Vehicle:2002 WRX |
When is it recommended one changes the PCV valve? I didn't see it in the maintenance schedules online at subaru, or at my stealership
06-21-2005, 11:04 PM | #6 | |
Member#: 55011
06-22-2005, 02:41 PM | #7 |
Member#: 9498
Vehicle:03 Bugeye Junkyards are fun! |
I changed mine at 40K and honestly, I shouldn't have. The stock one looked like it was in better condition than the new autozone one that I bought to replace it with and the thing was a PITA to get to.
06-22-2005, 04:14 PM | #8 |
Member#: 79493
SCIC
I hear every 15k miles, but it varies from car to car I suppose.
The golden rule is that if you shake the valve and it still rattles, it's probably good. But while you have the PCV valve out, you might as WELL replace it. It's not like it's an overly expensive little item... Oh and for some odd reason it's cheaper to buy the PCV valve along with that plastic joint thingy it connects onto. Subaruparts might have the PN number... |
06-22-2005, 08:04 PM | #9 |
Member#: 38890
NWIC
Vehicle:2002 WRX |
picked up the PN from a thread.
god dang the search function is grrrrrrrrrreat! |
another pcv valve ? on an 04 WRX | awd-box-turbo | Service & Maintenance | 2 | 04-03-2008 10:08 AM |
torque spec for wrx drive pinion assembly? | Tim Sanderson | Transmission (AT/MT) & Driveline | 0 | 09-27-2004 12:41 AM |
Exhaust torque specs in WRX service manual??? | Opal | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 08-31-2004 11:48 AM |
Torque specs for wrx | Tim-E | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 06-26-2004 08:36 AM |
Torque specs on WRX block | wRxbeater11 | Newbies & FAQs | 0 | 01-06-2004 05:47 PM |
