06-25-2005, 01:02 AM | #1 |
Member#: 64528
Engine keeps shutting off at low rpm
I am driving a 2000 Legacy Outback Wagon, 2.5L, SOHC
Very often for the last few weeks, the engine shuts off at low rpm at stop signs, red lights and while slowing down When I try to restart, it restarts immediately Along with this a Check engine light comes on and stays on for several minutes after the engine restarts I have taken it to the dealer They read out the check engine light and They changed the MAP sensor, but the problem persists Then they did a software update for the ECU, and the problem still persists Anyone seen this problem before ?
06-25-2005, 06:32 AM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
What is the actual code that is being set? Need to know that to troubleshoot properly.
Two possibilities that come to mind are the IAC valve sticking (would need cleaning or replacement) or the EGR valve sticking open (assuming that engine has one, not sure). |
Help Check Engine light blink at low RPM | islandboy78 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 23 | 09-20-2007 10:29 AM |
Car Keeps Shutting Off | krazedant | Tri-State Area Forum | 11 | 12-20-2006 10:45 AM |
help- engine ticking at low rpm | windsurfnut | Forester Forum | 7 | 12-03-2005 06:15 PM |
Another question -- Whining noises from engine at low rpm = good/bad? | cerelius | Newbies & FAQs | 31 | 06-09-2005 03:00 PM |
Engine smoother with radio at low volume/off? | Badkarma | General Community | 1 | 05-24-2004 09:35 AM |
