06-27-2005, 11:04 AM | #1 |
Member#: 42912
Vehicle:2003 Outback Sport bird **** & door dings |
tire pressure gauge?
what's a good tire pressure gauge to pick up? also i don't have a compressor or anything, so do the pumps that work off the cigarette lighter work well at all? thanks.
06-27-2005, 12:01 PM | #2 |
Member#: 40307
South East
Vehicle:2004 WRX Sport Wagon WRB |
Per tirerack.com http://www.tirerack.com/accessories/...gauges_all.jsp
I have an accutire gauge and it seems to be accurate and consistent. I have a 'cigarette lighter' compressor that I keep in the spare tire wheel well for emergencies. Before I bought a 33 gal compressor I used to use that for my tires and it would take me a VERY LONG time to put 44 psi in my tires. Now it just takes seconds. |
06-27-2005, 01:11 PM | #3 |
Member#: 82247
Vehicle:2005 Saab 9.2x Aero satin grey |
Those little 12v compressors work OK, but for the time it takes to uncoil the power cord & plug it in, it's easier to just use a bicycle pump.
06-27-2005, 03:58 PM | #4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
I have a 12V compressor that I carry in the car at all times, along with a repair kit to fix nail/screw punctures. It takes at least 5 minutes or more to fill a tire from empty, but usually all I use it for is topping them up or partial filling after a fix, which doesn't take more than a minute or two. Get the biggest/highest capacity one you can find which will make the filling time shorter.
I also have a 12V jumper pack with a compressor built in, I've been using that when checking/setting the tire pressures at home. Much easier to deal with as there are no wires and the compressor works just as fast as my other one. |
06-27-2005, 04:50 PM | #5 |
Member#: 79493
SCIC
Vehicle:2003 WRB WRX Wagon 5 doors > 4 doors |
I just use the normal tire gauge you can pick up from anywhere, the simple 'psi on a stick' reading. It hasn't failed me yet.
06-27-2005, 07:41 PM | #6 |
Member#: 2133
Vehicle:2005 STi WRB/Gold 2005 S4 Avant |
My Accugage dial-type pressure gauge has been in service for over 10 years and still works great. Good bang-for-the-buck, IMHO.
http://www.aircraftspruce.com/catalo.../tiregauge.php |
06-27-2005, 07:41 PM | #7 |
Member#: 79527
Vehicle:2005 2.5RS(I NDTRBO) Chipped Crystal Gray |
I used to work at a tire shop and honestly, the "reading on a stick" guages are the most dependable.
Just get a Metal one. just like the previous poster stated. |
06-27-2005, 08:24 PM | #8 | |
Member#: 79493
SCIC
06-27-2005, 08:46 PM | #9 |
Big Ron
Super Moderator Member#: 18062
Accutire ones are the best and most accurate according to Consumer Reports. I got one off of eBay for like $10.
http://www.retread.org/Inflation/index.cfm/ID/179.htm |
06-28-2005, 12:06 AM | #10 | |
Member#: 28716
SCIC
Vehicle:2006 STI |
06-30-2005, 11:17 AM | #11 |
Member#: 86939
Vehicle:2006 GTI |
Get the Craftsman 12V Compressor/Tire Gauge
Craftsman sells a 12V compressor that you can stick in your cigarette lighter. It also has a built in tire gauge. They work well and are about $20 to $30 at Sears. The compressor will pump up your tires. Look on the driver side door for factory recommended tire pressure.
06-30-2005, 07:02 PM | #12 |
Member#: 78815
NESIC
Vehicle:2005 LGT Atlantic Blue |
I bought a digi Radioshack gauge that works awesome and i bought it for like 19.99 great buy.
Anyone use an Accutire tire pressure gauge? | Bottom Feeder | Brakes, Steering & Suspension | 8 | 07-30-2002 03:00 AM |
Tire Pressure Gauge | Vigorous | Brakes, Steering & Suspension | 5 | 05-17-2002 11:02 AM |
Digital vrs. mechanical tire pressure gauge | brunetmj | Brakes, Steering & Suspension | 10 | 11-26-2001 03:24 PM |
Which is more accurate, digital or normal tire pressure gauge ? | nor1212 | Newbies & FAQs | 3 | 07-25-2001 01:34 PM |
Remote tire pressure gauge system | jeffg | Brakes, Steering & Suspension | 3 | 03-27-2001 12:50 AM |
