06-28-2005, 11:21 AM | #1 |
Member#: 39142
Vehicle:Memb er#: 39142 Join Date: Jun 2003 |
70k miles on an 02 WRX, what will I replace soon?
I've done all of the basic stuff thus far (spark plugs, brakes, air filters, oil changes, battery, fuel filter, etc.).
What are the next things that I should expect to replace? I'm talking real world stuff, not what the dealer recommends. Struts? Timing Belt? Clutch?
06-28-2005, 12:13 PM | #2 | |
Member#: 16957
Vehicle:2002 WRX Grey |
06-28-2005, 12:14 PM | #3 | |
Member#: 16957
wow |
06-28-2005, 12:38 PM | #4 | |
Member#: 39142
I needed a car for daily commuting, winter driving, and Summertime towing. Didn't make sense to buy an SUV, might as well keep the WRX. I can't afford a house around here anyway |
06-28-2005, 12:51 PM | #5 |
Member#: 87896
Vehicle:06 STi Spankaporsch Blue |
My 02 has 89K on it and I've replaced the A/C compressor, the tires, the battery and had the computer chip reprogrammed a couple times to fix the cel glitch where it thinks you are misfiring. I'm going to bring it in to have the A/C freezup fix done too, that came out in a tech bulletin a year or so ago. Other than that, she is still the most enjoyable car I've ever owned. I'll have to think about keeping my 02 as a winter car...hmmm.
06-28-2005, 12:53 PM | #6 | |
Member#: 39142
What about the water pump? I've never kept a car to 70k miles before, so I'm not sure what starts to break down. |
06-28-2005, 12:56 PM | #7 |
Member#: 66659
Vehicle:2000 L WRX'd |
My L has 93K and I am in need of rear wheel bearings, and my A/C has died, not sure if it is just a recharge or the Comp. My motor, trans, and rear are only 35Kish miles old from a WRX so all is newer there.
06-28-2005, 12:57 PM | #8 | |
Member#: 38537
Usually, that gets replaced at the same time as the timing belt. |
06-28-2005, 12:59 PM | #9 |
Member#: 87896
Just had everything checked out a couple weeks ago, everything looks in excellent shape. I think on a Suby you are going to find fewer major things breaking down. Just my gut and some informed reading but the maintenance record for a 02 WRX is about as good as you are going to get. I don't think that you will be seeing any major headaches, just the smaller neusance items like tires and batteries and belts etc.
Oh, one other neusance item to report, my compass in the dimming mirror says that I am always heading NW. I try not to dissagree with my car...but I'm half way through the Yukon and fast aproaching the artic circle and could use directions to a gas station... ) |
06-28-2005, 01:12 PM | #10 | |
Member#: 23547
Vehicle:13 Focus ST Blurple |
And right next to the TB, have you replaced the PCV valve? What about tranny fluid? And the rear diff fluid? Antifreeze? Replaced the brake fluid yet? |
06-28-2005, 01:13 PM | #11 | |
Member#: 6030
Vehicle:04 Gold FXT 07 WRB FXT Sport |
dm 02 wrx wagon >100k |
06-28-2005, 01:22 PM | #12 | |
Member#: 39142
06-28-2005, 04:29 PM | #13 |
Member#: 32371
Vehicle:'02 t-rex wagon platinum |
nothing special for 75k, but soon, u will need timing belt/water pump. belts and hoses are not a bad idea as well, while u're at it, the thermostat as well
i would do all that in one shot at probably 100k, which mine is going to reach probably this time next yr. nothing special rally, just the basic maintance item and you should be fine...and yes, people often overlook the pcv |
06-28-2005, 05:20 PM | #14 |
Member#: 42202
BAIC
Mine's at about 72K and it needs a fan belt. Other than that, I've done all the regular maintenance and haven't had a problem yet.
How to replace rear diff on an 02 wrx? | Pepo | Transmission (AT/MT) & Driveline | 8 | 04-25-2008 12:40 PM |
Will an 05 STi turbo inlet work on an 02 WRX? | zasy99 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 07-31-2007 07:57 PM |
Will an STI wing fit on an 02 wrx? | subynubey | Interior & Exterior Modification | 9 | 11-07-2006 12:38 PM |
will an 05 sti front sway bar work on an 02 wrx crossmember? | irishhockeypimp | Brakes, Steering & Suspension | 5 | 06-07-2006 10:53 AM |
Will an 03 WRX rear diff work on an 02 WRX? | zroom tsuchiya | Transmission (AT/MT) & Driveline | 3 | 03-17-2004 05:41 PM |
