06-28-2005, 08:06 PM | #1 |
Member#: 59659
Vehicle:2002 wrx platinum |
changed transmission fluid = boost problem
I just changed my transmission and differential gear oil, so i removed the intercooler to get to the oil. After i put it all back together, i only get 7psi, 10psi is the max if i floor it. I already double checked and everything is tight. I dont know if it is related, but this is the only thing i have done to my wrx lately. I have a vishnu stage 1 and some other minor mods. PLease help as to what i should check for. I did put a little too much fluid into the transmission, but i dont think this is related.
06-28-2005, 08:33 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
You have a leak or you knocked off a hose somewhere. Check everything again.
Also there's no reason to take off the IC in the first place to fill the trans, you just need the proper funnel. |
06-28-2005, 10:32 PM | #3 |
Member#: 60324
Vehicle:1998 RS |
did you take the compressor and WG hoses off and put them back?
Check for leaks, if you find none, and messed with the compressor/wg hoses, flip them around and see what happens. |
Changing transmission fluid with AT WRX | henzly23 | Service & Maintenance | 5 | 05-01-2006 10:08 PM |
Changing transmission fluid | terrenceseet | Transmission (AT/MT) & Driveline | 0 | 02-27-2006 08:29 PM |
How to change transmission fluid? | njskatchmo | Transmission (AT/MT) & Driveline | 10 | 02-06-2006 11:39 PM |
How many liters do I need to change transmission fluid and what kind? | SpoonTypeR | Service & Maintenance | 4 | 10-23-2004 03:16 AM |
How and when do I change transmission fluid? | FatJoe | Transmission (AT/MT) & Driveline | 2 | 04-22-2003 12:43 PM |
