06-30-2005, 10:49 AM | #1 |
Member#: 34960
Vehicle:What would baby Jesus say of OT? |
STi oil filter seems too small. What about a bigger filter and a heat shield?
I've seen the Impreza oil filter go from huge to microscopic in a few years, which sucks. I just realized that the filter for my 05 STi is the same as my wife's 02 Mazda Protégé 5! I have read that the push for a smaller filter on Imprezas was to keep them from being too close to the header (heat transfer to the oil) . So what about going back to the older, bigger filter and making a oil filter heat sheild? Anyone remember what the old Purolator Pure One part number was for the Impreza? Any thoughts?
06-30-2005, 10:50 AM | #2 |
Member#: 59692
Vehicle:2005 Impreza WRX STi WRB-Gold |
No need for a larger filter. In fact why would you want a larger filter? The STi filter is the very same as the WRX filter.
06-30-2005, 10:55 AM | #3 | |
Member#: 34960
06-30-2005, 11:02 AM | #4 |
Member#: 86617
Vehicle:2011 WRX STi Dark Gray Metallic |
Purolator does make a Pure One filter that is the same as their filter for the STi except that it is slightly longer. Dia., sealing surface, thread pitch is all the same as their filter for the STi. I do not remember the exact part number though. However, it is the exact filter specified for my wife's 03 Honda Element. Check out the fitment guide for the Element and you will have the longer filter for the STi. The last time I changed the oil on both cars, I was going to just get two of the longer filter, but they only had one of each in stock. Next time, I'll make sure to get the longer one. HTH
Fred |
06-30-2005, 11:05 AM | #5 | |
Member#: 34960
Just about how much longer would you say that filter is? |
06-30-2005, 11:11 AM | #6 |
Member#: 24038
South East
I'm pretty sure there are better things to worry about. That filter is spec'd with (without a doubt) a significant factor of safety. Its probably at least double what is required for the engine. You're engine is only .5 liters bigger than your wives, the block is the same size as a 2.0 wrx Why would you think you need a bigger filter???
06-30-2005, 11:14 AM | #7 | |
Member#: 59692
06-30-2005, 11:26 AM | #8 | |
Member#: 34960
06-30-2005, 11:38 AM | #9 | |
Member#: 34960
06-30-2005, 01:14 PM | #10 |
Big Ron
Super Moderator Member#: 18062
You do realize that you are trying to out engineer a team of professional engineers at Subaru who specialize in this sort of stuff right? While you are free to do so, realize that your efforts are really for naught. If you are THAT concerned, get off the wallet and buy a $200 bypass unit that filters your oil to HEPA levels. This will both relocate and outfilter the OEM unit.
06-30-2005, 01:47 PM | #11 | |
Member#: 34960
06-30-2005, 02:08 PM | #12 | |
Member#: 20611
Vehicle:2003 WRX World Rally Blue |
06-30-2005, 03:32 PM | #13 |
Member#: 18298
SWIC
Vehicle:2004 STi |
Somebody over on IWSTi.com purchased and cut open a large number of the most poplular filters and compared the internals. The consensus was the stock filter was one of the best ones out there in terms of construction and/or filter media area.
06-30-2005, 03:39 PM | #14 | |
Member#: 34960
06-30-2005, 05:21 PM | #15 | |
Member#: 43853
NESIC
Vehicle:2004 WRX Sedan Stg 2 Platinum Silver |
the subura filter is a quality filter, my dealer charges $6.50 and it's well worth it. i change w/ M1 oil every 4k, imo if your so concernced about clean oil then why would even consider changing it at 7.5K intervals. |
07-04-2005, 10:44 AM | #16 | |
Techno Sapien
Moderator Member#: 449
Vehicle:2019 Impreza Sport Lithium Red |
PN 15208AC060 filter surface area 760cm2 PN 15208AA100 filter surface area 800cm2 (a 5% difference) |
07-04-2005, 05:51 PM | #17 | |
Member#: 37678
SCIC
So, big women have loose p*****s, all things being equal, of course? Dude, I understand your desire to baby your investment to the 'nth degree. THere is a place I know of, full of like-minded people, that could become home to you: www.bobistheoilguy.com There, you can discuss the minutae of polyol esters, lube control, flow vs. filtration, and dancing green elves turned golden. Last edited by poison; 07-04-2005 at 05:57 PM. |
FS: Oklahoma, JDM STI TMIC w/o Y Pipe 240.00 shipped and SPT heat shield 45.00 | casionerd | Engine/Power/Exhaust | 8 | 12-13-2007 03:36 PM |
Stock STi downpipe and NEW heat shield | GeorgeRex | Engine/Power/Exhaust | 6 | 09-02-2007 04:25 PM |
2005 STI Cobb AP and/or Heat Shield | tungsten | Private 'Wanted' Classifieds | 0 | 03-31-2006 01:37 PM |
The 2.5L STi oil filter is too small | mlambert | Service & Maintenance | 34 | 06-19-2005 12:31 PM |
