Welcome to the North American Subaru Impreza Owners Club Sunday February 25, 2018
Old 08-08-2001, 03:00 AM   #1
elemental
Member#: 2701
'00 obs
Default door light turning on?
the light in the center of the roof (door light, i guess, donno what to call it) turns on when the car loses traction or starts moving sideways a little in turns... when it's set to the door mode (on when the door is open) scares me sometimes, esp. at night, why does it do this? has it happened to someone else, and where along the circuit was the problem?
elemental is offline   Reply With Quote
Old 08-08-2001, 10:39 AM   #2
spurner
Member#: 7289
1993 Impreza WRX RA
Default Re: door light turning on?
I don't have the same model as you but I have the same problem and just recently worked out what it was for me (pretty simple).
Whenever I go hard around a left hand corner the g-forces push my right forearm hard into the door-trim and push it out enough so that the sensor thinks the door is open and ther light comes on momentarily.
I know it sounds kinda simple but that's the full story and I haven't figured an easy way to fix it yet either.
spurner is offline   Reply With Quote
Old 08-08-2001, 04:04 PM   #3
elemental
Member#: 2701
'00 obs
no, heh, i don't think it was that, both my hands were on the wheel, i don't think i had my elbow on the door, but ill be sure to take notice next time, see if i'm just not imagining im not.
Old 08-08-2001, 11:17 PM   #4
spurner
Member#: 7289
1993 Impreza WRX RA
Okay I knew it was bit of a longshot but I still think it's something to do with the sensor if it's only coming on momentarily when your car does certain things.
Old 08-08-2001, 11:32 PM   #5
elemental
Member#: 2701
'00 obs
might be. drivers side door is permanently slightly open... when you run your finger along the side it is not flush. some guy told me that the latch on the actual car where the hook on the door attaches too might be out of whack because he moved his and it was back to normal. but the screws were hard to get out and i didnt want to mutilate them... guess i might take it to the dealer for that, i mentioned it before when i went to get 30k service or something but they didn't do anything or bring it up at all... so donno. will check, just wanted to see if it was a reoccuring problem with others too.
Check Engine light turns on when I Redline Rex Booster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-25-2006 04:57 AM
Anybody elses brake light turn on when driving? druxboyz Electrical & Lighting 4 10-05-2005 01:27 PM
AT "power" light turned on while driving nosajh9 Transmission (AT/MT) & Driveline 3 09-20-2005 10:16 AM
I/C water light turns on at high RPM.. Scav1180 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-10-2004 03:58 AM
Bright lights stuck on when lights turned on?? paultg New England Impreza Club Forum -- NESIC 7 04-11-2001 01:31 AM
