07-01-2005, 10:43 AM | #1 |
Member#: 78840
Fuel Filter replacement?
How can I know if my fuel filter on my 01 RS is good or not? I'm not getting horrible gas mileage really...ill get maybe 310-315 a tank with "spirited" driving lol i just dont know when the last owner replaced it or not...i called the dealership i bought the car from and they said they only replaced the brakes and pads when i bought the car
07-01-2005, 12:18 PM | #2 |
Member#: 3808
Vehicle:2005 Forester XT!!! Crystal Gray Metallic |
If your car isn't starving for fuel you can assume it's good. You can also assume it's been on there since the car was built. You can also assume that it'll plug up sooner than later. Replace it. It's only a 15 minute job at the most.
07-04-2005, 10:30 AM | #3 |
Techno Sapien
Moderator Member#: 449
Vehicle:2019 Impreza Sport Lithium Red |
07-04-2005, 11:55 PM | #4 |
Member#: 19879
Vehicle:2004 WRX Java Black |
Symptoms of a clogged fuel filter include sputtering at high RPM and difficulty starting. Ideally, you want to replace the filter before these problems occur... Subaru recommends replacing the fuel filter every 30k miles. It's a $20 part and is easily accessible in the engine bay. The toughest part of the install is getting the hoses off the filter, but a little patience goes a long way.
Here's another good how-to page. http://www.northursalia.com/m...r/ffilter.html |
07-05-2005, 12:02 AM | #5 | |
Member#: 17315
International
Vehicle:MY95 Impreza 207C MY05 Forester 257X |
-paK +4 |
07-05-2005, 02:05 AM | #6 |
Member#: 79493
SCIC
Vehicle:2003 WRB WRX Wagon 5 doors > 4 doors |
I wish I had fancy schmancy tools for the job, it was more like...
Need nose pliers + elbow grease + strained fingers + cut on hand from when it slipped + 1 hour job + frustration at the lack of space on these damn boxer engines = fuel filter replacement. Next time I'm cutting those filthy hose lines and simply replacing them. quick hijack...can somebody explain to me how to replace the PCV valve? I can see the valve very clearly, I can disconnect the hose, I CANNOT get that BOV return hose out of the way. The clamp is facing downwards so I can't get that off, and there's not enough space to fit a wrench in there. Plus the BOV return hose is looking a bit worn, so I'll probably have to replace it, but if I can't get those clamps off, I can't replace jack. Any thoughts? |
07-05-2005, 08:01 AM | #7 | |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
07-05-2005, 11:17 AM | #8 | |
Member#: 17315
International
-paK +1 |
07-05-2005, 01:04 PM | #9 |
Member#: 79493
SCIC
....what are you talking about? iirc, the hoses simply were wiggled onto these hard lines. it looked fairly easy to simply cut them and install another pair. In any case...wrestling with extremely tough rubber lines were not my cup of tea, especially with very limited spacing.
07-05-2005, 07:14 PM | #10 |
Member#: 1135
BAIC
Vehicle:2005 WRX WAGON Silver |
I had no problems wiggling them off when I changed it. It took me all of 10 minutes to change out. This was on my old RS. I hear they moved the fuel filter next to the tank in the 05 wrx
07-05-2005, 07:23 PM | #11 | |
Member#: 79493
SCIC
07-06-2005, 04:05 PM | #12 |
Member#: 90156
NWIC
Vehicle:1986 Syncro Vanaru 07 SV650 |
Something to be wary of if you cut your fuel lines and need to replace them when you undertake this job is replacement of the hose. Most likely, the hose you are cutting is fuel injection hose which has a higher burst pressure, 30-35 psi, usually, and a higher price, usually about $8/ft. If you replace with the standard HVLP stuff that is about $1.99 per foot you stand to have that hose burst during service, a failure with predictable outcomes.
07-06-2005, 04:48 PM | #13 | |
Member#: 79493
SCIC
11-28-2005, 09:21 PM | #14 | |
Member#: 32684
SWIC
Vehicle:2015 STi Ice Silver |
-Shane |
11-28-2005, 11:50 PM | #15 | |
Member#: 79493
SCIC
I'm still a fairly green mechanic. |
11-30-2005, 03:59 AM | #16 |
Member#: 39092
Vehicle:2004 WRX STi Java Black Pearl |
Damn, I wish it were that easy to change the fuel filter on the STis. Last time I checked, the fuel filter is attached to the fuel pump, permanently! So if you want to change the filter, you have to replace a perfectly working fuel pump along with it! It's a $500ish part!
11-30-2005, 12:25 PM | #17 | |
Member#: 79493
SCIC
11-30-2005, 04:17 PM | #18 | |
Member#: 39092
11-30-2005, 05:27 PM | #19 |
Techno Sapien
Subaru moved the filter to the gas tank in 04 for the STi and all the other Subarus in 05 Seems like a major step backwards if you ask me.
However if you look at my page: http://www.scoobymods.com/forums/showthread.php?t=3645 It says you can get and replace only the filter (not sure what the PN is though) I'm not sure why people are saying you have to replace the fuel pump too. I do remember when the STi was new and somewhere in the US people got a rash of bad gas that clogged the filters, no one had the filters yet (or PN it was so new) that they had to change the whole assy that included the filter and pump. I'm just guessing here anyone know for sure? |
11-30-2005, 06:22 PM | #20 | |
Member#: 39092
I hope someone who has recently changed their fuel filter can correct me on this! |
11-30-2005, 07:11 PM | #21 |
Techno Sapien
Funny in my link I have scans from the Service Manual showing the filter as a removable part. I wonder if they are doing the similar thing they did when our MAF's started going south in the 99's
11-30-2005, 07:22 PM | #22 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Replacement interval for the in-tank filter is 60K, vs. 30K for the external filters.
11-30-2005, 07:37 PM | #23 |
Techno Sapien
The external filter costs 15 bucks max
11-30-2005, 07:40 PM | #24 |
Trust no one
Yep not saying it's cheaper, just that it doesn't have to be done as often.
Fuel Filter replacement - where is fuel pump relay? | SeenDubAYouAreEx | Newbies & FAQs | 4 | 07-11-2007 09:29 PM |
fuel filter replacement | loudog800 | Service & Maintenance | 4 | 03-06-2004 11:26 PM |
Fuel filter replacement | Shifter | Service & Maintenance | 3 | 08-31-2003 06:16 AM |
wrx fuel filter replacement | phillywrx | Service & Maintenance | 9 | 10-10-2002 12:12 PM |
Fuel Filter Replacement? | Ryan24 | Service & Maintenance | 8 | 08-07-2002 10:59 AM |
