Welcome to the North American Subaru Impreza Owners Club Sunday February 18, 2018
Old 08-08-2001, 12:59 PM   #1
lustreking
Member#: 5154
1999 Legacy L
Default Wacky Speedometer
Since the past weekend, my speedometer has been freaking out.
Under 20 mph, the needle bounces around from 0 to around 30 mph. It does it when accelerating to 20 or decelerating from above 20. When above 20 mph, the speedo appears to operate normally.
Has anyone had/heard about a problem like this. If so, is there a solution?
Thanks
Steve
www.lustreking.com
lustreking is offline   Reply With Quote
Old 08-08-2001, 01:28 PM   #2
kevinsUBARU
Member#: 2263
2013 Outback
Lube up that spedometer cable.
Good luck,
Kevin
kevinsUBARU is offline   Reply With Quote
Old 08-08-2001, 03:16 PM   #3
XROLLER
Member#: 1273
98 Impreza
RBP
Default speedo
Well mine has been doing that for about a year now......i don't think there's a cable to lube our speedo is ran electronicly, somehow? I haven't gottin it taken care of, out of lazyness but i've talked to other people when it first happend and they said the dealer is the only one for the fix....?
XROLLER is offline   Reply With Quote
Old 08-08-2001, 03:27 PM   #4
Poseidon
Member#: 4864
2004 WRX
Yeah, I believe the speedometer works by measuring the ammount of resistance on a wire. Bad speed sensor, maybe? Yeah, you'll probably have to take it to a dealer, or at least a certified Subaru mechanic.
Jordan
Poseidon is offline   Reply With Quote
Old 08-08-2001, 05:31 PM   #5
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
I believe the speedo works on a vehicle speed sensor (a tone wheel, or hall effect sensor). You probably have a bad sensor or maybe the tone wheel is funked up with magnetic material...
--Roy
LUME is offline   Reply With Quote
Old 08-08-2001, 06:53 PM   #6
kevinsUBARU
Member#: 2263
2013 Outback
I assume you are talking about your 1995 Legacy LS which is in your profile, so I suggested the cable because I believe 1995 was the last year of the cable. I have a 95 Impreza with the same problem before I had it lubed at the dealer. I think the speed sensor thingie was introduced in 96. Just trying to help out
Kevin
Old 08-09-2001, 01:44 PM   #7
lustreking
Member#: 5154
1999 Legacy L
I was hoping it would be something as simple as lubing the cable, but the shop manual says it's electronic. I guess I have to look for a "speed sensor #2", and see if that helps.
thanks all,
-Steve
www.lustreking.com
The board is wacky today!!! redobs New England Impreza Club Forum -- NESIC 54 11-01-2001 01:32 PM
Friday - Wacky caption contest! webkris New England Impreza Club Forum -- NESIC 93 09-25-2001 11:29 AM
Scoobies don't get no love! TWO wacky encounters in one day...***? Sean New England Impreza Club Forum -- NESIC 11 08-24-2001 12:46 PM
What type of inline fuse to use for Sony MP3 deck and wacky wiring? remarcable Car Audio, Video & Security 4 08-23-2001 11:21 PM
Wacky Intercooling Idea... Rex4me Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-20-2001 03:54 PM
