07-04-2005, 08:40 PM | #1 |
Member#: 89909
Vehicle:2005 WRX STi World Rally Blue |
Help reading oil dipstick
I'm a bit confused by the STi dipstick. I changed the oil at 2000km with dino oil. I used 4.5 qts. When I check the oil when the engine is hot, say 10 minutes after turning the car off, the dipstick reads past the full mark, and the top hole is filled with oil. If I leave the car sitting for 8-10 hours (or overnight), then the dipstick reads just over the L, and only the bottom hole is fill with oil. This has happened since I did the oil change, so I don't think I'm burning oil.
Is this normal? Did I put in too little oil? I don't understand why I'm getting two different readings.
07-04-2005, 09:14 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
The proper fill amount is 4.8 quarts, not 4.5. So you're already a third of a quart low to begin with. The oil is best checked with a cold engine, after sitting overnight so all the oil is in the pan and there also won't be as much up in the dipstick tube to get on the stick and confuse the reading. Make sure the car is on a level surface.
07-05-2005, 03:22 AM | #3 |
Member#: 1135
BAIC
Vehicle:2005 WRX WAGON Silver |
Actually the proper fill amount is not 4.8 quarts for the 04-05 wrx's and sti's. They changed the oil pan size and it only holds 4.2 quarts. Otherwise, yes engine cold and level surface for an accurate reading.
07-05-2005, 11:48 AM | #4 | |
Member#: 2133
Vehicle:2005 STi WRB/Gold 2005 S4 Avant |
LOL, the confusion continues with the proper amount of oil for the STi. Here's an e-mail I rec'd from Subaru:
07-05-2005, 11:55 AM | #5 |
Trust no one
Also there may be some confusion because the capacity is shown in liters, US quarts and Imperial quarts. Only the US quart amount applies. 4.5 liters = 4.8 US quarts.
07-06-2005, 08:36 AM | #6 |
Member#: 86939
Vehicle:2006 GTI |
Be sure to wipe your dipstick clean before reinserting. The oil from it can get on the inner walls of the cylinder.
Reading The Dipstick | 510Style | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 09-29-2008 07:50 PM |
Reading the Dipstick (Engine Oil) | Gunner | Service & Maintenance | 7 | 11-19-2005 08:45 PM |
Trouble reading oil dipstick? Fix inside... | dsmperformance | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 07-25-2004 03:57 PM |
Newbie Question: How to read a dipstick? | kdawg | Newbies & FAQs | 17 | 12-07-2002 04:57 PM |
