Welcome to the North American Subaru Impreza Owners Club Thursday April 19, 2018
Old 07-08-2005, 02:38 PM   #1
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Default gfb pulley set belt sizes?
anybody know what it is? mine have just about had it and i need to replace.
ken
Old 08-05-2005, 11:16 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Hi Ken,
I’m assuming you have our 2 pulley kit, and that your car is the “bugeye” model? If so, the belts you need are 5PK 836 for the power steering and alternator, and 4PK 850 for the AC. On the chance that you have our 3 pulley kit, you’ll need a 5PK 820 instead of the 5PK 836.
We sell these belts as spares, the 5PK 836 is $27, the 5PK 820 is $25, and the 4PK 850 is $23, all in $AUD.
Regards,
Brett Turner B.E. (Mech)
Engineer/Technical Sales
Go Fast Bits
+612 9569 7648
www.gofastbits.com.au
soooo i went to http://www.speedycarparts.com/ and got :
Bando Multi Rib Belt Price: $11.29 Qty: 1 Part #: W1000-83832
Bando Multi Rib Belt Price: $11.53 Qty: 1 Part #: W1000-27637
which are both SLIGHTLY shorter in length. i did this because my old alternator/ps belt had stretched to the point where i ran out of travel on the belt tensioner, and the ac belt was close to being maxed out too. the belts weren't even really dead, it was just that i couldn't adjust them to snug them up.
the belts were a bit of a PITA to install, because of the lengths. the alt belt in particular required the removal of the pivot bolt to get it on the pulley, but once it was on and snugged up and used a bit it stretched out enough to prevent this from having to be done again to remove/reinstall it... and the big thing is that i won't run out of travel on the tensioner.
hope this helps someone,
ken
FS: GFB Pulley Set, Alternator, Starter, Timing Belt and Exhaust Jus Blaze Engine/Power/Exhaust 80 06-21-2009 04:07 PM
Agency Shift Knob, GFB Pulley set w/ Belts chinoWRXL Drivetrain 1 09-08-2006 01:23 PM
Red GFB pulleys with belt wreckedWRX Private 'For Sale' Classifieds 5 04-06-2005 11:33 AM
GFB Pulley kit Belt Part Number Ruz WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-20-2004 12:32 AM
Who's using GFB Pulley set? redrex3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 02-23-2002 04:31 PM
