07-08-2005, 03:24 PM | #1 |
Member#: 70481
TXIC
Vehicle:95 Impreza Semi-Flat Black |
Problems!
Has anyone ever had the nut that is spot welded in the frame rale brake loose while trying to remove the bolt that is in it? It happened to me. I am in the process of changing my 93 from front to all whell drive. The front bolt on the passenger side of the rear cross member. I eventually got it out but had to cut the side of the frame rail so I could get a wrench in there to hold it still.
The front bolt on the other side is rounding off. Any ideas? Please help me!
07-08-2005, 03:58 PM | #2 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
07-08-2005, 03:58 PM | #3 |
Member#: 41626
NWIC
Vehicle:SPB We make people quit teh internet |
http://www.sears.com/sr/javasr/produ...id=00952166000
Bolt out socket for removing stripped bolts and nuts. I had to use these for a similar problem and they worked great |
07-08-2005, 04:34 PM | #4 |
Member#: 70481
TXIC
Thank you Both. I can't use a torch because the bolt is about 3 inch from the gas tank, I am only doing the rear sus. and brakes right now.
07-09-2005, 09:34 AM | #5 |
Member#: 70481
TXIC
I got the bolt out kit and it worked great. But, now I popped the welds on that nut as well. So I did the same as I did on the other side and cut a hole just big enough for a wrench to fit in there. Now the nut behind it has popped loose. At least I will have all new fasteners in there by the time I'm done.
07-10-2005, 04:43 PM | #6 |
Member#: 70481
TXIC
07-10-2005, 08:07 PM | #7 |
Member#: 70481
TXIC
Now I have a Joint, CV spindle wheel bearing failure. I was driving on the interstate when the rear of the car became a little uneasy and then a sudden jerk to one side and the wheel locked up. I got the car off the road safely. When I got out to see what had happened the drivers side rear wheel was toed out at about a 35 or 40 degree angle. The only thing that held the wheel on was the brand new Subaru 2 pot caliper that had the brand new disk wedged enough to not let the hub come out of the hub carrier. The caliper is scared up but I think it will function fine. The parking brake assymbly seems fine as well, but the backing plate is bent. I need to know if the hub assymbly is lost, I can't tell at the moment. I will take pics if anyone can help me out. Please anyone. This is my familys only car, and now we are stranded.
