07-08-2005, 06:05 PM | #1 |
Member#: 71495
Vehicle:1999 Impreza 2.5RS Black |
Can't find oil leak, help..
I got an oil leak, but I can't locate it. The oil is all over the driver's side steering arm boot. The power steering is still full, so I think its actual engine oil. Can any body guess where it's coming from? The valve cover gaskets are all good (I just replaced them). No oil leaks from the front of the engine or the oil pan or the oil bolt.
Any guesses or pointing me to the right direction is much appreciated. Thanks It's a 99 2.5 RS w/ 163,000 miles on it. Thanks again. I can take pictures if that will help.
07-08-2005, 06:43 PM | #2 |
Member#: 63616
South East
Vehicle:1996 Volvo 850 Turbo with mods :) |
THe best thing to do is to clean up all the oil you can...brake cleaner will work. Then drive the car for a few days. That should help locate where the fresh oil is. If I had to guess, I would say it is probably your front engine seals. Double check the valve cover gaskets anyway. Just because they are new does not mean they can't be leaking if defective or improperly installed.
07-10-2005, 01:18 AM | #3 |
Member#: 17315
International
Vehicle:MY95 Impreza 207C MY05 Forester 257X |
Pictures will help, try to if you can. I have a hard time imagining right now.
-paK +0 |
07-10-2005, 02:10 AM | #4 |
Member#: 3148
TXIC
Vehicle:12 Ford F150 EB 00 BRP 2.5RS (again) |
Brake cleaner will eat at rubber... it shouldn't be used like that because there is a lot down there it can damage.... use Simple Green as it won't damage rubber or aluminum...
07-10-2005, 02:15 AM | #5 |
Member#: 17315
International
I use Orange clean/citrus-based cleaners. Stuff works amazing. And smells good
-paK +1 |
07-10-2005, 03:44 AM | #6 |
Member#: 1112
Vehicle:2006 FXT RBP |
I love working on my car and everything smelling good!
07-11-2005, 12:46 AM | #7 |
Member#: 71495
I will post pictures tomorrow night, if i figure out how i can download them onto the board.
I already tried wiping everything up and made it all clean, by the time I went under the car again, there was oil all over the steering arm boot. I replaced the valve cover gaskets myself (first time) so i thought i may have done something wrong. They were pretty easy, as everyone stated on this board, so I'm always checking on those seals. They are pretty dry from what i can tell. I'll post pics. so you guys could have a better idea of what i'm talking about. |
07-11-2005, 12:59 AM | #8 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
I think you may have a leaky rear main seal. Just above the cross member there is an inspection cover. Wipe your finger across that. It's probably oily.
It could also be the oil separator plate on the back of the block. |
07-11-2005, 01:33 PM | #9 |
Member#: 71495
The cross member also has oil on it too.
Is that a difficult fix for the rear main seal or pricey? |
07-11-2005, 02:16 PM | #10 |
Member#: 6486
Do you have an engine hoist? A torque wrench and a clutch alignment tool? And a set of tools?
If you have all that and a garage with a full day to work on it then it's do-able. |
07-11-2005, 02:24 PM | #11 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
For a dealer to fix, it's ~6 hours of billable x $/hour they charge.
For a DIY person, it is not too bad. I would do the rear seal, check the oil seperator plate (if plastic, they leak, if aluminum they are OK). To do either requires you pull everything that a clutch would take as well as removing the flywheel. Good time to do a light flywheel and maybe new clutch. |
11-18-2005, 09:49 PM | #12 |
Member#: 36333
NESIC
Vehicle:98 RS GT30R, closed deck madnes |
did you ever find the leak? what was it?
Oil Leak Help Help Help | blackbeast | Built Motor Discussion | 3 | 05-25-2007 09:22 AM |
Need help finding oil leak | fast71 | Service & Maintenance | 4 | 05-04-2007 04:42 PM |
can't find drl mod- help! | madeguy | Interior & Exterior Modification | 3 | 04-28-2006 08:50 AM |
Can't Find Bulb #...HELP! | scoobydrew06 | Electrical & Lighting | 3 | 10-18-2005 03:02 PM |
can't find the LEAK | WatsonBillSOT | Newbies & FAQs | 2 | 10-18-2004 06:18 PM |
