07-09-2005, 06:08 PM | #1 |
Member#: 88807
Vehicle:2000 Forester Silver |
Fuel Filter Change...Oops!
welp...changing the fuel filter on my 2000 Forester today and...oops, i pinched the hose too close to the nipple and punctured it. this is _after_ a titanic 45 minute struggle including the walking around muttering phases. anyway, went down to the local auto-parts place and the closest match they had was 5/16" normal (not hi-pressure) tubing. it seemed to fit the nipples well enough but the clamps were a little small for it.
so the Q is...i'm going to have to change these out again to get some fuel-injector-firendly hoses in, what's the exact diameter i need to look for? i would imagine it's some meteric number but i wasn't able to find diameters in the FSM. a second, less important Q is, i read that i should use some lithium grease on the middle nipple (i just like saying nipple) zone but i couldn't find any lithium grease at the parts store. only lithium-based lubricant i can recall seeing is spray can based, but i think i'ld want something in a tube to manually spread around. any brand suggestions? as always, thanks for the help.
07-10-2005, 01:14 AM | #2 |
Member#: 17315
International
Vehicle:MY95 Impreza 207C MY05 Forester 257X |
I used intake cleaner by BG, makes it slide on easily. Dunno where you can buy it. It also is a penetrator and lubricant, so it reduces the 45 minute struggle to a 30 seconds paradise to remove the hose.
-paK +1 |
07-11-2005, 01:53 PM | #3 |
Member#: 88807
so 5/16" is good then? no meteric fuel line sizes?
07-13-2005, 04:15 PM | #4 |
Member#: 90156
NWIC
Vehicle:1986 Syncro Vanaru 07 SV650 |
2.54 centimeters per inch. If you do the conversion you can see what the old hose says on it, see if it is close to the diameter you arrive upon. Or just measure the metal line. You definately need to get some FI hose. You would not like an engine fire. Or just replace it with normal fuel hose and uprgrade your insurance. Dont tell em about your work though, cause that will be an issue when your car burns up and you are trying to get paid.
96 legacy fuel filter change | kleddon | Newbies & FAQs | 1 | 01-15-2005 10:45 AM |
wrx fuel filter change | phillywrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 10-25-2002 07:24 PM |
2.2 Fuel Filter Change | Jersey Mike | Service & Maintenance | 4 | 06-30-2002 06:06 PM |
Fuel Filter Change on 1998 Forester S | Ginseng | Forester Forum | 4 | 04-11-2002 06:47 PM |
Fuel Filter Change | tt17ct | Normally Aspirated Powertrain | 5 | 05-22-2001 08:46 PM |
