07-10-2005, 05:18 PM | #1 |
Member#: 82486
1st oil change
Just wanted to know if anyone had any tips on trying to unscrew the drain plug and oil filter on a 2005 RS. I tried crawling under the car and just going at it but the damn things wouldn't budge. I think I'll end up taking it to the dealer to get it changed.
07-10-2005, 05:39 PM | #2 |
Member#: 71191
Vehicle:2005 WRX Wagon Platinum Silver Metallic |
The drain plug shouldn't be very tight. I use a socket and if it doesn't budge, bang the end of the handle with the side of my fist to jar it loose. If that doesn't work try a piece of tube or pipe over the handle to give you more leverage.
As for the filter, mine was on very tightly and half way through an oil change isn't an ideal time to go out and buy a filter wrench! I ended up using a piece of metal bar against the edge of the filter and tapping it with a hammer to rotate the filter. A messier way is to punch a screw driver through the filter and push on the handle to rotate the filter off. Several risks with this - damage to the oil filter housing on the car, mess, and then if it doesn't come off you are really stuck as you have a punctured filter on the car so you can't even refill with oil and drive somewhere for help. Try getting a filter wrench and make sure it is the right size and will fit on the filter before you start. Good Luck! Mark. Edit: Forgot - buy a new crush washer for the drain plug. On mine the washer was painted black, like the plug, and it didn't look like there was one there at first! Make sure to remove and replace the washer. |
07-10-2005, 06:10 PM | #3 |
Member#: 34931
Vehicle:. Super bowl LII Champions! |
just remember this
righty tighty...lefty loosey |
07-10-2005, 06:50 PM | #4 |
Member#: 75078
South East
Vehicle:2011 Forester 2.5X Dark Gray Metallic |
when you finally do get the old subaru oem filter off (use a pair of grippy gloves if you have them) go to any auto parts place and get a fram oil filter that has a grippy bottom part to it so you dont have to worry about it anymore. oil filters should only be tightened no more than 1&1/2 times after it comes in contact with the block.
07-10-2005, 07:20 PM | #5 |
Member#: 10135
Vehicle:MY02 IMPREZA WRX platinum Silver |
Get a fumoto Valve http://www.fumotovalve.com/
Get a breaker bar to loosen that bolt. It'll be useful for future projects too. |
07-10-2005, 07:55 PM | #6 |
Member#: 20773
SCIC
Vehicle:2002 WRX Midnight Black Pearl |
i've got a fumoto valve, it makes it super easy and much cleaner. however, the threads stick into the oil pan, so if you want to get all the oil out, you'll have to remove the valve or tilt the car (i prefer the former rather than the latter). not sure if they have a new version or not.
07-10-2005, 08:55 PM | #7 |
Member#: 82486
Thanks for the help. I'll try the breaker bar. They must have used air tools to get that thing on in the factory.
I got the filter and the crush washer from the dealership, wouldn't you know it but the 2005 RS uses the STi oil filter... the price was ridculous. I would skip out on the Fram filters, heard cardboard isn't exactly the best "filter" material. But that's a discussion for another thread. |
07-11-2005, 03:17 PM | #8 |
Member#: 68799
Vehicle:2004 2017 FXT PSM |
Just go here (http://www.allsubaru.com/catalog.html) and get a case of them with crush rings for a decent price. Buy 5W-30 Mobil 1 synthetic from WalMart at $20/ 5 quarts and about every 5th change will be free oil from the leftover.
Just a thought. |
07-11-2005, 04:35 PM | #9 | |
Member#: 84445
South East
Vehicle:2002 WRX Wagon |
07-11-2005, 07:20 PM | #10 |
Member#: 89912
Vehicle:2006 wrx wrb |
i've had that problem with a new tractor. (i'm not kidding) sometimes drain plugs are relly tight when they come from the factory.
07-11-2005, 07:47 PM | #11 |
Member#: 79527
Vehicle:2005 2.5RS(I NDTRBO) Chipped Crystal Gray |
Same with the filter. From the factory = bitch-tight.
After your first oil change, if you do it right, the filter will come off by hand. And for the drain-plug, just bang the wrench with your fist and make damn sure you are going the right way. I've never had to use a breaker bar on an oil pan. You'll be aaiight. |
07-11-2005, 08:16 PM | #12 |
Member#: 38397
Vehicle:2002 Lovemachine Silver |
My drain plug wouldn't come off either, I used to always take it to the dealer for oil changes. I guess they use the airtools to tighten it. I had to use a breaker bar to get it off.
07-11-2005, 08:24 PM | #13 |
Member#: 88219
BAIC
Vehicle:2003 WRX |
DO NOT go to the dealer for a simple oil change. Just get a long ratchet and pull hard.
You should also make sure you don't try to change the oil after driving. |
07-12-2005, 12:27 AM | #14 |
Member#: 79527
why? Because of the heat?
It may be an old wive's tale, but I thought that you were supposed to change it after it has come up to operating temperature. You know to let the contaminants and such flow out. That's the way I've always done it. |
07-12-2005, 12:45 AM | #15 |
Member#: 12329
TXIC
Vehicle:2o15 WRX Ice Silver |
let it run for a few minutes, for the oil to thin out. any more, and it hurts pretty bad
07-12-2005, 11:37 AM | #16 |
Member#: 88734
Vehicle:2005 WRX Wagon Platinum Silver |
Did my oil for the first time on my 05 this past weekend. The drain plug wasnt too bad to get off, but the filter took a while. Couldnt use the usual strap type filter wrench because the filter is recessed in there and there was no leverage. So we got one of those wrenches that has 3 teeth and attaches to a socket wrench. Then since the filter was smooth and had no grip, we wrapped a peice of rubber around it for grip... LOL. PITA but we got it off. Should be good to go now. I also needed to use a box cutter to score around teh old crush ring since it was totaly painted on.
07-12-2005, 12:22 PM | #17 | |
Member#: 23510
South East
Vehicle:2020 Tacoma |
Also wongvi, (shameless plug) I put together a write-up when I changed my oil for the first time. You can check it out here: http://forums.nasioc.com/forums/showthread.php?t=786772 |
07-12-2005, 12:45 PM | #18 |
Member#: 4430
Vehicle:2003 outback tan/white |
as others have mentioned, don't over tighten the oil filter. A simple trick I've used is alway tighten it w/ your less dominant hand. I'm right handed so I use my left to put it on, then I know my right hand can always take it off.
07-12-2005, 02:19 PM | #19 |
Member#: 84557
who here changes their oil every 3000 miles? i go 5000! I heard there is no difference what so ever, aside from you spending a whole lotta more money on oil.
07-12-2005, 02:27 PM | #20 |
Member#: 23510
South East
If you're using full synthetic, 5000 is OK. A lot of us here just feel better changing it out every 3K for the peace of mind. Also, "spirited driving" will warrant more frequent oil changes. In the grand scheme of things, what's 20 bucks and 15 minutes?
07-12-2005, 06:09 PM | #21 |
Member#: 79527
I like 3500 to 4000. The manual says 3750.
07-12-2005, 06:17 PM | #22 | |
Member#: 37719
Vehicle:2003 WRX |
07-14-2005, 10:11 AM | #23 | |
Member#: 2133
Vehicle:2005 STi WRB/Gold 2005 S4 Avant |
Me, I'm going to use a 5,000 mile OCI when I switch over to using Castrol Syntec 0w-30 (a.k.a., German Castrol) in a few hundred miles. If you really want to know how your oil is holding up over a specific drain interval, have the used oil analyzed and make sure to have them perform a TBN (total base number) analysis. This will give you an idea of how "used-up" the oil is. If the TBN is still good at say 3,000 miles there is no reason to drain the oil. |
07-14-2005, 12:17 PM | #24 |
Member#: 82486
Oh no worries Perret, not a shameless plug whatsoever. I have that thread printed and put in a binder. I was referencing it when I was "attempting" the oil change.
The oil change intervals are a personal preference I noticed, since I killed my old car by not changing the oil, I think $20 + 15 minutes every 3 months is not too bad. This first change however I am probably going to take it to the dealer to do because I don't have the equipment to pry off the oil filter and drain plug. I just have to make sure to tell them not to screw in the filter and plug so damn tight when they reinstall it. |
07-14-2005, 09:24 PM | #25 | |
Member#: 37719
Vehicle:2003 WRX |
'06 STi- 1st oil change done and oil leaking from filter? | Domo-Kun | Service & Maintenance | 30 | 10-16-2005 06:57 PM |
1st oil change (1000k) | cre | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 05-11-2002 11:15 AM |
When to Have 1st Oil Change for New WRX | Big_Hitter | Texas Impreza Club Forum -- TXIC | 4 | 10-23-2001 11:55 AM |
Need to do 1st oil change in Vancouver... | Necromancer | Vancouver Impreza Club Forum -- VIC | 24 | 09-06-2001 09:27 PM |
post break-in/ 1st oil change power increase | Godmal | General Forum Archive | 4 | 03-27-2001 10:11 PM |
